435
Coolant leak somewhere near head
GeneralDisorder replied to blatantb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah - leaky heater core hose or manifold hose or leaking manifold gaskets would be my first suspect. The only time I've ever heard of an external coolant leak on an EA head gasket was when someone used copper head gaskets. These just don't generally fail in that way. It's possible but experience indicates it's VERY rare - so much so I've never heard of it or seen it. GD -
So...Am I the first to have a Frankenmotor in his Brat?
GeneralDisorder replied to renob123's topic in Subaru Retrofitting
I drove it. It's nuts. Brat's should not have that much power. Very dangerous. Steering under acceleration like that is like trying to steer a jet-boat by dragging and oar alongside . EA81 Suspension < EJ25 Frankenmotor. It will BURY the speedo. I have no idea how fast I was going but I'm sure it was close to triple digits. Something is going to break - I wouldn't be surprised if it frags that transmission on dirt. There's more power than I could even use on my test drive - it's like driving a WRX but without the turbo lag and with a really sketch suspension - feels like a WRX powered sand rail on the freeway GD -
Don't get me wrong - they are better than nothing. But *most* of the time I find that the questions I need answered are not part of the "normal" repair procedure. What they lack is accuracy in their wiring diagrams, wire colors, etc. And then the "hard" stuff they cop-out and tell you to take it to a shop. LAME . Without fail I have accomplished all of the tasks they claim I can't accomplish. WITHOUT FAIL. Granted I will not accept defeat and if it means I have to buy a new tool then so be it..... I have been to the dealer for a repair only twice - both times for warantee replacements of "lifetime" seat belts that were freyed . I'm not forking out the $300+ for the parts and I'm sure as heck not doing the labor when SOA is picking up the tab. GD
weber choke high idle
GeneralDisorder replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Likely just needs some lube - I agree. GD -
best place to buy exhaust for an ea-81?
GeneralDisorder replied to RallyAlex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes - we are all cheap. I am getting a little less so with age though. Money well-spent vs. poorly spent is the distinction I try to make now. 2.25" (what I meant) will just allow it to breath better after the cat. The stock exhaust is 1-7/8 IIRC. 2.25" is easy to get and will help a little. The header should be left stock for a stock engine as they really aren't much of a restriction and they do well at scavenging. Replace the muffler with a cherry bomb, etc. Makes for a nice exhaust note. GD -
Excelent! I'm really glad to hear that you got it fixed and it wasn't neccesary to change the throttle stop. It's nice when we hear back from people on what does/does not work. So many posts end without a resolution . I too have had issues with the IAC (seemingly) and idling too fast/too slow/hunting. Do you have any idea what was wrong with the previous two units? GD
Depends on the year - in any case the front O2 (before the cat) is the only one that matters for mixture control and thus fuel mileage. I use the NTK brand one's (made by NGK spark plugs) and they run about $75 for the EJ front O2's. Being that the car has 240k on it and the exhaust sounds original from what you are saying - if it hasn't been done in the last 100k then it probably needs a new one even without a code - they get slow to respond and cause mixture issues which reduces fuel economy. Tire pressure, etc is also a factor. And a roof rack will grab about 2 MPG on the freeway..... GD
The best way to go is always the factory service manuals. They are not cheap. But I beleive Subaru has a web site setup where you can pay a fee to get online access to the FSM's. I'm not sure if you can order paper copies for a '99. Check with your dealer. I think some of the newer stuff they no longer print but '99 is old enough that they may have produced them. If so you should be able to order a '99 FSM set from your dealer. There is probably 5 or 6 volumes to the set. A Haynes or Chiltons manual is like $20 and that's about what they are worth too. . I wouldn't rely on what they say farther than I could throw one. GD
Jeez! You guys need to check your sensors and tuneup stuff. My last DD EJ (besides my '91 Turbo ) was a '94 GT wagon and got 25 to 27 regularly and 30.5 on freeway trips. My '83 hatch gets 27 around town and 31+ on the freeway and it's got over 260k on it, a low comp. cylinder, a tuned Weber, and I drive it like I stole it . Other than my EJ22T Legacy, I've never had a Subaru that couldn't get at least 25 in town and over 30 on the freeway. My EJ22T get's 16 and runs premium..... and I wouldn't have it any other way GD
I wouldn't worry much about it - all kinds of junk get into bell-housings. Rarely does any of it cause an issue. The back side of the flywheel is a good place for it in the scheme of things - eventually when the peices of it get small enough from rubbing on the (cast steel) flywheel they will fall to the bottom and be just one more peice of debris in there. Just run it. Don't worry about the stuff in there. Most of the Subaru's on the road probably don't have that cover either - they get hard and cooked from engine heat and then when someone removes it (which is odd that they would on an EJ MT since there's no real reason to - it's the access for removing flex-plate bolts on AT's) they break and won't stay in place anymore. GD
$40 MP3 Head Unit - Perfect Fit
GeneralDisorder replied to Trevor's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I just ordered one of these off Amazon to put in my '83 Hatch. So we'll see just how well they fit an EA81 (should be awesome being only 4" deep). I'm going to probably be putting it where the map pocket is located and putting the pocket where the old two-knob stereo was. Stay tuned for my install pics. GD -
Good Commuter: Subaru Justy?
