mike motta
mike motta's Achievements
Newbie
Newbie (1/11)
10
  1. Hi Folks: I'm probably going to need to replace a brake caliper assembly on our Forester with ABS. I've done this tons of times on older vehicles without ABS. Is there any special technique to doing this on a car with ABS? Is the system bled the same way as a system without ABS? Anything "new" I need to know before doing this job? Thanks in advance!
  2. Hi all: Can anyone help with details on aligning the camshaft and crankshaft pulleys so that I can replace a damaged timing belt on my '93 Justy? Also, does anyone know if the cranshaft pulley bolt is reverse-threaded (right to loosen instead of left to loosen)? I can't seem to get it loose! Thanks, Mike
