440
I have had those exact two bosses welded due to the same collision damage. Steven of Inferno Fabrications had no trouble at all. But he is VERY good with TIG in general. He has welded cracked AVLS pressure switch bosses IN THE CAR with perfect results. The man is an artist. Given his skills I have no problem handing him that block. GD
PCV Hose Replacement
GeneralDisorder replied to MWLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You want emissions hose. It does exist. GD -
Easy job. Drain coolant, pull manifold - takes about 30 minutes. Replace o-rings. Clean gasket surfaces, replace manifold. At a shop this should take no more than 2-3 hours and the gaskets are about $20 for all of em. From the dealer. $350 tops. And thats a pretty high estimate. Dealer is one of the WORST places to take a Subaru. GD
Like I said - it's going to come down to cheap turbo parts. The shop should be made aware of the outcome of the repair.
- 60 replies
- Forester XT
- VVT
(and 2 more)
Tagged with:
Starter gear clicking
You need to tighten all the flexplate bolts. It will pull the torque converter away from the starter pinion. GD- 1 reply
- 2
OE isn't necessary - just quality. You can't make big HP if you stick to OE. We use Melett for factory turbo CHRA's, and we stick to Blouch for performance upgrades. GD
- 60 replies
- Forester XT
- VVT
(and 2 more)
Tagged with:
They key always twists to the drivers side. Leaving the passenger edge of the keyway intact. You simply clean up the mess, install a new key, and it will bear against the good passenger edge of the keyway when tightening. The key will be held just fine because three corners are held by the new sprocket, and one good edge. It will tighten up just fine and once the bolt is tightened to 150 ft/lbs the key is meaningless. GD
Oh I knew what the conclusion was going to be. But thank you. GD
- 16 replies
- 1
120k is not really a premature failure though. Even if they had to be done twice as often - not really enough of an issue to go out of the way to "correct" on a vehicle that is only seeing enough abuse to have a failure after 120k. If they were failing once a season I might consider some type of upgrade. Otherwise it's a waste of time for anything that isn't a full-on race car and isn't seeing regular failures. And if that's the case - upgrade to STI knuckles. If higher temps are being seen then simply changing the grease really isn't enough because the thermal growth will cause too much load inside the bearing assembly. At that point you need to loosen up the clearances with a spacer shim between the bearing cone's. Probably change the grease and the cage material as well. Or just get bigger brakes that don't get as hot. Air ducts to cool them also. GD
Yep that's your problem. Either put the old one back on if the rear cover wasn't leaking, or get one from the dealer. GD
- 10 replies
- 1
- powersteering
- steering
(and 2 more)
Tagged with:
They are very nice. Definitely worth the price in my opinion. Extra 1.5 quart capacity and the new version is cast aluminium. Fitment is virtually perfect. You need a wobbly 10mm 1/4" drive socket. Pull the intercooler, pitch stop, and jack the engine as far out of the cradle as you can. If you want or need engine mount upgrades (we like Cusco but be warned they are pretty much full race mounts and you will get some vibration) thats the time to do them also. GD
