435
90% sure i just blew a headgasket
GeneralDisorder replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Probably not - how much smoke are we talking about here? Crankcase vapors do have a smokey apperance to them very often. GD -
If it's low, then you could just be seeing the effects of the pump sucking air...... GD -
Something has changed it sounds like. If it's a head gasket leak it would seem as though (from your description) that the compression should be much lower than what you are reading on the gauge. I have one low cylinder on my hatch (110 psi while the rest are 145ish) and it doesn't run any different - still idles smooth and has good power. Been that was for several years - probably a burned valve, etc. I would pull the valve covers and inspect the action of the valves on all the cylinders. Something could be not openeing - last time I had an issue just like your's on my 350 SBC one of the rockers had blown apart (bottom of the rocker just ripped out) and the intake valve for that cylinder wasn't opening at all. It was pulling oil past the rings and burning it causing exhaust smoke and rough idle. I replaced that rocker and it's back to it's usual worn-out self . Maybe you have a push-rod issue, etc. If you don't see anything there - run a leak-down test on it. Is it drinking coolant? Could be a very bad intake manifold gasket that's pushing a lot of coolant into one side of the engine causeing a misfire condition. GD -
Run a compression check for sure - if it's blown so bad that it won't run on that cylinder it should show something on the gauge. GD -
Tow rig - buy or build a trailer to haul your Subaru trail queen with . They are good trucks - I have an old 2WD, 4 speed, '69 GMC Custom Camper (3/4 ton+). With a 350 SB and a 4 barrel. It's a monster - hauls like nothing else with the camper package suspension overloads, sway bars, and a Dana 60 Power-Lok rear end. I put 1.25 tons of roofing in it a couple weeks ago and it just about leveled it out - actually touched the overload springs with that load . I'm wondering (because you mention the rear end is gone) if it had a Dana 60 in the back..... 67, 68, and 69 had it as an option ("Max-Traction rear axle" was the option name on my GMC) and then GM went with one of their own corporate units that wasn't as strong in '70.... A Dana 60 non-dually (because most were dually's from 1 ton Fords) Power-Lok rear axle will bring $1000 to $1500 in used but rebuildable condition - people throw them under rock crawlers as they are built like tanks. Turns out the axle in the back of my truck is worth more than I paid for the truck. Was it one of those years by chance? A truck is a really useful thing. Depending on the age it might not have to go through state testing - 350 SBC's are a dime a dozen and great engines and often come with the Rochester Quadrajet which is an excelent 4 barrel carb IMO. GD
If it's an EA81 with a 4 speed D/R then it's a great car with a legendary engine. The transmissions are less than fabulous but we just swap those out for the later 5 speeds. Yes you can lift it and lift kits are availible through several sources. Parts are getting harder to find. Mostly this board and other places on the internet are the best sources. There are some Subaru wrecking yards here in the NW. But a lot of parts don't have to specifically come from an EA81. There are lots of options when it comes to parts and there's actually very few times when *only* another EA81 part will do. Engine parts are still plentiful and availible though many channels including the dealerships. Motor swaps have been done. I've helped install an EJ22 into that body. It's possible though time consuming as anything newer is going to be fuel injected and that's a whole lot of wireing and plumbing that most people don't want to do. GD
The SPFI cars had no serviceable filter before the pump. I'm sure there is a sock on the pickup in the tank but that is all. They are rotary vane pumps and as such they tollerate a good deal of small debris without much trouble. Thus the mounting of the *real* fuel filter in the engine bay on all FI Subaru's. GD
BRAT with a "Sport" package
GeneralDisorder replied to Twitch de la Brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
83/84 they offered them with the EA81T engine's. Sadly only with Automatic's though. But still 95 HP instead of the stock 74. It's purely weight. Other EA81's are typically heavier - the closest to the Brat being the Hatch. Where does this information come from? The interpretation of "sport" could be anything. Probably refers to the decal package . As far as drivetrain and suspension though - a Brat is a Brat unless it's a turbo. There were never any official upgrades as far as I know. At least I've never heard of such a thing and it's closing on a decade that I've owned them now. GD -
Spfi Conversion Question
GeneralDisorder replied to Petersubaru's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah - some of the early stuff has funny connectors as well. The distributor pin issue is something I should add to my conversion page. GD -
Fan nuts?? Crank pulley?? Gotta be a trick...
GeneralDisorder replied to cnc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's been modified - lots of them are like that. I've even cut a few myself. GD -
The 170 AC should be on the primary, not the secondary. Likely you will need a larger primary idle jet. Have to tune it and see. GD
There are no Subaru's that are enough wider than your '90 to make any real difference in the width. The differences from the Legacy on up are a matter of fractions of an inch if anything. Not enough to bother with. You'll have to do it the hard way - the suspension components aren't the hard part - that's just machining and welding. The hard part is going to be figureing out something to replace the struts - they aren't going to cut it for the kind of travel you are talking about. GD
Should run fine - just get a code eventually if you drive it. GD -
Power-up my 1980 DL Wagon 1.6 EA81
GeneralDisorder replied to JusticeInPDX's topic in Subaru Retrofitting
No - they are not interchangeable. GD -
Auto belts came out in '90. Silver and Black ECU's are interchangeable - the only difference is that on manual transmission silver ECU's have a clutch switch in addition to the neutral switch in the tranny. But other than that they will still work - just might get a code about it. GD -
Subaru probably suspects that the same flaw exists on both heads. You may not know this, but Subaru uses the same castings for both right and left heads - only some of the port drilling and machining are different. Thus if there was a flaw in some parts used durring manufacture of the heads (improperly ground seats, etc) then it could exist on both sides. This is all the more likely given both of the original heads were likely made side-by-side on the same equipment. They may have seen this before and they know that it wasn't an isolated case thus they are making sure that there is no possilbility of a second failure. Good stuff. Glad they are taking care of you! GD
That's an EA71 (1.6) top-mount starter engine. Unless you also change the tranny there are no larger/newer engines that are compatible. That was the last (and largest) of the top-mount starter engines. If you go to the EA81 side-starter transmission you can install an EA81 (1.8), an EA82 (1.8 OHC), or by the use of an adaptor plate you could install just about anything in the EJ line up - easiest would be an EJ22 (2.2) but EJ25's are possible. There is also the ER27 (2.7L H6) that shares the same bell-housing as the EA81/EA82 but is rare, expensive to maintain, and will not fit behind the radiator without major frame and body work. GD -
The fan nuts suck. Long pattern 10mm and a long flat-blade screwdriver to keep the fan from turning. The crank pulley is easily removed or installed with a 1/2" ratchet and a hand sledge. Like a 3 or 4lb sledge. Just whack the end of the ratchet handle. It's like an impact gun but cheaper . I do it all the time. GD
