NEED ADVISE about Class 3 Hitch - 98 Legacy Outback
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood advice! I've been all over the west and the east coast and even Canada but never had the pleasure of TX. Now I have to drive basically through half of it in a couple days. Fortunately the 1079 without the taller MRAP gears and the CAT engine flashed for more power has a max speed of about 58 (74 after those upgrades). I will observe speed limit signs carefully though! GD
Talk to me about the 2013 oil consumption problem.
You replace the short block. The reman FB short blocks are like less than $1800 from Subaru. The FB's don't come apart like an EJ and if you try to get into changing rings you get to pull the rod caps and open up a can of worms and own the warranty yourself. The dealership changes the short blocks also. The reman blocks come with a 3 year / 36k warranty from SOA - though they do not technically sell these to individuals except at the parts departments discretion and warranty if you aren't a shop that can "professional installation" on it is a question mark. Depends how much the parts department likes you (directly proportional to how much money you spend with them annually). Used replacement engines for the FB25 cars are stupidly over-priced from the junk yards and you don't get anywhere near the warranty you get with the new Subaru blocks that have the updated rings. GD
Couple Q’s about EGR and 2000-04 Legacy 2.5
GeneralDisorder replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell on the Forester there was a change from the 25D in the 98 to the 253 in the 99. Those are electrically incompatible and the intake manifolds won't swap either without making custom manifold adapters. Or he may be referring to differences in the crank and cam triggers if he got an engine from a Legacy that was speed density...... it's hard to tell but there's absolutely ways to make just about any combo work if you want it bad enough. If you don't have a large enough tap handle you can sometimes use 8 point sockets or there's always the crescent wrench or pair of box wrenches in a pinch. I've done them without a tap handle. Again - it's aluminum so just go slow and careful and you'll be fine. GD
Limited slip front?
I've done it a couple times on the EJ 5 speeds. It's not difficult. GD
GeneralDisorder replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes there's an exhaust valve stem/guide after you break through into the port. Not an issue just go till you break through and stop. GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThat's just it - there is no frame. The unibody is made from folded sheet metal that's slightly stiffer than wet tissue paper. Suspension has no bearing on what will begin to tear the bolts out of the wet tissue paper that is your "frame/body" GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOh wow - didn't even think of that! I'll have to ask my guy in TX about that - he has a military museum down there. I wouldn't think they would mess with a camo LMTV with Texas plates but maybe? It is supremely off-road capable so would be uniquely suited to border crossing in the middle of nowhere...... GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell..... Looks like we are headed to Tuscon Arizona and up through Nevada and Vegas this trip not up to Colorado. Not sure where you're headed but you're welcome to tag along at our slow speed if any part of the route brings us together. GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYep. Arrive in Houston on Oct 1. But remember - truck only goes 55 top speed. Effective final drive ratio is around 7:1 GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne possible route does take us right through it actually. I'm still doing research on which route I want to take. The truck, as delivered to the government, has a top speed of about 50 to 55 so I'm taking that into account. It's also tall at about 11.5' GD
GeneralDisorder replied to moosens's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI buy most of that stuff for my shop through a local tool company but being you couldn't find one..... and unfortunately things like electronics and a lot specialty stuff you can really only find online now. Used to have Fry's Electronics, and other places but they all went away GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOctober 5th or 6th. Depending on how many days the drive from Houston back to Portland takes me.... GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNissan's are a pain in the neck. If you get anything get a square body GM or a Toyota..... Or one of these (my preference): GD
1990 legacy Ti Type S engine swap options
GeneralDisorder replied to Iller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe EJ18 is quite reliable. On par with the EJ22. GD
GeneralDisorder replied to Iller's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnything you want with enough swapping of parts and/or fabrication. GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust buy whatever hitch and cut/weld in the receiver tubing size you need for the carrier. You might need heavier rear springs if you also have any gear but KING springs makes some. GD
GeneralDisorder replied to YnotDIY's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't do that. Get a truck. GD
Vehicle Speed Meter
GeneralDisorder replied to 700's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah but 2x the price of the part is still less than $50. And in this case "used" is no kind of option in my experience. GD
Vehicle Speed Meter
- Vehicle Speed Meter
GeneralDisorder replied to 700's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGo to the US Amazon not the derp Canadian one. Here in 'Merica the link shows 7 available. GD- Vehicle Speed Meter
GeneralDisorder replied to 700's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOrder a new adapter from Subaru. Very common failure. https://www.amazon.com/Subaru-Automatic-Transmission-Speedometer-737411752/dp/B01MG60SP2 I wouldn't trust a used one. Most of them look pretty beat to he11. GD- Should I buy an 04 Subaru Legacy?
12 Impreza is going to have the bad piston ring's issue (severe oil consumption), and the early CVT valve body/torque converter issues. Both of which add up to more expense than doing the HG's on the EJ's. Personally I wouldn't buy ANYTHING made 2005 or newer. Too much complexity and closed-source intellectual property issues. Right-to-Repair..... etc. Stay the F*CK away from all of it is my recommendation. If you are mechanically inclined just slide on over to the old school GM platforms. At least you can get schematics and repair parts. Have the 2004 inspected. If needed replace the HG's with 770's and use proper Japanese timing components and a new radiator. Change all the fluids. Should go another 200k with proper maintenance. GD- Valve body replacement to solve torque bind
GeneralDisorder replied to Buhas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCertainly could be that the grooves are hanging up the apply piston from engaging AWD - just as easily as the grooves could keep it from disengaging. Probably depends on driving habits that led to the grooves in the first place - the auto's are basically 90% front wheel drive till they sense wheel slip so one could envision a vehicle that is driven very carefully and rarely has occasion to engage AWD. The grooves would form in the unlocked position and may hang up trying to engage till the duty-c ramps down to a lower state where enough pressure is held on the piston to overcome the sticking in the grooves. In all cases I'm aware of the duty-C solenoid dumps line pressure away from the lockup piston - so that a failure of the solenoid will result in full locked 4WD operation and the driver will experience really severe torque bind. If installing the fuse alleviates the problem then the duty-C is working. In such cases the torque bind is almost universally drum wear groove related except in rare cases where the vehicle has been run with severely different tire sizes or amounts of wear which can result in a burnt up clutch pack. New drums can be bought for some models - we recently got some new ones for a 2006 Forester XT where the customer wanted new rather than dressing the grooves. Some others may be NLA. Typically do have pretty good luck just filing down the edges of the grooves - usually this results in a 90% reduction in toque bind symptoms. On the older models prone to Duty-C failure we typically will replace the solenoid while in there. I will usually buy a clutch pack just in case but 90% of the time I return it. Have also seen a few (90's cars) with Duty-C driver failure inside the TCU. This is rare but shouldn't be discounted. They may or may not throw a code, but in the few cases I've seen the Duty-C solenoid and wiring checks out but the code is present and changing the solenoid doesn't help. Swapping out the TCU fixes these cars. Haven't tried going board level and checking for cracked solder joints or bad driver MOSFET's but given the age it's certainly a possibility. GD- Valve body replacement to solve torque bind
GeneralDisorder replied to Buhas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's not the solenoid or the clutch pack. It's the drive and driven drums that hold the clutch pack. They have grooves worn into them from the clutch plates and even though there's no pressure on the apply piston the clutch plates are jammed together because they aren't free to slide apart - they are wedged into the wear grooves in the drums. GD- Recomendations for an OBD scan tool
GeneralDisorder replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNothing in that price range will talk SSM protocol. http://blog.obdii365.com/2019/06/26/freessm-vs-ssm-3-vs-ssm-4-subaru-select-monitor/ GD - Vehicle Speed Meter
