Picked up two more Brats...
We don't crush for rust - we just crush for fun! Seriously though - those are parts cars. With so many complete specimins around in the NW you can't really justify putting something like that on the road. And gen 1's aren't all that desireable. They command more than a wagon to be sure, but 82-87 Brat's are where the time/money is best spent. If you are going to restore one - restore one that's actually going to return the investment ya know? It's all about where you want to spend your time. For example - as far as profit making opportunities - there aren't any left in the EA series cars. I don't buy them at any price, and frankly I see a lot of them I could pickup for almost nothing - $100 or $200. Several a week. Even first gen Legacy's aren't worth beans. I won't even buy them except for EJ swap donor's. Last one was a '91 sedan for $250. Needed 1 injector '95 and up is all I even look at, and I won't pay a lot for those. I just bought a '95 wagon in decent shape with 165k on it for $800 - drove it home. GD
92 Legacy AT start problem
No problem - I'll help with what I can. If you need talked through it over the phone send me a PM and I'll give you my number. All you are going to have to do is cut/strip/crimp some wires and spade terminals. You will need a relay - I typically have used Subaru relay's around but you can use any 12v normally-open relay. Most auto parts stores will carry something in a blister pack - like a Bosch, etc. On the side of the relay will be printed it's "pinout". There will likely be spade terminals - either 1 through 4 or 1 through 5 depending on the relay type. You will see that two of them in the diagram pass through a rectangle - that's the coil inside the relay - when powered it causes the contacts to close. Two of the other pins will pass through a contact "gate" on the diagram - it will look like a raised bridge. You want to use the two contacts that are NOT closed on the diagram. Now it's a simple matter of hooking up the wires to the right contacts. You will need to make three wires. First you will cut the end off the starter solenoid wire and crimp on a new female spade terminal. That will connect to one of the coil contacts - doesn't matter which one. The other side of the coil you will run to ground - which means any availible location on the engine/manifold/body, etc. The other two wires will run from the battery, through a 15 amp fuse, and to the normally open contacts in the relay. The other side of the contacts runs to the starter solenoid where the original wire from the ingition switch was. Here's a diagram I found online - instead of "starter button", you will be using the solenoid wire from the stock ignition switch: A relay is simply a remotely activated switch - you turn it on with 12v. That's what you will be doing. The reason this works is that it takes a LOT less amps to turn "ON" the relay than it does to push out the plunger on the starter solenoid. Relays switch on a large voltage or current using a small voltage or current - ultimately they save on wireing and switching component costs and make things less bulky. In this case you are using them to advantage by taking the large solenoid load off your aging ignition switch and putting it instead on the relay. This will save your already damaged crank circuit from further decomposition. GD
Re-torquing heads?
71 ft/lbs is a bit on the high side. Stock is 47 and I take them to 55. I haven't tried any higher because I haven't found it neccesary - I haven't stripped any block threads out yet but I have heard of folks haveing that trouble. Just a sugestion. If you hadn't gone to 71 I would say reuse them and go 10 lbs higher. But...... I would replace them considering the high torque they were under. I don't think you need to have a shop put the heads on - seems like you are doing fine on your own. Maybe have them do the valve's but mounting and torqueing the heads doesn't require a lot of "special" knowledge. Just a little care which I would think you would have more of than some shop. GD
welder?
Of the two, I prefer Miller over Lincoln, but they both make decent machines. I've used both in their 230v/460v range of machines and typically the Miller's weld a little cleaner. Though I do like the Lincoln Sqaure Wave TIG machines FCAW (flux core) will do thicker material and handle dirty stuff a bit better - that's true. And there's no arguement from me that a 110v FCAW machine is a really useful tool to have - no gas bottle - all you need is a 110v extension cord. That's a very conveinent thing. That's what my old HF 110v machine is for now. Just depends on what you are going to do with it. Small automotive stuff and sheet metal - 110v machine is a good choice. I wouldn't try building a trailer with one though nor would I trust it to weld 1/4" thick mild steel lift components for a Subaru. GD
Just install a relay between the existing solenoid wire and the starter - use the solenoid wire for the relay coil and run a hot lead from the battery (fused) to the relay contact and then other side of the contact to the solenoid. I just did the same fix in a '91 AT - same problem. Intermittant start. It's not the ignition switch - the previous owner had the dealer change that out less than 10,000 miles ago. It's just that the ageing wireing can't pass enough current to kick the solenoid hard enough. You can swap/replace components all day and in the end it will just keep comming back till you fix it with a relay. This is a pretty common problem on older Subaru's - I've done about half a dozen relay's by now. It's a 100% success rate for me. I drive the '91 daily and since I installed the relay it has started flawlessly every time - been several months now. You do not need a push-button - you use the stock ignition switch and instead of fireing the solenoid directly it fires the relay. They will pass enough current to close a relay contact easily. GD
Differetial axle shaft bearing....anyone?
