GeneralDisorder
    439
  1. The "rythmic grinding" is definitely a wheel bearing by your description. You also need to replace your cone washers - they have been damaged by driving with the axle nuts loose. GD
  2. If tapping the throttle makes the rpm drop part of the time then you have a freying throttle cable or worn out throttle shafts in the carb. Unfortunately the ECS light you mention means you have a feedback (computer controlled) carb. You will either have to pickup a factory service manual and get aquinted with its rather complex nature or consider swapping out the carb for a Weber or fuel injection. GD
  3. Any ECU codes present? Sounds like the ECU is cutting off the injector pulse for some reason. GD
  4. They should not be associated in the harness, no. GD
  5. Yeah - either it's not as far off as you say, or something is wrong with your speedo head I would say. GD
  6. Yeah my dealer said she could order them but had no gaurantee that the order would ever be filled. There are none in the US at this time. Here the price is about $104. Also only the "left" one is compatible. The "right" one is the one I mentioned that has the extra extened spline on the end. So you would need two lefts to make it work..... GD
  7. Looks like you probably have a short to ground somewhere...... the weird part is that the high beam switch *should* be grounding the high beam bulbs - which should provide enough resistance to keep a direct short from occuring. You don't have anything strange going on with your inner headlight (the high's) wireing do you? GD
  8. Yes - you are correct. I was merely informing the OP that it's possible - I revised my first post to reflect the vague nature of my knowledge of how high it would go should he do it. GD
  9. It is best to pull the engine, but it can be done with some difficulty without pulling it. The work itself is not challenging if you work slowly and carefully. Mostly it's cleaning and prepping for new gaskets that takes the most time. You can rent an engine hoist for very cheap - probably in the $25 per day range. Thus you could rent one on Friday morning, pull the engine, run the heads down to a machine shop to have them resurfaced, and then put it back in again on Saturday. Rental on the hoist will probably be a minor expense in the scheme of things - $50 for a couple days. Pulling the engine and putting it back in is relatively easy. I can leisurely pull an EJ engine in 1.5 hours. If I'm trying to show off probably 30 to 45 minutes if nothing strange crops up like a stuck lower bell-housing nut..... I don't like to sweat and throw tools around like a mad-mad though so I usually take my time and organize parts/tools as I go to maintain a clean work area, etc. GD
  10. I suppose it depends on how many splines you skip. I remember a local guy here a few years ago used that method on his wagon and it was slightly higher than the 3" blocks he had in the front. Perhaps he skipped two splines on the reclock. I only saw the end result - I wasn't present for the actual procedure. GD
  11. Only one of the stubs from the early VLSD is the correct unit. The other will not work as it has an extra splined section on it. That part is about $100 each from the dealer and they don't have any in the US which means it's probably not availible at all. GD
  12. Any radiator cap should do. Cost of a HG change - if you are not doing it yourself - will very likely be approaching the value of the car. $1500+ at the dealer. Independant shops will be closer to $800 to $1000. If you do it yourself it can be done for around $100 in parts if you are reusing the timing components, etc. GD
  13. Snout repair is sometimes applicable. I have gotten away with just filing down the rough transitions and sanding the snout smooth on more than one occasion. A liberal application of grease helps also. Usually they aren't so bad that you can't work around it if you are careful. GD
  14. Converting is fine and dandy if the measureing device has enough inherent resolution to convert - when going from standard to metric it's important to remember that a thousandth of an inch (.001") is still over 2.5 hundredths of a millimeter (.0254 mm). Since most everything in a Subaru engine is measured on the hundredths of a mm scale.... having a Mic. that reads in thousandths of a mm is preferable for accuracy and simplicity. The shims for valve adjustment are availible in .01 mm increments (or was it .005 mm increments?) in any case it's just easier to stay metric the whole time. It prevents errors from creeping into your calculations. GD
  15. Sure - 6207-2RS is the sealed bearing. But it's not a perfect solution. Especially for a lifted off-roader where you should really be running 7207's (which don't come as a sealed variant AFAIK) for maximum load handling capability . GD
  16. Nope - not without making them yourself. None of the stock springs or struts will lift the front. The rear is easy - you just clock the torsion bar down a spline or two - its a "suspension" lift and can be adjusted with the adjuster bolt and how many splines you move the trailing arms... But you better also drop the diff if you don't want to break axles and you will have to go to the Rancho shocks. The front must be lifted with blocks on the stut towers, or strut tube extensions.... etc. GD
  17. For EA82's the answer is yes. For EA81's there does not exist a stock axle that will match this combo - you have to build your own. GD
  18. '99 was a bad year for center diff's. I've seen/heard of quite a few failures. The last one I replaced - the spider gears were so far gone in the center diff that they demeshed and the car wouldn't move. Made some really, really aweful noises. Center diff was the *only* problem with it. Another member here is using that transmission with a good center diff from another '99 transmission with a broken reverse gear tooth. GD
  19. They look expensive from their web site - but I'm used to NW prices. I get EJ22's for $450 with 12 month warranty's, 5MT's for $350, and 4EAT's for $250 from my local yard - all tested and warranted. My machine shop does rebuilt EJ25D's for $1295 with core....... GD
  20. Any 90 through 94 *Legacy* (Not Loyale's) ECU will work. AWD/FWD and automatic/manual don't matter. The ECU doesn't care about the former, and the latter is determined by a ground pin on the harness not by the ECU itself. If it were me I would open the ECU up and see if it's just a bad trace or solder joint or obviously burnt transistor/cap. The Japanese solder tends to corrode and shrink over time and that is the biggest cause of electronics failure among Subaru's, Honda's and Toyota's. Mitsubishi just uses junk caps that leak and burst all over their boards..... lowest bidder components GD
  21. 85.... maybe 90 with a good tail-wind and a Weber. 750 rpm. GD
