Boost
The terms "turn up the turbo" and "kick up the boost" (while being wholely inadequate from a technical perspective) seem to refer to the exact same thing. Thus your statement makes no sense. This would lead me to beleive you have no idea what you are doing. And this list: will likely have "EA82T" added to it shortly. Sure you do. Good - and you should STOP right after doing those two things. You came to an internet forum and asked for advice. That in iteself is enough to infer that you are asking for advice on how to spend money. Otherwise you would just take the car to Chip Foose and have him and his team overhaul it for you. Granted. But you clearly want more performance. Most of us will tell you that the easiest, quickest, cheapest, and most reliable way to get there is to drop in an EJ. Not entirely true. You can destroy anthing if either you wish to do so or you don't seek help/advice from the right sources. Not knowing what you are doing is part and parcel to not seeking proper advice but in itself will not typically destroy an engine that has "common sense" maintenance like oil changes, belts, and hoses accomplished in a timely manner. Most people are capable of finding a shop do to this even though they themselves "don't know what they are doing". Also not entirely true. And especially not true on certain engines.... which the EA82T is one. "required maintenance" in the general scheme of things does not encoumpass what the EA82T usually needs to live. Especially in modified form. Not live long anyway. I'm not replying to your question in that way. I was replying to your response in that way. You are not listening. So that's what you get for not listening. Go ahead and destroy your engine if you like. Don't say I didn't warn you. As yet you have not shown that you have the knowledge or abilities required of that engine. I just call them like I see them. Prove me wrong..... GD
'04 Subaru Forester - Overheating
GeneralDisorder replied to jtrigger's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis really seems like a rotten/clogged radiator to me from the symptoms you describe. Although the car is relatively young in mileage - your location in NY where there is a lot of salt used on the roads will tend to rot out the radiator fins, etc. This could lead to a situation where the radiator is inadequate for proper cooling. I have seen engines from your vintage with similar miles that have horrible corrosion to the cooling system due to lack of maintenance..... it's possible but not common on Subaru's in general. Also - the fact that the shop mentioned the head gasket oil leak AND knew enough to indicate that it's *not* leaking coolant leads my to beleive they are familar with your engine and probably with Subaru's in general. That is a common problem and you SHOULD be using the Subaru coolant conditioner. It's $1.49 a bottle from the dealer here. Since your's isn't leaking just add a single bottle to the radiator. GD
E82 to E82T?
Bad idea to run a high-compression EA82T - they aren't great on their stock compression and adding more just is not a good idea. You could run it MPFI without the turbo, yes. It should run alright with a high-compresison block. GD
Boost
:lol: That POS is going to OWN your wallet. For the same price you could have easily had a Legacy - probably with less miles. More power, no turbo, etc. You'll never make a relible 135 HP like the EJ22. If you turn up the boost it will just fail. GD
Boost
The only safe boost with an EA82T is the stock setting. And even that is pushing it. They aren't designed for high-boost and even people with intercoolers, and other mods designed to support added boost have been largely foiled even running mild increases of like 3 to 4 psi above stock (around 10 psi total). GD
finally picked a direction ej22 it is
I probably have enough parts for you to rebuild an AWD transmission if you wanted to go that route. I swap them out all the time and just built a '96 STi transmission in a legacy cable-clutch case for a Brat. We are installing it right now in fact. Drop me a PM if you want to check it out. GD
Hub/Assembly
GeneralDisorder replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA "race" is part of a bearing - most bearings have inner and outer races in addition to their rolling elements and often a "cage" to hold the rolling elements in the required posistions. With tapered roller bearings you have a "cup" which is the outer race and a "cone" which is the inner race, rolling elements, and cage. You don't replace just portions of these - you replace all components as matched sets. GD
questions about interchanging hubs!
Adaptor plates are not the way to do it. You don't really need a machine shop either. You can get close enough with a hand drill and some patience if you know what you are doing. They are probably hub-centric but many of us are running wheels with larger center bores than the factory rims... they do just fine. Just remove the hubs, mark out your pattern and center-punch/drill your holes. Flatten off the back side for the lug to sit flush and pound them in. This aint rocket science. The way I would do it - chuck the hub up in my lathe and scribe a line designating the bolt circle. Then mark my 4 holes with dividers and go to town with the drill. But I have a lathe..... there are any number of ways to do it without one though. GD
Boost
Sometimes not even the stock boost levels are safe . Don't turn it up - you will just blow stuff up. GD
Kabuki idlers?