GeneralDisorder replied to Rhubey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe roller bearings are pressed onto the diff carrier - removing and installing them requires removing the diff from the transmission. It's not difficult really - just remove the tail section and split the case - the whole diff drops right out. GD
interesting shuddering
Being a turbo - high likelyhood that it was overheating and some previous owner removed the thermostat completely. These EA82T's rarely overcool - mostly they overheat and blow up. GD
Re-torquing heads?
I would get another one - the seal between the graphite and the head/block has been disturbed and it might not bond tightly the second time around. GD
Quick question on a '92 Loyale
Yeah - total water pump failure - I've seen it before. Basically you will need to do a whole timing belt job. Replace the timing belts, water pump, reseal the oil pump, and new front main and cam seals. The entire kit with the belts, idler, and both tensioners can be had on ebay for cheap. The labor is about 3 to 6 hours depending on experience. You will want someone that's experienced with EA82's as the dual-timing belt arrangment is unusual and a lot of mechanic's have a hard time with it. If you want to tow it to West Linn - just south of Portland, I could do the job for $200 plus parts. Typical shop rate for a timing belt job runs about $500 - I can save you about half that. If it needs a radiator, those are about $120 new. I don't like to use used one's as these cars already have small cooling systems. Another possibility - I have a friend that regularly travels through your area and also has a car trailer. For a small amount of gas/hookup money he would be happy to bring it here. GD
It sounds like the water pump has failed - the mechanical fan should have NO play in the shaft with or without the belts attached. You should be able to spin the fan, but not move it on it's shaft. Those are not the timing belts - they are the accesory belts. They run the power steering pump, the alternator, and the water pump. As well as the air conditioning if your car is equipped. Are the belts broken or just loose? If they are loose it's probably because the water pump is gone. When you move the fan do the belt pulley's (where the belts contact) move with it or does just the fan move? Also - you should post where you are located so members in your area can offer assistance if they are so inclined. GD
painting my XT
Don't clear coat it - that will just peel off. You should put around 5 to 6 coats of color on, then wet sand it with 600 then 1200 grit. Then buff it out with finishing compound. It will looks better and last longer than the clear coat. Remember - light coats - but lots of them. Don't glob it on or it will take forever to dry. Prep the surface with a D/A if you can get one or sand it real good by hand. Make sure the suface is very clean - use laqour thinner to clean up sanding dust, etc before you spray a panel. There's nothing wrong with a rattle can job - just understand that it's going to last about 2 years give or take - the clear coat will make it look worse when it does start failing and makes it impossible to touch-up, color sand and refinish when it does start looking like poo in a year or two. And watch out for big bugs - a good sized one will roll up that soft rattle can paint from your headlights to the winsheild if you hit em right GD
welder?
Yes - very important - if you don't know how to weld it's going to be 10x harder to learn on a crap machine. A good welder can make one work OK, but a novice will expose all it's flaws and turn out really poor welds. Have you thought about a decent stick machine? I firmly beleive that you should learn at least AC/DC stick before you MIG weld anyway. Gas welding is optional these days and frankly is just as expensive as MIG if you have none of the gear. A decent stick machine can be had for almost nothing - a Lincoln tombstone can be had for $100 or less and can produce very strong welds even if they aren't the prettiest thing around. GD
1990 legacy, possessed door locks...
