disom93
Everything posted by disom93
Is this a coil issue, pickup, or what
Have swapped to new carb and my brat still shuts off st like 1200 its like u turn the switch off? Whats causing this
Or would a ea81 swap me alot easier? Idc for alot power i just like havelow range
Is it possible for first gen
Can anyone give me somewhat step by step on a ej22 swap in 1980 brat?
Im just wantinf to run it till i can get a 32-36 weber would that fiesable
Anyone knoe anything about these carbs? They good bad??
Filters have just been changed last time i vleaned carb good it fixed it for about a week?
This is the 2nd time my brat has done this it just randomly starts and it misses and spits and sputters if u arent wide open to the floor but if u mash it wide open it runs fine. Whats wrong with it??
Makes sence ill probably go with 32-36
Wondering the same for my ea71
Ok i thought it was 10 or 11 lol wrong
Whats the tank capacity of a 1980 subaru brat 1.6??
I beveled mine when i redrilled a set of 6 lugs worked out awesome. Lugs dont ever try to work loose at all and its really smooth.
Ok i will itll be xmas probably before i do lol but ill probably get the 38 as long as it checks out that it will work ok
Would it be hard to find ea81 and trans
Ok i just had heard i couldnt just do a bellhousing swap
Do could i just swap housing to use dual range trans? I have top mount starter
Ive had apart and cleaned 2 times somethings clogged somewhere idk where tho
Could u use my shaft and cut it down? Or splines diffrent?
Can someone tell me what i need for sure 100% to swap to something with low range or dual range. I have a 1980 brat 1.6. 4speed single range with top mount starter do i need diffrent bellhousing or what???
Ok thanks a bunch mine just wont idle below 1200 and will take random spurts and idle like 2k idk for sure whats wrong
Ok thanks a bunch. Is there anywhere to buy these carbs decent price
Would the 38 get WORSE fuel milage then the stock hitachi. Mine just wont idle snd randomly idles high. Its not a daily driver more like weekend trail cruiser. Would i notice more power with the 38 or not good for my setup
