440
1) Grey 14 pin connector with red and black wire rolled up, labeled 10 amp switched- what does this connect to/plug in to?
2) what connects to: yellow 9 pin connector?
green connector with blue wire?
green connector with black+red wire?
3) what is the single black wire that splits in to 2 with tape wrapped on end?
All of the above are diagnostic connectors. The green connectors are plugged together to put the ECU in D-Check mode, the grey and yellow connectors are for the Subaru Select Monitor (SSM) - it's a dealer tool that provides more functionality than the OBD port and also interfaces to the ABS computer, TCU, SRS, etc. The taped up black wires are factory ground pins that are provided to be inserted into the grey connector to put the system into certain test modes. The rolled up wire is the power for the SSM port. You can hook it up if you like or just leave it alone - it will run either way.
4) Where is the black+red wire that runs to neutral safety? As it is now there is only one green+black wire that is labeled "neutral switch".
That is the neutral switch - it's on the side of the transmission on the manual tranny's. It's a single wire that is either grouded or not grounded depending on if it's in gear or not.
5) The black "tach signal" wire is power for the tach?
Yes - that is the tach signal for the gauge.
6) which posts do fan relay 1 & 2 go to, respectively?
They control the fan relays if you choose to install some. You can use the EA's fan control system if you like instead of the ECU's fan controls. I leave them in so you have the choice. They are merely ground signals to close a relay - you can find the EA's fan relay and use #1 on it. EA's don't typically have a second electric fan so you would have to install one and a relay for the ECU to control.
7) 15a start/run needs to be spliced to ignition switch, correct?
No. It needs to be fed from a 15A fuse that is hot when the switch is in start and run. I sugest using a relay closed by the wire that used to feed 12v to the ignition coil on the EA. That can then feed a fuse block where you have the 15A fuse for the ECU, the 10A for the SSM port, and another 15A for your secondary fan, etc. Painless wireing products makes the fuse panels I use. They come with relay controls, etc
8) starter signal goes where?
One of the 6 pins on the ignition switch connector will be hot ONLY while cranking. That is the start signal. It tells the ECU the engine is being cranked and to adjust fuel and timing accordingly for a quick start at the low RPM of cranking.
9) big black wire with eyelet gets grounded?
Yes - any of the black wires with eyelets are grounds and should find a home under the hood.
Thanks Rick,
No problem - good luck.
-Frank
