Everything posted by kirzick
Hey all. I did try searching i just didnt find anything. I'm in the middle of swapping in a ej22 into my gl. The harness is from a 92 and the engine is a 90. The engine harness has three grey plugs while my harness has two white / grey plugs. Can I just switch the engine harness? Thanks
My 73' Coupe Restoration
kirzick replied to Datsunrides's topic in Historic Subaru Forum: 50's thru 70's
This is awesome. Thanks for all the great info. -
Awesome! Thank you!
Anyone have a working copy of the write up for the ea81 spfi swap? I can't find a working link anywhere... thanks!
5 spd push button in Gen 2 wagon
kirzick replied to kirzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks for the info. I'll try to take good pictures and post a guide -
I have the vac/electric stuff. It's a street car mostly. Does the ea81 console still work? I know the boots are different at least. Thanks -
Hey hey. anyone stick a 5 spd single range in a Gen 2 wagon before? It's out of a 90 loyale. I'm just looking for tips or what to expect. And yes I've tried searching I only find duel range stuff. Thanks
Ea82 rear wheel bearing tool?
kirzick replied to mykingcrab's topic in Old Gen.: 80's GL/DL/XT/Loyales...
dead link -
There's a ea81 tan wagon in breaking bad. It's in a episode showing a Montage of Wendy the hooker getting customers.
Best looking replacement for brat tail lights
kirzick replied to kirzick's topic in Historic Subaru Forum: 50's thru 70's
Just the lens or is the plastic mounting part that the bulbs sit in there? -
I might have some parts depending on what you need. You from Marysville Washington?
1978. I'm missing the headlight mounting brackets , taillights, side markers, blinkers, and gauges. Could also use some decent front fenders. I will probably go with trailer lights for now. If anyone has a lead on parts near Olympia Washington I'd really appreciate it. Thanks all! -
*teaser* rear EJ brakes on EA car..
kirzick replied to PoorManzImpreza's topic in Subaru Retrofitting
Can you update this please I could really use the info. Thanks! -
After scouring the forums and not having any luck finding xt6 rear hubs i found these. They look very similar im just curious to know if they could be adapted. Im in no way a expert when it comes to new age subaru stuff so pardon me if this seems dumb. Thanks! Xt6 hub (Numbchux picture) Forester Front hub
I know this thread is old but a update would be really appreciated!
I thought ea 81 motors dropped straight in?
how does this newer gas effect our older engines?
kirzick replied to Hsoj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you mean like standard unleaded? I have no problems with it in my 84. -
Ea82 Loyale Lift Block Positions
Thank you! -
I also started to install my lift kit. I bought a 4'' lift from sjr. No offense scott but i'm kinda upset with the quality. On the front strut spacers the bolts are only tacked on, not fully welded. And the back brackets are different lengths.. They will work i just wish they were done better for the price. I decided i could build the rest of the kit myself. I bought 5 ft of 1/4 3'' by 2'' square tubing for 30$ from ziglers welding. Cut, Drilled, and Painted by a friend. Getting there! Crossmember blocks and front strut spacer blocks on! Took the fenders off to roll them and smash the wheel wells in abit. Also Id like to thank my wonderful girlfriend for the help!
When its not raining and i'm not being lazy i can actually get stuff done... Who'd a thunk. Got lots done, still have a lot to do. Engine Prepped. Was this supposed to connect to something? Was held on with two bolt and not doing anything. Transmission Freedom! Engine out! Jusd used a old fense tentioner and a beam in my car port. I cant belive how light these engines are.
The outer edge of the same bracket correct? Also i used 7/16 steel allthread to do the engine crossmember. Will this be okay?