GeneralDisorder replied to SubieDaddy80's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The Justy's have a bad tendancy to eat oil pumps and end up with rod knocks. They have that really aweful CTV transmission in the automatic's (avoid like the plauge). Ultimately, if you can find one in really excelent condition that's been run with synthetic and/or has had the oil pump replaced regularly - then they can be an ok choice. Parts availibility is not the best. Ultimately - we all know how much distaste I have for the EA82's - yet I would pick one every day over the Justy. At least with the EA82 you can always put in an EA81 or an EJ. GD -
88 DL Stereo upgrade / build
GeneralDisorder replied to sl33py's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I know someone that uses a 1980's IBM 3000 series mainframe as an industrial label printer for mass-mailing..... he lives in a warehouse along with his mainframe and other stuff he has collected through his junk hoarding proclivities..... Beat that for geek-ness . I know I can't. GD -
EA81: Fusible link problem
GeneralDisorder replied to MaddCelt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sun bleached? Red, green, and black are the only colors I know of from EA Subarus. I don't think you do know what happened. The fusible link box is plastic so unless something is seriously fubar you aren't going to get a short. A "short" is a path to ground. What you probably are seeing is a poor connection between the male/female spade terminals on the box and the link - causeing resistance - which causes heat and eventually burning of the link and possibly melting of the plastic. You have this board - which you obviously didn't consult prior to wiring in a fast blow inline fuse in that location. The fusible links are the only thing that keeps people from burning their cars to the ground on a regular basis - it happens enough without them messing with that stuff. I've seen it happen. If fusible links didn't exist the road would be littered with burned out hulks. You just need to carefully consider what it is you are messing with and how dangerous modifying it might be..... that's all I'm saying. GD -
Hows this sound for 84 Wagon?
GeneralDisorder replied to 92_rugby_subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
PO changed the driver's door to a manual one and cut the window harness off at the jam . Probably just needs some wires jumped in the harness to complete the circuit to the other windows. This car is a nightmare. And part of the harness is melted from a fire - don't underestimate what may be required to make those windows work. GD -
1991 loyale quick engine questions
GeneralDisorder replied to Screwmedo91's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's a small displacement 4 cylinder - over 2k lbs of car will turn the engine over. When turned over slowly the cylinder compression is of little consequence. That's why they included a parking brake. You aren't supposed to rely on the transmission to keep the car from rolling away. That's bad form. Putting it in gear in *addition* to the parking brake as well as pointing you wheels toward the curb is not a bad idea but the transmission alone is not going to hold it. GD -
Yeah - I have one of the early stereo bluetooth decks in my '91 SS. Sucks for taking phone calls but rocks for playing music from my phone. Love that feature. But on the geek side of things - CD's are pretty much outdated. I would give a mechless deck with a sleek install that doesn't use a spacer MORE geek points I'm a former software engineer. You can't out-geek me I assure you . GD -
Have Legacy wheel bearings installed. And find someone that is skilled in the ways of bearings in general. Most auto mechanics do not treat them with the care and precision they require. Sounds electrical with your guage problems. Always best to have weird electrical gremlins checked by the dealership. The gauge is designed as a resistance meter. If you get a dead short in the wiring the gauge will indicate full hot. Sounds like a simple short and your "mechanics" are not willing to tackle it. If it were me I would probably just run a new wire from the dash harness to the guage sender. It's a single wire device - pretty damn simple. GD
If you want a cleaner installation where you won't need an installation kit/spacer, etc - these are only 4.2" deep: http://www.amazon.com/gp/product/B002OMB7FE/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B002OR0HWI&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=12S0K63HX98T7CPMM5AP GD -
The head unit will not fit without a spacer ("installation kit" ) But they now make inexpensive non-mechanical head units that don't have the CD player and are about 4" deep. Those can be made to fit without the spacer. GD -
Scrape the rubber up with a heat gun and putty knife. Hurculiner and done. GD -
81 GL-5 Wagon to get it or not to get it
GeneralDisorder replied to 84gl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I should rephrase - it would be a good deal to someone. But not to someone that has as many vehicles as you apparently do. If it's going to just sit in a barn then what's the point? Personally I'm in the same boat. People want to give me stuff all the time - I got handed the title and keys to a '93 Legacy wagon not long ago. . I could have almost an umlimited supply of unwanted EA82's...... I can't store them all nor do I even have time to part them out. I have 6 cars of my own (5 Subaru's and a truck) and usually between 8 and 12 sitting here at all times in various states. A FWD EA81 (and an early '81 model at that) is the LAST thing I need. That's an albatross that will never go away. That's like the last FWD EA82 I had - had to sell it for $500 to get it out of my way and it only had 118k on it. :-\. If I can't sell it and don't want to drive it - then I would rather not be tripping over it.... know what I mean? GD
