435
Yeah he didn't replace the bearing. Which is silly not to do as a 6203-2RS is only like $5 and you can't replace the front lip seal without pulling the shaft/bearing assembly. Don't really need a press - totally overkill for such a tiny little thing. I use a vice with some soft-jaws and some carfully selected sockets. I have a 20T shop press and I wouldn't even consider using it on this. If I had a whole assload of them to rebuild then I would setup an arbor press to do them. Just too small and the forced involved are trivial. I have done about half a dozen EA and EJ pumps - note that there is quite a variety of kits and they aren't the same from Legacy to Impreza even in the same year.... nor are the EA pumps quite the same. Some don't even have the same size bearings - some are 6202's and some are 6203's. So you want to verify what you have - especially if any junk yard pumps have been involved. GD
With that many miles on it and the lift/tire stress - I question the replacement of the rear diff at all without also splitting the case and checking everything out. When the 5MT's fail - it's the rear input shaft bearing that goes. If you are going to replace bearings then I highly sugest you split the case and replace that one. None of the other bearings really matters if you are going to leave that one with 200k on it. They won't be the first to fail and typically they are just fine even after a tranny is nearly destroyed inside. Inspect them. Blown them out with solvent and spin them - if you feel any roughness then replace. But don't just replace a bunch of bearings that aren't failing for no reason - especially when the main transmission has 200k on it. Chances are that they are fine and they don't need to be renewed because the rest of the tranny will amost certainly blow up first. GD
low compression in one cylinder
GeneralDisorder replied to ForrestM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the wet test only brought it up to 90 then it's got valve sealing problems. Possibly a burnt exhaust valve. The rings are sealing from the oil but the valve can't and continues to leak. Unlikely to be a head gasket - those don't typically show up on compression tests. Also it would be having other issues related to the cylinder compression escaping to where it should not be. Why wasn't the compression test followed up with a leak-down test? Wet/dry compression test is just a pass/fail for the rings. The rings passed that test - now you need a leak-down to check the intake/exhaust valves. GD -
I agree with letting it sit all weekend. So far we have had the best luck with the first cylinder I treated which sat overnight with a 50/50 mix of ATF and Acetone. That cylinder (#3 pass. rear) came up 40 psi and has stayed there. Both of the further treatments I have done to the 90 lb cylinder (#1 pass. front) were only able to sit for about 3 to 4 hours before I had to put the car back in running order. That doesn't seem to have been enough to really accomplish anything. I think patience is the key. And possibly the application of some air pressure to the cylinder. About 10 to 20 psi behind the solvent mix and just let it sit over night like that. Should yeild some results I think based on what I have seen so far. Overall the engine has smoothed out a lot since we first started it but the oil consumption is not acceptable. GD
Is this an accepted practice ??
GeneralDisorder replied to okie bill's topic in Old Gen.: 80's GL/DL/XT/Loyales...
EA81 heater core lines are two-peice with a coupler in the middle. Those don't look like stock couplers though. They probably rusted out. You should go to the dealer and get all four hoses and new couplers. GD -
I have a customer with over 270k - uses Mobile-1 at 5k intervals since he bought it new in '90. First production year - slam dunk for reliability. Superb engine design and implementation. With the proper maintenance they can easily go half a million. You could use one of his valve covers as a dinner platter.... or meatloaf tray :-p. GD
Are you refering to the small line that opens to to a squarish port under the carb base? That is the carb base-heater port. It flows coolant to heat the carb - it's basically an emissions trick. Hot air burns cleaner. It's typically blocked when installing a Weber as it tends to leak from ill-fitting weber adaptor plates. GD
Beautiful hatch! Do you have many of these in England? I was under the impression that Hatchback's were rare in the EDM world. I know I've heard there's less than 10 of them in Austrailia and I has assumed the other European markets were similar. I think your's is the first picture I've seen of a hatch from England.... I'm a much bigger fan of the hatch than the Brat personally. Did you see the aluminium rear window latches that a friend and fellow board member made not long ago? He may offer them again. Best way to solve the weak plastic handles.... GD
No - auto or manual does not matter as long as it's a 25 spline inner and NOT an XT6 axle. Those use a totally different outer joint interface like a Legacy, etc. Again - avoid NAPA axles - they are reman garbage and you will regret the purchase. Get an axle from a retailer that sells NEW axles. I get EMPI or another house brand from my local import parts supplier for less than $60 - lifetime warranted. GD
The valve is designed to sense engine temp and to open or close an internal gate between the two vacuum ports. It is a way of turning on or off a device that is vacuum operated based on engine temp. For example - the EGR valve will only be enabled after the engine has reached operating temp. This valve interrupts the vacuum signal to the EGR valve (or whatever) till the proper temperature is reached. It does not itself supply the vacuum - only regulates if it's allowed to flow or not. Therefore it does not need an opening at it's base - just an appropriate metallic interface that facillitates the thermal transfer. Typically the bottom of the valve will be in contact with coolant..... GD
And - just to insult the counter guys at NAPA - their part number for a 25 spline turbo axle is: NMD 953109. Right off their own web site. Idiots I tell you..... To find it you have to lookup parts for an XT and then drill down to CV driveshafts..... it's right there in the description of the part which spline count it has. GD
front wheel drive doesn't work!!
