Coolant Leak- Water pump-Idling help
Replace the pump. Might only last a couple miles. When they go it's usually quick. As for the idle - clean your IAC and go from there. Check the CTS for correct resistance when cold. GD
Wheel problems
Might be a clutch issue in there somewhere. I just can't tell from your description. Sounds like a hell of a mess to me GD
Wheel problems
This is an automatic isn't it? Have you checked the tranny fluid? You might need to work on the governor. Axles are not your problem. If the governor, tranny fluid, or perhaps the modulator doesn't fix it then you need a new tranny. That thing has definitely had it. GD
Fuel Pump Problem? and/or Suggestion for Weber
But how is your driver's side connected to the air filter? What size hose? GD
Hooray for open timing covers, but...
They do stretch and the EA82's don't have hydraulic tensioners..... GD
2.2 to 2.5 Engine SWAP, how difficult
GeneralDisorder replied to DerElf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXValves hit pistons if the timing belt breaks. 90 through 96 EJ22's can freewheel - no damage if the belt breaks. If you do put in a 2.5 (not reccomended), it would have to be a phase II - '00 model year or newer to be a simple swap. But you would also need to swap the exhaust as your '96 exhaust is single port and the 2.5's will all be dual port like the early 2.2's Stick with the 2.2 - they are generally good to 300k+ GD
Starter solenoid ?
GeneralDisorder replied to Megell's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf that doesn't fix your problem, then you have battery cable issues or issues with the crank circuit that engages the solenoid. Both are common - more common than contact failure's. GD
No - you need it setup like this: GD
coolant flush tips
Yes - those are the two. Just look at the back of the manifold where the lines connect. Whichever one goes into the intake manifold is the one you DO NOT want. You want the one that dissapears under the manifold as that one runs to the water pump. GD
No cup holders
Between the legs, or between the 4WD shifter and the e-brake. Seriously there's not much you can do about the cup holder situation without causing damage to the interior somewhere. My solution - drive a gen 1 Legacy as a daily. Cheaper to drive and easier to find parts for - plus I won't give a hoot if someone runs into me. GD
Heater Problem
Yes - they are identical. The only difference is the way the switches look and the shape of the slider knob. You can pop out all the switches and pull the knob off and replace them with your original and it will look identical. Oh - and the backlight bulb is green on the newer one's. Again put your's in if you want the white illumination. There are differences in the design of the slider mechanism and strangely enough BOTH of the designs have serious flaws that result in them breaking. The intersting thing is that you can take the plastic slider out of the early control, fit the flat roller wheels from a later style control to it and install into the later model slide rail to make a superior control mechanism. The problem with the early one's is the shape of the roller wheels, and the problem with the later one's is the design of the slider. You just have to take bits from both to make a good one. GD
Unfortunately I suspected your PCV was setup something like that. In order to get positive flow and thus remove blow-by gasses from the crankcase, you need to have the passenger side open to the/an air filter (valve cover filter is fine), and the driver's side must go directly to the PCV valve. If the driver's side is also open to atmosphere as you have it currently, there will be no positive flow as there will be no pressure differential between the two valve cover's. The gasses in the crankcase must be displaced by a positive flow from one valve cover to the other - that cannot take place if there is no pressure differential.... do you see how there cannot be a pressure differential with your current sytem? Both ports are open to the atmosphere with the same diameter lines..... On the stock system there is only a 1/4" ID hose T'd into the driver's side and running to the filter - this is an "orifice" to control the flow and prevent oil from being sucked out of the driver's side valve cover. Several years of running without removing any acidic blow-by may be causeing damage to the engine's and thus your low compression, etc. GD
Seatbelts in my 92
It's probably not all that bad once you get the trim off. Pull the whole rear seat assembly so you have room to work. And perhaps it's time for a new dog. My opinion is that if the dog runs away, destroy's stuff, poop's in the house, etc..... that animal is a reject and must be traded in. GD
coolant flush tips
Yeah - a plain flush kit for 5/8" hose will work. You just splice it into the heater core line and follow the directions. You want to splice into the return from the core so you are back-flushing it - the one that goes into the water pump. The one that comes out of the back of the manifold is the supply. I would dismount the radiator and completely flush it as well as clean out the fins. Really simple to do. Just remove the fans and the two bolts at the top and it will come right out. GD
Wheel problems
It really sounds like a stripped hub from your description of it not moving for 30 seconds.... that's a long time and I can't see how it could happen unless the hub was stripped or there were internal transmission problems - but even then you have metal on metal and it should make one HELL of a racket if the hub were stripped, etc..... You say it doesn't do this in 4WD? That would also likely point to a stripped hub.... What year/model are we talking about? GD
frying regulators , please help
Just convert it to an internally regulated alternator and get a later 80's fuel pump control unit for the pump. There's a few guides on here on how to do that - it's not at all difficult. GD
How is your PCV routed with the Weber? I suspect you aren't getting rid of acidic blow-by gasses properly and it may be leading to cylinder damage. The #2 and #4 cylinder are on the downstream side of the PCV and also your comment about sucking oil out of the valve covers gives me cause to wonder how it's setup. GD
E10 Torx socket in Minneapolis Area
That's why an impact is beneficial. The shock treatment will often break them loose without twisting the head off. GD
Disconnecting Front Handbrake
They aren't 4 wheel hand-brake's. They only work on the front wheels so if you disconnect them you won't have a parking brake at all. If you do the rear disc brake conversion and use calipers from a 240 SX you can rig up a rear parking brake. GD
new gl-10 and member
That document cover's the 3 speed automatic governor. The 4 speed doesn't use a governor as it is electronically shifted. GD
Front end CLUNK
I haven't had an issue with the aftermarket's either but then I don't put a ton of miles on any given rig since I have so many.... and I generally use high quality stuff unless I'm in a pinch - Beck Arnley parts are very often repackaged OEM, and I get a lot of japanese made parts from my favorite aftermarket import parts house. They don't seem to carry ANY cheap parts at all. The only water/oil pump's they carry are the OEM's, etc. But the prices are usually right inline with like Autozone and the other ultra-cheap parts houses that sell korean and chinese parts. GD
High preasure oil leak?
Excelent - glad you don't have to get rid of the car! Always nice to know that all that stuff is new anyway. Good work on keeping at it till you found the issue. GD
Find a Snap-On or Matco truck. Either could probably have it in a day if they don't have one on the truck. I don't know about Mac but probably.... I bought mine from Matco as they are impact rated and an impact is OFTEN needed to get them loose. You MUST get a 1/4" drive as no 3/8" drive socket will fit. The Snap-On one's I've seen aren't impact socket's but I doubt that matters much. Other's on here have reported that a 6 point of some normal size will usually work to get them off as well. I haven't tried. I bought two of the E10's so I have one for my primary tool box and another in my junk-yard bag. GD
Seatbelts in my 92
Are those the child seat mounts? Might explain the oddball size.... GD
Seatbelts in my 92
You will have to remove the seat bottom to get at them. There are 4 12mm bolts that hold the bottom to the car.... Wait - does this have shoulder belts in the rear? If so you are going to have to remove the trim to get to the retractors. GD
