435
Discontinued Bushing HELP!
GeneralDisorder replied to PMA's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hello? McFly? I said YouTube.... search. Like a million videos on this. GD -
The ignitor on the firewall is the transistor(s) that switch power to the coil pack to fire it. Just match up a few wire colors with numbers and you will soon get a picture of the numbering scheme. It should take no more than identifying colors of each corner wire and the wires adjacent to them then determining the pinout numbers from there. Ignore the labeling on the connectors. GD
Crank pulley repair
GeneralDisorder replied to mykal's topic in BRZ and its Sister the Scion FRS/Toyota GT86
This is definitely chain cover pull. That sucks. GD -
Make your own with urethane. SuperPro might have some EA bushings.... still easier to get some smooth-on two part urethane and make a cardboard form. LOTS of YouTube videos on the process. GD -
Optima is junk now - sent production to Mexico. LOTS of stories of premature failure in recent years. Terrible quality control and they switched away from pure lead to lead alloys. Crap IMHO. Odyssey is where it's at. They (Enersys) designed the spiral core that optima uses and their new flat plate design is 15% more dense. Their design life is 12-15 years. GD
- 17 replies
- 1
- old
- AGM battery
(and 3 more)
Tagged with:
Yeah I still think you need to try jumpering the ignition switch circuit so that it is sending power to the hot in start/run circuit all the time then try cranking it. Also sometimes with these ignition switches.... turn it very slowly till it just barely touches the start contacts. Don't push hard on it, and it might work. The connector pinout is in the FSM you can download from sl-i.net.... GD
Yeah it's not too much of a concern really. My Trans Am originally had the fan set points set to 222 and then didn't kick on the secondary fan till 243. Higher temps result in more complete combustion and fewer hydrocarbon emissions. One of the MANY reasons these engines have always needed synthetic. Amsoil synthetics can handle sustained 350 degrees with no damage. Definitely do run a 5w40 though. Viscosity decreases with temp. I run nothing but 5w40, 10w40, 20w50, or 15w50 depending on stock, modified, season, etc. GD
Put a 90 bend in it, and attach it to the carb mounting stud. GD
Phase 1 includes the dual cam engines like the EJ25D and they do NOT share intake patterns. Phase 2 is entirely different, turbo's are different, and besides that due to entirely different idle control systems you can't interchange any of the manifolds easily between phases anyway as the manifold must match the heads but also the ECU's preferred idle control design. GD
Correct - the small lead that runs to the PCM comes directly off the 10 AWG solenoid wire. But it's an internal splice inside the harness and as Fairtax mentioned it is completely inaccessible, buried behind the dash. I doubt you have a fuel pressure issue - the PCM has no knowledge of fuel pressure and would continue happily pulsing the injectors without any fuel at all. What you seem to have is either a slow cranking speed coupled with no start signal to the ECU, or a loss of 12v to the ECU. Did you say that you had solid 12v at the injectors? As for the ECU start signal.... they will eventually struggle to life without it if you turn the engine over fast enough, but the ECU gives additional fuel and changes timing to allow the engine to easily start at the ~300 RPM cranking speed. Without that signal, it may be difficult to start and the slower it cranks the worse that would become. Also typically harder to start when cold as the ECU's only inputs are crank and cam signals and without the start signal it just starts seeing engine rotation - it may not idle up and provide cold start enrichment. GD
I would have to consult the diagrams. Download the manual here: https://sl-i.net/FORUM/showthread.php?18087-Subaru-Factory-Service-Manuals-(FSM)-Every-Model-USDM-EU It is not sufficient to just turn the starter - the ECU also needs a 12v signal from the starter solenoid lead telling it you are cranking the engine. GD
