Everything posted by AWD J3wman
$1,111.00 for a complete EA82 gasket set !
AWD J3wman replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A lot of eBay stores will set the price to something outrageous like that when they are out of stock. That way they don't lose their listing and they readjust it when it's back in stock. -
Elder Scrolls VI: Pleiades 1986 Subaru GL-10 Turbo
AWD J3wman replied to AWD J3wman's topic in Members Rides
Exhaust and Coilovers are now on. Got some help with questions from Numbchux as well regarding the best setup. Currently these are KYB GR-2s with some Shengxiong Manufacturing Corp. Miata coilovers just for fitment. I'll be investing in a set of Ground Controls and Koni shocks in spring once I get everything measured up to my liking. -
Got it to my work so I can work on it this weekend. custom downpipe, exhaust and fresh fuel pump are going in and while I'm at it, I'll see what I can do to lower the back some more. I might hack off a coil or 2 up front as well. Got the downpipe bends completed! Just have to add bungs and flanges. Next step is a 3" exhaust! While I'm waiting for my downpipe to be finished by my friend at work, I've begun pulling out the carpet so I can properly clean it. Also had my friend Jared Levine clean up my back seat which had a brutal stain on it, looks damn near new, if you're in the Minneapolis area definitely hit him up for detailing services. He saved me a grip of cash by cleaning it up. -
So the interior of my GL that I'm restoring smells like a old wet gym sock, IT'S GREAT! But all great things must end and I would like to find a fresh carpet. Thing is, my usually go to places either come up with universal carpet kits or nothing at all and worse yet, tell me my car doesn't exist. So I know someone at some point here must of sourced one before. Has anyone been able to find a pre-molded carpet for a EA82 wagon before? Any help would be much appreciated. Thanks!
God I love that car, I wish I could find some preface lift corner lights that arent spiderwebbed. -
Started it up for the first time in a while, currently no DP and no O2 sensor, plus still a lot of oil in the intake system so hopefully that explains the plume of smoke. 1 step at a time though. -
How To Keep Engine Cooler? Any Ideas?
AWD J3wman replied to Subasaurus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I got some longer bolts and a 1" spacer from menards, then I used them to raise the hood. It actually worked really well, I get around 5-10 degrees cooler at running temp and on boost its closer to 10-15 degrees. Also, I removed the spare tire and that helped a lot. I plan get some DEI gold heat wrap for the turbo heat shield. -
Slow revs and hesitation: 90 Loyale EA82T
AWD J3wman replied to Jabbott126's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm having the same issue, I assumed it was bad compression but I should check my timing as well. How are your head gaskets? any leaks? -
lololololol performance EA82. But actually I am going to use an EA82 for a chump car so stock Miata rear struts and XT fronts are going to be awesome in it.
- 12 replies
- ride height
- springs
(and 7 more)
Tagged with:
A set of Z31 fuel injectors would help a lot. I would take them to Fuel Injector Clinic so they can flow test them and rebuild if needed.
- 12 replies
- Ea82t
- horsepower
(and 4 more)
Tagged with:
xt gl10 dash going crazy after coil over swap
AWD J3wman replied to tytuk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
or you can just completely pull the compressor out and sell it to me if it still works? -
I've got a set of XT front struts on OEM coils and rear miata Bilstein struts with ground control coilovers. Even with Monroe struts with generic coilover sleeves it handled so much better.
where does this turbo coolant hose go?
AWD J3wman replied to turbosubarubrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah I was going to get one, I work at MAPerformance so I have a B&M cooler I've got my eye on. I originally was going to use a BMW E30 tranny cooler a buddy of me gave off of his chump car. -
Update time! Got some color matched enamel paint today so I can finish up my bumper filler and grille and get em on! -
I would be interested in that. I would still need the rubber line though. -
I don't mean to bring up an old thread but the bottom line that goes under the engine is the coolant return line, correct? Mine NEEDS to be replaced (including hardline) and I can't find a new one. I could just run that return line to another area and cap off the original banjo bolt hole with a standard bolt right? -
The XT I pulled the steering wheel from was an XT6 so 6 cylinder. If you're asking about the struts, they're brand new Monroes. Crappy Autozone brand or whatever but lower and better than what was in there. -
exhaust sound, post yours!
AWD J3wman replied to l75eya's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Here's my GL-10- 4 replies
- 1
- exhaust sound
- custom exhaust
(and 1 more)
Tagged with:
Those were just EBay coilovers on stock KYB struts, I have switched to Miata Koni yellows with ground control coilovers no pictures yet due to winter. Honestly, I highly recommend stiffer springs in the rear compared to the front, it completely changes the handling characteristics as you would imagine. it cornered about as well as my CRX did on all season tires. (HHHUUUGGGGEEEE Improvement for an EA82) -
Ugg I can't wait to finish up my Civic so I can pull the engine on my EA82 and rebuild it...