GeneralDisorder replied to zyewdall's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt's just all the lock mechanisms and rods/links needing lubed. Pull the door panels off and spray it all down with lithium grease. Work them back and forth. They probably are binding and not fully disengaging from the locked posistion. Every gen 1 Legacy I've owned needed this done. There usually isn't anything broken though. GD
1987 GL SPFI revving uncontrollably
For it to get to 5k you need the throttle plate open - no amount of extra fuel will do it without the air for it to mix with. It's got to be a mechanical bind of some kind as it would never get that out of control without the air supply from the TB. Only other thing I can think of would be a sticking idle air control valve - but even then I wouldn't think it could get to 5 grand. GD
xt-6 front axle spline question
Only difference I could see side-to-side would be the use of a different inner joint boot on the passenger side to prevent heat damage from the cat. Otherwise that's probably a cataloging mistake as every Subaru I've ever worked on (except the Justy) uses the same part for either side. Even in the Subaru parts books. GD
timing belt how to with picks
GeneralDisorder replied to bobaru's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf none of the coating has come off, then it would probably work. I've never tried to reuse one of those, but maybe since it's still basically new. As pointed out though - the cost in labor would kinda suck against the cost of the new gasket if it didn't work. GD
XT6 axles are unlike all other EA82 (including XT) axles. They use a legacy style outer that mates to the 5 lug legacy-style knuckle/hub assembly. They most likely have a 25 spline inner. I beleive they are basically first-gen legacy axles. If you throw up a picture we can tell you immediately if it's the correct axle or not as the outer joint is quite different from any other EA82 axle. They do not have the bearing mating surfaces like the EA82 axles - instead they are splined to fit the hub which is pressed into the bearings. GD
Hot wire vs. vane style MAF. If it's an 85 or 86 it should have the vane style, and all 87's and newer should be hot-wire. Just clean the two little wires with the electronics cleaner. GD
Actually the difference in octane ratings is purely one of how it's calculated by the laws of the country you are in. There are two common ratings (RON and MON) and some countries use one and some use the other. By govenment mandate here in the US we use the average of the two. That makes our ratings quite a bit lower than Japan for the same grade of fuel. So our 91 is their 105 or whatever..... That said, the EA82T should run just dandy on 89 or higher. Higher is prefered but they have a knock sensor and fairly low boost pressure's stock. 91 is prefered but you won't notice the difference much at all. In other words - octane is not your problem. Not even remotely. JDM has nothing to do with how it will run here - the fuel inejction system is USDM and the compression ratio of the engine is still 7.7:1 - requireing the same octane as the original engine that came with the car. GD
weber throttle set up
I think the SPFI cable will work, yes (if it's an EA82 we are talking about - the pedal end is different on EA81's). The adjustment nut's and the end of the cable is a larger diameter but if you can work around that the barrel should fit the Hitachi wheel. Otherwise the cables aren't real expensive from the dealer - I think around $20 give or take. Obviously they don't stock them but they can usually have them in a few days. You could always tie a string to it and run it in the cabin for a temporary control. GD
welder?
They work OK for the price. They aren't the caddilac of welders obviously but they are common enough (due to the cheap price) that there are lots of mods you can do to them to improve their features and welding characteristics - lots of good write-up's and such can be found over on weldingweb and other forums. The MIG torch and cable is cheap on them but it's also cheap to replace - parts are readily availbile through HF if you just call them. Shipping is fast, etc. There's a lot of plusses to them from that standpoint if you are handy with electrical and into modifying things with bigger, better fans, better diode bridges, etc. I have the 110v version of the same machine - gas capable, etc. It was my first MIG welder and I did add gas and tweak it a bit. Worked OK till I wanted to weld serious structural stuff. They can't handle much over 1/8" on the 110v machines. And the 220v machines won't handle as much as the big-name 220v machines will. Typically they over rate the machines. A 220v HF machine will not do what my 220v Fabricator 180 will do. If you want to step up to something decent but a little less than the Lincoln/Miller stuff take a look at the Thermal-Arc offerings. It's Tweco's welder division. My Fabricator 180 was $625. I like it a lot. I can weld up to 3/8 no problem and that's about as thick as I typically go. Plenty of good used machines out there as well. Take a shot at craigslist and see what you find. Lots of people trying to make a few bucks on machines they don't use right now with the bad economy. One of the biggest overlooked costs with 220v machines is getting power to them where you need to weld. You need a decent extension cord and that's a few $$. I built my own from 8/3 SOOW cord - it was still around $100 for the cord, end's, and such. If they don't get the amps they need they won't weld worth beans. If you can find a gas bottle on sale you might get a decent sized one for $80 or so. Gas regulator will come with the quality machines - not sure about the HF one. But that's another $75 cost if it doesn't. GD
Hill Holder Removal? '87 Brat
Dealership. They aren't terribly expensive - best to get a new one. You don't want it binding. GD
Yeah - I don't like em much so I don't see many either. But it's helpful to remember that Subaru has never made a turbo with a carb. In fact very few car manufacturer's have ever done that. Although the Masarati BiTurbo comes to mind...... GD
No choke or carb on the turbo engines. I agree - start with plugs/wires/cap/rotor. Turbo's in general don't like large plug gaps as the high cylinder pressure's tend to cause misfireing if the plug gap is out of spec. When warm the mixture will lean out and make the problem more noticeable. Also might be a good idea to get a resistance reading on the coolant temp sensor - the computer may not know it's warm. And have you checked for codes? The ECU might be able to give you a head start on troubleshooting if it's got codes set in the memory. Clean the MAF if it has a hot-wire type. Electronics cleaner or MAF cleaner will do the trick. Check the timing - the timing information should be on the hood sticker - it varies depending on the year for the turbo's. GD
What are you brat owners using for Service manuals
You need the '84 factory service manual (it's a single volume) and the 85 to 89 Brat/Hatch wireing supplement. Those two will cover everything for all the 84+ EA81's. They did not print Brat specific FSM's - the Brat is a carry-over body style from the '80 to '84 lineup and as such continues to use the '84 FSM. Only wireing changes were made after '84 as all new development was concentrated on the EA82 platform. GD
