Everything posted by BoxerRebellion
drive shaft replace 89 gl wagon manual
BoxerRebellion replied to Robbman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Typically, yes. Easy. Everything is pretty straight forward. Be able to safely lift the rig. Use a punch to bash out the retaining pin that holds the CV to the tranny. Possess the proper axle nut socket to pull 'er off. Possess the proper socket to unbolt the control arm nut. Then... Rip it out. Take new one, put it back in. There's plenty of youtube videos that'll give you the know-how to do this job comfotably. If you're not comfortable, find a buddy to help. Since you own a Soobie, this is a good job to know how to do. Best of luck. -
Ahhhh yes. CV-axle troubles. I have an '87 GL Wagon. Ft. a '93 Impreza tanny. Stock hubs drilled to 6. When it came time to replace a CVA.... An '87 GL CVA didn't fit. A '93 Impreza CVA didn't fit. However, an '87 GL-10 (turbo) CVA fit like... Play-dough perfectly moulded into tupper-ware..... My point...? Sometimes it simply takes trial and error to find the right part. Be certain you're purchasing through a company with a decent return policy. All of my questions regarding what I mentioned above were answered here at USMB. With that said, it sounds like you're on the right path. Best of luck.
And the fortune cookie says... "custom exhaust is in your future."
It's Friday folks. And with a new weekend, comes a new Scoob-Related question. To all of the high voltage gurus out there... My pillar-gauges are bright as can be. Driving at night with the most neon-of-light smashing into your eyeballs can be a struggle. Correct me if I'm wrong, but there must be something that can be wired inline to dim the brightness? Yah? Perhaps a... Resistor? That would limit power, resulting in dimmer lighting, correct? What could be wired inline, to dim aftermarket Autometer pillar gauges? Much appreciation in advance.
- 2 replies
- Electricalgauges
- lighting
(and 1 more)
Tagged with:
Loving the 14' Rex !
BoxerRebellion replied to subiJ's topic in Meet n' Greet. Your USMB Welcome Center
First things first. Exhaust! -
One brake light quit working
BoxerRebellion replied to pparrish's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds silly, but make sure the bulb is in correctly. Having the offset "side posts" or "terminals" allows for only one proper fit. -
Harbor Freight tools to avoid or not expect much from
BoxerRebellion replied to idosubaru's topic in Shop Talk
Since we're on the topic... Didn't have much luck with the 24 toothperinch hacksaw blades. Teeth bent on the double. 50 for $5.00! Hard to say no. http://www.harborfreight.com/12-inch-24-tpi-hacksaw-blades-50-pack-37155.html -
Well, being that you posted this two months ago... And apparently created a profile just to ask... You probably don't need any info anymore. With that said, it appears to me that your device comes with an iPod cable. The prettiest way to use that cable, would be to string it through your trunk. Plug your iPod in, select iPod track on your nav device. Voila.
You have an '09 that needs control arm bushings? That genuinely surprises me. Some hack didn't tell you right? This guy didn't tell you which bushing(s) needs replacing? Both front control arms? In the end, if you truly do need to replace any bushing - nab some polyurethanes from Energy. That's what I'd do. Not if it's one side though. That'd be undesireable. Poke your head down there and try to identify what this guy's talking about. "If it ain't broke, don't fix it."
Awesome. Thanks for taking the time to share this photos. As we all know, the photo process from camera to website, can be rather tedious.
Congrats. I've had good times in Loyales. Couple Loyales actually.
This was very cool to see. My gratitude goes out to the guys who to it upon themselves to start USMB. As well as to everyone who worked hard to keep it alive to this day. So guys like me, over a decade later could come join this Subie-Brigade and share/learn/inform. Thank you all.
Grab a multi-meter and chase it. Also, on top of simply physically verifying that fuses aren't blown, check them for voltage with the ignition "ON" That'll start the "chase" then go from there. Find out what fuse the ICM is on, trace it from there. (I realize, it's a pain) I don't know for certain regarding it's location, sorry. There could also potentially be a bad ground somewhere.
New 1987 Subaru GL wagon owner
BoxerRebellion replied to Yagster's topic in Meet n' Greet. Your USMB Welcome Center
Welcome Yagster. I too have an '87 GL wagon. We're all gearheads here at varying levels of gearheadedness. I've had multiple questions answered here... That I more than likely would not have been able to obtain anywhere else. Congrats on becomming a Subie owner. -
'87 GL Wagon Wheel Stud Dimensions
BoxerRebellion replied to BoxerRebellion's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Rock on! Nicely done dude. Thank you very much czny. -
Ha! That's the same site I opened when I googled "virgin switch."Fun read. Thinking back... I recall my two Legacies having that switch. Orientation was flipped though. And... My '02 Impreza TS had it as well. I believe. I'd never heard of it till tonight. Let's take this one notch further... Why's it called "the virgin switch?" 'Cause dudes like me think their lights are on, when really it's just that **** switch? A virgin no more. Funny. My fourth Sub is the one that gets me.
- 16 replies
- 1
- Electrical
- light problems
(and 2 more)
Tagged with:
Happy Friday folks. I write today regarding two wheel studs that need replacing on my '87 GL Wagon. This wagon has a six-lug hub conversion. One stud is missing and the other... We'll let's just say it's FUBAR'd. I went to CarQuest the other day and could only order the studs on the hub. The whole assembly. I can order studs based on length, shoulder and knurl. 12x1.25. Who here knows knurl diameter, shoulder size and a decent enough length? Thank you guys.
Hatchback Speaker Setup
BoxerRebellion replied to Skylar's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I'm not sure about how big of speakers can be stuffed into the panels. Fatty magnets and all. If you're wanting to get buck wild though, you could cut up that rear "cargo floor" in your trunk, put what you want in ...and lay some plexi-glass over it. -
Did Subaru use better paint on the GL?
BoxerRebellion replied to Rooasaurus Rex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ahhhh.... Interesting. That would explain why my Maroon '87 GL's roof is fading. -
I almost... Almost... Just almost... Slightly took offense to that. Then I googled it. Good call sir, good call.
- 16 replies
- Electrical
- light problems
(and 2 more)
Tagged with:
No climate control
Subaru Windows Vista lol. I like that. I did what I could man man! You're in Corvallis, you've got it a little drier. As you know. With all that rain came in a month or so ago, this "no defrost problem" turned serious. This is my daily. And I did use an ohm meter. (It's a feature contained in my multimeter ) (Admittingly, voltage makes more sense to me than ohms) *Pressure vs. resistance - this and that. The blower motor was shot! The motor resistor was shot! The relay wasn't grounding! Replaced 'em all and opted not to make matters worse... Rather remedy the situation by any means necessary. Now My T-Line rig is that much closer to being fully mountain-worthy. You dig? I know you do sir. BR OUT! Yeah! -
Need a peugot rim. 4x140 15 inch
BoxerRebellion replied to AustRabel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://row52.com/ You're welcome. -
gl third eye Assemble
BoxerRebellion replied to joelkinkade's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm not sure what the question is here... What is the value of additional 12v powered lighting in automotive applications? Why one? Get two, even it out. Twice the value!
