lots of engine vibration
I agree - check plugs/wires and the coil resistance. You can check to see how much each cylinder is doing at idle simply by pulling the plug wire off. If it makes no difference then you have found a cylinder that is not fireing either due to ignition system issues, lack of fuel (vacuum leak) or lack of compression (valve timing?). GD
Clutch slave cyl washers. No one list them...
GeneralDisorder replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell - there's a couple rules I've found that will help the first-timer with bleeding the new slave. 1. The pedal doesn't fully actuate the MC piston. You can disconnect the MC at the pedal very easily and actuate the piston by hand. Note that you will feel a GREAT deal of resistance and it may feel like you are not even moving it. You have to push HARD. This is how I typically get the first few pumps done because it's the most effective a quickest method to get the pedal operating. 2. The system is unlike a brake system where you can pump it as fast as you like durring bleeding. When bleeding the clutch you should apply steady, even pressure to the pedal on the downstroke (open the bleeder just after you begin to apply pressure) - you have to take "control" of the pedal as it's spring loaded - manhandle it into doing what you want. Just before it bottoms out have your assistant close the bleeder. Then pull the pedal back up off the floor (it will stick there the first few times). Then you WAIT. You must now wait about 20 seconds for the MC to refill it's empty fluid chamber. It sounds weird I know - but if you don't wait for a bit between each stroke and open/close the bleeder at the right times you will spend DAYS trying to get it right. Hope that helps. I had to figure this out the hard way and after doing half a dozen of them I have my *technique* for it now..... but it IS pain in the neck no matter what. I don't think I have done one in under an hour yet. GD
GeneralDisorder replied to Rpm90001's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThey are just copper washers - I have reused hundreds without issue. If you are really anal about it you can polish the old one's with a peice of glass and some 220 grit. GD
EJ Swap Wiring question...
No - that *shouldn't* be able to cause the tail lights to be on. The only thing I can think of is that you got some plugs swapped around under the dash dealing with the lighting system.... GD
88 gl-10 turbo. ej swap??
Not really - the only benefit is that it's already got the fuel pump in it that you need so you don't have to swap that over or change to FI rated hoses. Otherwise it's the same as any other EJ swap. GD
Where is your EJ harness getting it's power from? What did you touch on the stock harness that might have caused that.... Hard to say. I've never experienced that issue before durring a swap. GD
EA81 Oil Pressure
I think you need to seek some professional assistance with your electrical issue. It sounds as if your wireing is dangerously close to melting either due to high resistance at a connector or because of improperly fused aftermarket wireing..... there's just no way to tell without being there. Your symptoms are not typical. There are board members in your area - reach out and possibly someone can take a look at it that knows their way around a DMM. GD
EA82T into 1980 GL
It's not a direct bolt-in. First, the EA82T is a horrible engine. So bad it should never be swapped *into* anything but a dumpster. Second - it will not bolt up to your transmission because it uses the newer "side-starter" bell-housing as opposed to the top-starter housing of your EA71 and associated tranny. You will have to change the tranny as well. Third it doesn't fit between the frame rails of the EA81 chassis without removing a small area on the driver's side at the rear of the valve cover. You will have to cut out a section of the cross-member and reinforce it to clear the down-pipe, you will have to move the hill-holder, and cut down one of the bleeder screws on the brake master cylinder..... All-around it's a bad idea because it's just as much work as an EJ swap or an SPFI swap and for all your hard work you get a POS engine that makes less power than a non-turbo EJ. LAME. GD
one more time please weber carb for 87 brat
One is for the EA81 manifold, and one is for the EA82 manifold. GD
84 4WD Wagon new daily driver with future EJ swap
Interesting indeed - think you could point me to an auction for one of these? Is that a Momo pattern? GD