GeneralDisorder replied to eppoh's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you look at the bearing seal it will be an NTN bearing. Who cares who made the metal bits that the bearing is inserted into.... I've used plenty of the Kabuki branded idlers from mizumo - they are fine. GD
Questions about a 85 GL-10
Just swap the MPFI heads onto a carb or SPFI EA82 block. They are turbo heads but the compression ratio is 9.0:1 or 9.5:1. Yes they did build the GL-10's in '85 with the N/A MPFI - I have seen a few. They are rare and because of that they are not desireble. That was a single-year engine and has a lot of odd bits that are difficult to find. The SPFI came out in '86 and replaced that engine. GD
Valve adjust?
Doesn't make any sense to me - and I bet if you talked with the actual mechanics they would tell you a different story. I've seen a couple burnt exhaust valves now and the $1000+ repair bill that it comes with (when I do them for people) is not a happy day for them. It's pretty simple logic - valves wear on the seat and face - that makes them tight. They only have to wear .010" to close the gap and then they hang open - they burn shortly after and the engine runs like crap. Complete rebuild on the EJ25D heads runs me about $425 to $500 depending on what all they need. Not cheap to work on. I do have a machine shop that does so many EJ25D's that he will completely rebuild one for $1295 though. Not a bad deal considering the price of a used one is typically $900+. GD
Valve adjust?
You might want to read your owners manual . It's required every 105k - same as the timing belt. GD
EA82T Complete engine failure
That's a pretty typical rod bearing failure. The EA82T is well-known for those. I wouldn't have bothered dissasembling it - that was kind of a waste of time. Hole in block = no salvageable parts. GD
Rebooting a CV axle
You don't dissasemble the outer joint - you slip the boot down over the shaft when the inner joint is off. GD
Valve adjust?
If the valves have never been adjusted..... probably burned exhaust valves at this point. Run a compression test to see. That's their bahavior at first - misfires at lower RPM and then the cylinder will start to fire as you accelerate. The last one I bought had 169k on it and the #4 cylinder had 60 psi due to a burned valve. No shim clearance will hang them open. GD
EJ22 Head Problem - CONFUSED!
The pistons are different between '96 and '97. The single port heads are not the cause of the interferance. The ONLY way to tell if a single-port engine is interferance or not is to look for the solid-lifter/roller rocker setup under the valve covers. In '99 the EJ22 went over to phase-II like the '99 Forester/2.5RS EJ251. That continued till '01 - after that the EJ22 was discontinued from the US market. GD
EA82 rear drums, as rear disc hubs?
Ghetto. Don't try that. GD
Transmission and tcase...
Suzuki tranny and clutch setup is too small. Yota stuff is in the works..... GD
If it has solid lifters with roller-rockers - it's a '97 or '98 engine. All EJ22's from '95 to '98 have EGR if they came from automatic's and all '96 and up will be single-port exhaust. GD
Hub/Assembly
GeneralDisorder replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe bearings and their race(s) come as a set. Buy a bearing and install it - pretty simple. I wouldn't opt for using a press - the hub-tamer type tools are better as they don't put out as much force and potentially deform the bearing pocket in the process. GD
They can be redrilled to a 4 x 120 pattern - it's been done for 4 x 114.3 and even 4 x 100 so I'm sure 120 is also possible. GD
'90 Legacy Engine Swap Options
Don't bother rebuilding it - there's no profit in that. As you have seen they are easy to find and cheap. At most I would just repair the damaged crank nose or sell it to somoene that can for $50. It will have to be welded and then filed down and a new sprocket fitted. Pretty simple - take me about an hour probably. GD
Hub/Assembly
GeneralDisorder replied to amr9000's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXFind someone with a hub-tamer or similar and press in a new bearing - about $35. Sounds like a used knuckle was installed that doesn't have the tone-ring setup for the ABS. Sometimes that will happen when you can't find the one you need in a timely manner.... just means the ABS doesn't work which isn't that big of a deal since the early ABS on that '96 is a big pile of crap and probably is better off not meddling with your braking anyway. GD
87 Gl hatch power steering
You can only run the EA82 style pump if you have the EA81 Turbo water pump, crank pulley, and alternator pulley as well. And you will need to have custom lines made up between the pump and the rack. It can be done though. If you are near Portland you can drop by and check out the setup on my wagon if you like. PM me (once you get to 10 posts) or leave a profile message or something. You will still need the EA81 power steering rack and cross-member. That's a different beast than what you have and it will take some searching - most EA81's didn't come with power steering so you have to find a high-end model. The true EA81 power steering pump is a BIG sucker that's off to the passenger side of the engine - it requires big mounting bracket, an idler that hangs down under the engine by the pan (and is vulnerable down there), and a different upper radiator hose and thermostat housing. And being that you have a hatchback - you need to be looking for parts from '80 to '84. Most '87s are EA82's and are almost entirely different. EA81 parts are getting scarce and harder to find now. They are still great cars but not well suited to daily driving anymore due to the lack of availible parts for them. Are you the one that bought Ryan's lifted hatch? GD
