440
Specifically, if the cable is too tight it will cause all kinds of idling problems. It needs to be LOOSE. GD
- 43 replies
- 1
- MAF Sensor
- 2003 Subaru Impreza 2.5 RS
(and 1 more)
Tagged with:
Check the tension on your accelerator cable. GD
- 43 replies
- 1
- MAF Sensor
(and 1 more)
Tagged with:
Ea81 hydraulic lifters.
GeneralDisorder replied to Strutmaster801's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Agreed! We run Amsoil's high zinc oils in everything and anything modified or raced gets Dominator. Catalytic converters may not appreciate it long term, but engines are a lot more expensive than converters. GD -
No they are not. -
Go back to basics - have you checked for +12v on the solenoid wire to the starter while holding the key in the crank position? Use an incandescent test light for this to give the circuit some load. If you get a bright test light then the problem is either the starter solenoid, or the battery cables. GD
Foreign engines inc in Lynnwood Washington has EJ25 short blocks for about $900. They are from JDM EJ254's. They are a direct swap for the USDM 251/253. The EJ20 has no power and fuel economy will suffer with the USDM gearing, etc. GD
- 8 replies
- 1
- timing belt
- engine swap
(and 2 more)
Tagged with:
EA82's do not have a rolling element in contact with the camshaft. It applies to all of them. It also applies to EJ22's except 97+ as well as all EJ quad cam engines up and including current model year. I have seen pitted cams from junk oil on many 2000+ engines. Quality, clean oil is not optional on Subaru engines - at least not for long. GD -
You dont need to add zinc if you run high ZDDP oil. Amsoil 10w40 premium protection for example, or z-rod, or some of their other products. Yes they are flat tappet cams and yes the lifters will be damaged without sufficient ZDDP. Had to have a set reground not long ago because of wear. Oregon Cam Grinders does them - $5 per lifter. GD -
They are not available. You will need to have them reground. GD -
We replace the crush washer with a new copper one every time. Cost less than 1/3 of the dealer unit and just as effective in my experience. Not that its a great savings but we buy them in bulk. The dealer ones come in little plastic bags one at a time - takes forever to unwrap them all. We buy them in boxes of 50. Time is money and fiddling with 50 little baggies.... GD
At that point, anything you do should involve forged pistons. Just swap in forged pistons, and replace the head gaskets. Dont really need a new bottom end. We do this all the time. We have good luck with JE pistons - they seem to slap the least. 2618 alloy. The Blouch 18GXTR with the 8cm housing is the sweet spot IMO. Makes about 370 wheel. GD
You need tuning, and that isnt going to happen on the stock ECU. What experience do you have with fuel injection and how comfortable are you with ugly wiring projects? This will largely dictate your options. You also really need to lower the compression.... Subaru engines dont handle detonation AT. ALL. The first time you run into any amount of detonation while tuning will result in squirting the rod bearings right out of it. The factory cast pistons are weak and you will shear off the ring landings if you push them. Ultimately - just figure on the learning process taking at least two to three engines before you figure it out. Everyone that gets into tuning Subarus wrecks about three engines give or take. GD
I've never seen it. And I do about 2-3 head gasket replacements per week for the last 10 years. I would have to say, without more proof, that either they were replaced incorrectly and you haven't got the records, or it's a mis-diagnosis. Given the number of these I've seen I would have to say it's virtually 0%. And every time I think I've found the outlier that would prove otherwise - some idiot has been into it and screwed it up. EVERY. TIME. GD