05 turbo baja auto, had one day now bad turbo?? wtf
You can't see down the oil filler - it's twisted around into a strange shape because of the DOHC head arrangement. Look for evidence of driver's side valve cover leaks - the turbo cooks them. Yes they have decent HP - I think it's around 220 or so. They are very "peppy" engines. Not a lot of turbo lag. They used a smaller turbo to keep that to a minimum. MPG will be..... frankly it will be horrible. . If you are looking for a powerful, fun ride - the EJ255 is a great engine for that. If you are looking for mileage - lotsa luck to you. I beleive the rating for them is somewhere around 18 to 24. If you enjoy turbo power you will be lucky to see a consistent 18. Mileage is not why you buy one of these. My '91 2.2 turbo (slightly modified) is lucky to get 16 mpg with the way I tend to drive it. Oh - and besides the crappy mileage you MUST run premium as well. Further sticking it to your wallet. GD
EJ20T 2L into Brat
I think what would likely kill a D/R 5MT under the give scenario (200+ HP) is the tendancy for people to get frustrated with the crazy wheel spin and drive it around in 4WD Hi all the time on dry pavement just to prevent the wheel spin and give them that desireable "launch" ability. I agree that if driven with sanity and if the 4WD is only used on slippery surfaces, etc.... probably would be fine for a long time. But "boy racer" here will not drive it like that - he will drive around in 4WD Hi all the time and that will eat up the tranny in short order. 200 HP clutch dumps in 4WD Hi WILL kill the D/R. GD
It really needs to be stressed that if the engine wasn't run with synthetic and regularly maintained - just walk away. The whole turbo return banjo-bolt screen and the AVCS valve banjo-bolt screen issue is just a symptom of poor maintenance and incorrect lubricant. The screen was put there to prevent blown-up turbo bits from getting into the engine - but proved to be more trouble than it was worth because people here in the US don't seem to understand the need for synthetic oils in turbo-charged engines that experience localised high oil temps that cause conventional oils to sludge up and burn. This is the same basic problem with the VW 1.8T (though it's much more widespread and worse on the VW's). I have a customer with an '04 FXT - I just had to clean out the AVCS control solenoid on the driver's side because it was sticking and causing the intake valve timing to not retard properly and the idle was all F'd up. I also replaced a valve cover gasket for her and the inside the of the engine is DISGUSTING at 115k miles. She has all the records of frequent oil changes AT THE DEALER because she bought the car with lifetime lube and oil. But she never popped for the added cost of synthetic and now I'm afraid it's only a matter of time before that turbo and her engine just gets so sludged it up can't lubricate itself anymore. GD
Stereo dash mount kit
That's the kit I mentioned - its for a two-knob cassette deck. It will not work for a DIN stereo. GD
anyone help, please!
You've got to take the initiative - if you don't have money then you will have to trade your time, labor, etc to either get some money or barter for parts. The barter system is not dead and you have this forum, craigslist, etc.... you live in a Subaru rich state.... Someone has a derelict Legacy that you can "earn" somehow - you just have to want it badly enough and shout about it loud enough. I have got at least half a dozen cars over the years for dirt cheap - including a 78 wagon for $1, a '92 Legacy for free, '91 Legacy for $200, and an '86 D/R sedan for $100...... ALL of which I DROVE HOME. Why? Mostly because I'm loud, memorable, and people know I like Subaru's and will "rehome" them like lost puppies. Post in the wanted section - make a craigslist posting - make flyers with crayons.... someone has what you want and needs yard work. I've been where you are - barely able to afford the gas to get to work. Somehow I managed to get the parts to get things done. GD
Pass if it wasn't run with synthetic oil and had regular oil changes. Pull a valve cover off - if it's not immaculant inside there just walk away. These have issues with the oil sludging up and destroying turbo's, gunking up the AVCS control solenoids, etc. There's TSB's about this stuff. Don't buy any turbo that doesn't have excelent maintenance records and/or wasn't run with synthetic oil ONLY. GD
Pouring oil from timing belt seal?
