435
Picking up a Loyale- things to look for?
GeneralDisorder replied to Hex1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Things to look for: An entirely different platform. Seriously? You can't be serious? You want to get stuck in the woods and starve to death? LoL GD -
1984 GL Engine (& Transmission?) Swap
GeneralDisorder replied to 1984 GL's topic in Old Gen.: 80's GL/DL/XT/Loyales...
No part of this is a "bolt in". It requires significant custom work. This isn't an LS swap - no one makes much of anything to help you. The EJ trans will require a completely custom transmission cradle and linkage. If you aren't good with electrical and welding I wouldn't attempt it. GD -
Sounds like get another block. Don't attempt to split it and replace the bearings. Without a main-line hone (difficult to even find a machinist that's capable) that's a waste of time on a high mileage block and the potential to screw it up is extremely high. The first half a dozen you build are likely to fail or have extremely limited life spans. Subaru's are not forgiving about rod cap alignment, block half alignment, and oil clearances. If you are not familiar with reading measuring tools down to a couple tenths and have said tools on hand - it's not going to be worth the effort. GD
We use a pressurized tank of oil and an adapter custom made for the oil pump discharge port to fill the engine with oil at 90 psi. We put all 5 quarts in them this way. We hand crank them while they are filling. You can try cranking it with the crankshaft sensor disconnected, but unless the oil pump is packed with assembly lube it probably wont prime. You would likely be fine to just start it and observe the oil pressure light. But we don't take that risk on the high dollar engines we build. GD
Remove shift yoke from transmission
GeneralDisorder replied to Ionstorm66's topic in Old Gen.: 80's GL/DL/XT/Loyales...
They are supposed to have a double roll pin. I generally knock them out together. GD -
'17 in my shop right now with a rod knock. 69k miles. Just did a '16 Forester that had a broken valve spring at 120k. Nothing else wrong just a broken intake valve spring. GD
Here in the US it is illegal to deny warranty for not using the dealer service department or parts. Subaru oil and filters are garbage BTW. GD
Yes you can drive out the pin. They all leak from the shift shaft seal. They start leaking there as soon as you sign the papers. They are a pain to replace and will just leak again in about.... 3 miles. I've seen 2019 STI's with less than 5k miles and the shift shaft seal already leaking. It's pretty much a waste of effort. GD -
91 loyal swapskies
GeneralDisorder replied to IfjdmaintAwD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you want to use that WRX as a donor, you need at least a first gen (1990 - 1994) Legacy. The Loyale is not compatible and the EJ20T will tear it in half like Jesse Ventura with a phone book. GD -
EA81-T Fuel Pressure Regulator
GeneralDisorder replied to Datnastybrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Haven't been impressed with the Aeromotive stuff of late. Radium Engineering is my choice. GD -
We do the HG's, timing, and radiator/hoses for $2750 Axles - there's choices but I prefer to use new OEM axles - they tend to be around $400 each. I can get Chinese one's that aren't terrible for half the price but you don't get the longevity out of them. If we were doing a HG replacement I would only charge one hour for install of both. GD
