state
About state
- Birthday 08/05/1965
Location
Sharpsburg
Referral
web
Biography
Subaru lifer. Just bought a 2013 Legacy Sedan.
Vehicles
1995 Legacy Wagon
state's Achievements
Advanced Member (3/11)
10
I'm still fighting a CEL light on my 95 Legacy Wagon too. My code is P0170. Fuel trim malfunction. I checked alldata.com and it said 1- check for air intake leak, 2- check for exhaust leak, 3- fuel pressure, 4- coolant temp sensor, 5- Mass air sensor. Before I looked at Alldata, the first mechanic said it was the front o2 sensor. I replaced it and the CEL came back the next day. About 60 miles later. Took it back to him and he said it might be the ECM. Lost confidance in him. Took it to another mechanic, he said it was the rear o2 sensor. I replaced that and it came back a couple of days later. I know it's the same code because I bought my own obd II reader. I'm going to check my fuel pressure next and if that's not it I'll probably replace the Mass air sensor. Have checked the other things the best I can and I think they are OK.
I have been fighting this CEL for 2 months now. I have replaced both o2 sensors. No help. Here's the latest. I got some info from alldatapro.com that said for a p0170 on my 95 Legacy Wagon to first check exhaust for leaks. No problem found. Then the air intake for leaks. No problem found. Then fuel pressure. I don't have a gauge so I skipped that one for now. Now to what I did find. The engine coolant temp sensor. My Haynes book says to test the resistance across the terminals with the engine cold and then when hot. The readings I got were within the range listed. So far so good. Then I am to check the reference voltage to the sensor from the ECU. It should be 5 volts. It said to disconnect the connector to the sensor and with the ignition on and the engine not running I should see 5 volts. I get 145mv. I'm sure I was making good contact. Could this be my problem? There are only 2 contacts in the connector. Could my ECU not be sending the 5 volts or could I have a bad wire between them? Car doesn't run bad. CEL just keeps coming back.
o2 sensors
state replied to state's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
My car was made in 1/95. It has the OBD II system. -
o2 sensors
Yes. They only list 2. 1 is labeled as front oem ( has connector on) the other is front universal (you splice the oem connector on). I have found 2 placed on-line that list a rear one but it is the same part number as the front one all the other sites list. I wonder if it is just a typo on there sites. If they are the same why don't all the other sites list them that way? -
o2 sensors
Someone has got to know the answer to this. -
The Goodyear mechanic is telling me that this p0170 fault is caused by the rear o2 sensor. The first mechanic I took it to said it was the front o2 sensor. I replaced the front one but the fault came back. I took it back to him and he thought it might be the EMC. I thought he was guessing so I took it to another mechanic. Does this second mechanic's conclusion sound right?