GeneralDisorder replied to Skysm182's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If the inner axle joint cup (the "cylinder thing") is spinning but the shaft is not then you have a bad DOJ (Double Offset Joint). Not sure how you could have done that while replacing the components you mentioned but if your description is accurate then clearly there is a problem inside the DOJ. Pull it apart and inspect. GD -
Any interest? OEM EA radio ponderings
GeneralDisorder replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Not since Art retired. It's not the same with George. GD -
The torque cams don't really make it sound any different except at idle - it's not a V8 type of lumpy idle like you think though - it sounds more like..... it's just not tuned very well at idle. Sound a bit like it's got a vacuum leak actually. Remember this is a 1.8L engine. You are comparing it to 5.7L and larger V8's that have twice as many cylinders. Subaru's have 4 and a lumpy idle on a Subaru just sounds like it runs crappy. Not enough cylinders to get the lumpiness that you desire. SPFI pistons will increase the compression ratio to 9.5:1. Decking the block and heads can further increase the compression into the 10:1 or 10.5:1 range. EA82 intake can be used for somewhat better flow. Port and polish the heads. Exhaust should be upgraded after the header to 2". Those three mods alone - along with a good tuned Weber can get you close to 100 HP which is a decent increase over the stock 73 HP. Of course - all of this will cost more than doing an EJ22 swap - which is 135 HP without changing anything on the engine. And a frankenmotor (EJ25 with EJ22 heads) is about 180 HP. You'll never come close to the performance-per-dollar that you will find in the EJ's with a modified EA. GD
I wasn't aware of the AM reception issues with our new-fangled digital sets so if that's your poison I appologize :-p. I pretty much listen to FM rock or the multiple GB's of MP3's on my phone.... and being that I'm not a sports fan.... AM is pretty much what I plan on tuning into for the Zombie Apocalypse and as such I have a one of those emergency units with a hand-crank . GD -
Lots of folks have done cams in EA81's. It's nothing new. Mostly they go for the torque profile which helps the engine breathe at low RPM and improves torque across the RPM range. It is very unlikely that your engine is salvageable after a cam breakage event - you would be best served by just picking up a used engine and dropping it it. GD
Yes - Delta camshaft can regrind a cam in one of several different profiles depending on your intended usage. But you need a good used cam to send them. And: No - you most likely cannot get a new cam at this point. In any case you wouldn't like the price - likely it would cost more than a used engine. I really don't think you understand what's involved in changing the camshaft - it will require COMPLETE dissasembly of the engine. Down to pistons, rods, and wrist pins. ALL the way down. Every nut and bolt. GD
Yeah - the tape deck input is on all the EA81 radio's - tape deck's were an option in those years. The input jack mod has been done quite a few times - at least two threads that I can recall seeing. Personally I prefer the new shallow mechless decks though - an a decent job of installation of course. GD -
Pretty sure it will plug in - if not directly then using the harness off the old SVX tranny. But you will either want to swap the front diff over to the new tranny or go with a custom TCU - the final drive on the SVX is a LOT different than that 4.444 outback tranny and is going to cause shift point problems if you try to use it and the rear diff from the outback without a TCU reprogram. Maybe the TCU from the Outback would work? I'm sure some combination will get you down the road. And a 4.444 final drive SVX is a sexy idea indeed . Though a 5MT swap is even better. GD
