Hi There, First off I am new to this, but have read many articles on USMB before.
My problem is I was driving my 91 Subaru Loyale 4wd (226k) when it just shut off. Now all it will do is turn over, but wont even try to fire.
I have newer timing belts, which i checked and are set properly, newer head gaskets too, just passed smog 3 weeks ago.
I checked the fuel pump, working well, even changed all gas. Great spray coming from fuel injector (SPFI) in rythem.
I am getting spark, in rythem at each spark plug. Checked the screw on rotor and it didnt fall out.
Has newer exhaust.
No trouble codes
Fuseable links are good, even switched them out with extra set, all fuses under dash good.
Good compression, definately not a mechanical issue, has to be electrical, fuel or air????
Ive worked on subarus for a while and I still have NO clue whats wrong..... Getting spark, air , and fuel (even with starter fluid nothing). I have heard of this problem once before and the car just went to the scrap yard, I really dont want to do that to my subie.....
Anyone have a similar problem? Possible relay, computer, or bad electrical????
Same as this artical, but I need an answer http://www.ultimatesubaru.org/forum/topic/129943-problem-with-loyale/
PLEASE HELP! I am defiantely dealing with a more advanced issue than a bad fuel pump, coil, fuse, or timing belt, etc issue cause I have ruled those all out.
What should I try now, I am becoming desperate.
Thank You For Your Help!!!
