Everything posted by Rlmcowboy
Oil pump for my Gl wagon
Rlmcowboy replied to Rlmcowboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Soooo.... Replaced oil pump, Mickey Mouse gasket came off in 3 pieces. Put every thing together and it still knocks. Got a rod flopping around like a fish outa water. Best place to find a replacement or just rebuild? -
I know the gauges are inaccurate. Car has 90k miles. Gauge normally read good at start up then would read low when driving and drop to near nothing at idle. Which I know is "normal" for these cars. When the engine noise started gauge stayed zero. I've heard the TOD on other vehicles. This is more than that. I'll try and upload a video. Thanks -
Low to no oil pressure and engine knock -
Installed the new pump. Too bad it didn't fix the problem..... -
Bought an oil pump. It'll be here Tuesday.so the ole wagon is sitting in the shop waiting..... -
Part# for oil pump 15010AA004. I think the one I got is the last in the U.S lol -
Ordered gasket and seal.those were easier to get. Thanks guys -
Would bad seals/o-rings make it sound like the engine is about to explode? Yes it's an EA82. Wagner done some research the pump that has the idiot light instead of gauge(like on my car) the same pumps I'd just have to swap parts to use gauge instead of the light. -
I'm pretty sure my oil pump went bad on my 86 Gl wagon. I called Wagner Subaru dealer and talked to them and they agreed. They can't get a pump so they gave me the part number so I could look online. I'm not having much luck. Anybody have any ideas? Can the pump be rebuilt?
Try these guys. I've ordered gaskets from them http://www.walkerproducts.com/
How to ship an engine
Rlmcowboy replied to the sucker king's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've used uship before.had a huge sectional couch ship from ne Ohio to sw ohio for less than what it would have cost me in gas. Uship.com is the website I believe -
My 86 Gl with just under 70k miles. It's my daily driver and a work in progress. Custom rear bumper,replaced rear hub and wheel bearings,weeded out some of the emission bullcrap and rebuilt the carb. The wife's ride,2010 Impreza. Custom wheels,tint we windows and new audio system
Help! Cant get axle shaft into hub assembly?
Rlmcowboy replied to Leebo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hammer method worked for me. Once I had it pulled through so far I used the old stripped out drum and ran the nut down to pull the rest of the way -
Rlmcowboy replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rear wheel hard to move
For some reason when I jacked the car up last night I was able to turn the tire fairly easy.went ahead and double checked everything and torqued axle nut down. Some some rubbing on the backing plate but it's pretty much got trashed when the bearings exploded while driving with a stripped out hub. I see a disc brake conversion in the future! -
I know it's not brakes. I didn't even put them on. They're trashed and waiting on new shoes and hardware kit. I temporarily plugged the brake line and put hub on so I could move the car around. I will get torque wrench and go that route and see what happens. Thanks for the help! -
86 Gl wagon 4wd