You don't need the primer. That's just a copper spray.... .050" is a HUGE gap..... questionable to even use parts that fit that poorly..... think SBC oil pan . For a water pump you are talking about a machined flange against another machined flange. There should be .001" or less gap to fill unless one of the robots was drunk or on strike that day. For the oil pan..... well I hear you on the gap being probably larger there. Probably not much more than .005" in any one place though. I recently used Anaerobic on a Nissan 30DE (300 ZX) oil pan and I've been under it way too much and the oil pan (and everything else for that matter) is perfectly dry. . I would not hessitate to use the anaerobic sealant for an EJ oil pan. I use it for oil seperator plates and such all the time. I have actually completely replaced 100% of the liquid gasket needs on Subaru's with it and it has not failed me yet. I like it because it has an infinite shelf life and won't dry up if you leave the cap off. Plus cleanup is less messy, and it is just generally a friendlier product to use. GD
Subaru EJ22 internal EJ25 ?
The sound it makes has everything to do with the exhaust design and much less to do with the actual performance of it. A video just wouldn't do it justice. GD
Why doesn't he want you doing wireing? You aren't going to learn if you aren't allowed to screw something up - hell the engine is freakin shot so what's the big deal about hacking into the wireing a bit? And if he knows how to do it better than you then why isn't he helping you? The EA82T is a pile of steamy poo - if this doesn't convince him of that then I don't know what will. A little wireing is no big deal - especially when you stand to gain so much reliability and power. You don't even need to do the EJ22T - just a non-turbo EJ would be a lot more power than the EA82T ever made..... And besides all that - there doesn't have to be any modifications done to the car's wireing. You are just adding a fuse block, and a piggy-back harness. The car *could* be put back to bone stock if you do it right. Go to the junk yard, pull a harness, and strip it down yourself. Then bring it to your grandpa and show him that you have done the reasearch, stripped the harness, and know exactly what needs to be done. Take the initiative! GD
Ok I'll rephase that - no one makes the "kit" that was intended for EA81's anymore - at one time Metra did make a kit to mount an aftermarket two-knob cassette deck on the EA81's..... that's it and it's no longer being produced . The commonly used (and ugly as sin) kit is for the EA82's but requires hacking the hell out of the radio console and loseing the ashtray, etc. You can roll your own radio install using whatever you like but if you want it in the center console and you want more than a two-knob unit, and you would like it to look decent.... you will have to get creative. Here's the last one I did: http://www.ultimatesubaru.org/forum/showthread.php?t=115379 GD
EA81 Oil Pressure
Check the resistance of the sending unit both when it's at rest and when the engine is started and running. Watch what the resistance does - it should start out higher, and drop as the engine starts and the oil pressure rises, etc. GD
How much for rebuilt carburator for '83 GL wagon?
You are better off buying a reman carb than paying a mechanic (if you can even find one that could/would do it). Either that or consider swapping over to a Weber or the SPFI fuel injection system. GD
I retract my former analysis. That engine is toast. Ah..... the wiley ways of the EA82T. They sure have a way of sticking it to ya don't they? . Sorry about your situation - I think I warned you about this engine didn't I? I would say "sorry about your luck" but it's hard not to be unlucky with that engine. :-\ It takes a very special type of person to rebuild an EA82T and make it last. Sadly those of us that could do it have no desire to do it since we are awash in EJ parts. I counted just a few days ago and I have like 5 EJ22 short blocks in my shed.... not to mention a pile of EJ25D parts besides. GD
Automatic to manual on 96 Legacy Outback ?
It's really not worth the effort - just replace the automatic. They rarely fail. If you want a manual it's typically better to just buy one that's already a manual. As far as AWD - all Subaru's are AWD starting in '96. And most were before that as well. Even if you swap to a manual - it will still be AWD. GD
Pull each plug wire, in turn, and see if it makes any differences. It does not sound like a rod knock to me - rod knocks are most audible when under a load - and usually they will make a "back rattle" when you rev the engine and quickly snap the throttle closed. It sounds mechanical and being you just had the engine out.... I'm also voting for something amiss in the bell-housing area. GD
