seattlealex
Everything posted by seattlealex
  1. Well after calling ten auto wrecking yards in Seattle. They all tell me that my Transmission is a one year only and can only be swapped for an identical unit. If this is true that's a hugh pain. Of course they just looked it up on their computer and told me what the screen said. true or not?
  2. Thanks for all the great advice. I'm currently looking into buying a unit from a junk yard. this was yet another thing I tried that didn't work too well. Last time I tried something crazy, I installed a carburator off a v6 pinto on my 604 peugeot. It ran, but not any better. That car was disaster.
  3. I have a 1999 Legacy wagon with a 5 speed manual, 2.2l. somehow the center differential got toasted and I think it will be cheaper to drop in a new (used) tranny. From what I've read I can use most any 5mt as long as the final drive is the same. I have a TY754VAAAA, FINAL DRIVE IS A 3.900. Will all of these tranny's bolt up to my 2.2L (phaze two, if that matters)? I'd also be interested in advice on parts to replace while the tranny is out. A clutch kit of course, but any seals, or ...? All transmissions in the list below have these four specs. TR = 1.000 FD = 3.900 Center Dif = Viscous (4kgf) Rear = Open Model/Engine/Year Tranny # 1st 2nd 3rd 4th 5th rev Impreza AWD 95 TY752VT3AA 3.545 2.111 1.448 1.088 0.825 3.416 Impreza EJ18E AWD 96 TY752VT4AA 3.545 2.111 1.448 1.088 0.825 3.416 Impreza EJ22E AWD 96 TY752VABBA 3.545 1.947 1.366 0.972 0.780 3.330 Impreza EJ18E AWD 97 TY752VT5AA 3.545 2.111 1.448 1.088 0.825 3.416 Impreza EJ22 AWD 97-98 TY752VA5AA 3.545 1.947 1.366 0.972 0.780 3.330 Impreza EJ22 99-00 TY754VA1AA 3.545 1.947 1.366 0.972 0.780 3.330 Impreza TS 02-03 TY754VC2AA 3.545 2.062 1.448 1.088 0.780 3.330 Impreza Outback 02-03 TY754VC2BA 3.545 2.062 1.448 1.088 0.780 3.330 Impreza TS 04 TY754VC4AA 3.545 2.111 1.448 1.088 0.780 3.330 Impreza Outback 04 TY754VC4BA 3.545 2.111 1.448 1.088 0.780 3.330 Legacy 94 TY752VAABA 3.545 2.111 1.448 1.088 0.780 3.416 Legacy 95-96 TY752VABAA 3.545 2.111 1.448 1.088 0.780 3.416 Legacy 97-98 TY752VACAA 3.545 2.111 1.448 1.088 0.780 3.416 Legacy 99 TY754VAAAA 3.545 2.111 1.448 1.088 0.780 3.330 Legacy L & Brighton 00 TY754VCAAA 3.454 2.062 1.448 1.088 0.780 3.330 Legacy L & Brighton 01-02 TY754VCBAA 3.454 2.062 1.448 1.088 0.780 3.330 Legacy Outback 01-02 TY754VCBCA 3.454 2.062 1.448 1.088 0.780 3.330 I hope this list helps others with Tranny issues. Took me a while to type up.
  4. Hi, I have a 1999 legacy wagon, 2.2L, 5mt with 130,000 on it. last spring the car started making clunky noises while turning, so of course I replace the front axles. still making noise. So I replaced the right ball joint. still making noise. Then I replaced the right front wheel bearing. still making noise. (these things probably needed to be done anyway). I finally figured out that the center differential needed help and was making the clunking noise. I bit the bullet and jacked up the car. pulled off all the stuff to get to the tranny extention and then pulled off the rear piece with the center differential. The snap ring on the viscous unit had come off and was in lots of pieces. bearings not bad. viscous unit was frozen. I decided to clean everything up and reinstall the unit. I also removed the rear piece of the propeller shaft so I'd be converting the car into a front wheel drive. I left the front half of the propeller shaft installed, to stop tranny oil from leaking out. After reinstalling all the parts I thought I'd go for a test drive. No Way. couldn't even make it down the drive way. with the tranny in gear and clutch all the way out it barely moves. feels like the clutch isn't fully engaged. this was never an issue before I "fixed it". is there anything that I might have done to cause this clutch issue? I dont' know if the clutch can be adusted, or bled or something. Any advice would be helpful.
