440
Fusible links Questions
GeneralDisorder replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check for power on either side of them. Just like any other fuse. If in doubt, replace them temporarily with a section of wire with spade terminals. Do this only for testing, use appropriately sized wire (approximately 2 AWG sizes smaller than the circuit), and have a fire extinguisher handy in case something starts smoking. GD -
Original radiators are good for about 8 years. We are seeing catastrophic failures on 2010/11 models now. The new blue OAT coolant seems to be eating cooling system plastics just the same as Dexcool did 20 years ago on GM's. Don't use any stop leak on your WRX. It won't do anything useful. Go with full welded aluminum. The CSF offerings are quite nice. Koyo is nice also but their warranty is poor. Mishimoto is garbage. GD
Doesn't really matter since the rule with these is to replace them with a used one when they fail. So one day when it stops moving or when you get tired of dealing with the symptoms, swap the trans with a good used replacement with a warranty. There's nothing else that's going to solve that type of problem and rebuilding them is non-viable. GD
First off - don't replace a working OEM coil pack. ESPECIALLY with some aftermarket garbage. They almost never fail and aftermarket one's do. A tune up doesn't include the coil unless it's not working or damaged. Second - do you have an EJ25 or an EJ22? Pics of the heads and timing belt covers please. GD
Look at the bearing - the surface that's still intact - there's no significant damage. The oil film that the crank rides on was not critically comprised by the loss of that small amount of surface. No question that this isn't ideal. But the reality is that the EJ22 makes 135 crank HP. These bearings can support about 500 HP and last quite a long time doing it. I have not seen a single failure that could be traced back to this type of surface flaking and I've probably seen damage exactly like that and found those little pieces in the pan or stuck in the pickup screen a dozen times over the years. The first few times I found those pieces I tore down the engine and found exactly that type of damage. But really considering the effects of that damage and not seeing any collateral damage that can be attributed to it.... I have since ignored that symptom. GD
The light scuffing and flaking is only a mild concern really. That would likely have ran out the remainder of it's life without issue. Think about it - what problem would that cause? I have actually seen that quite a few time. Found bits of the thrust bearing surface in many oil pans. Never seen it cause a failure. Regardless - you're stuck with the decision now. Line hone it and undersize the crank. DO NOT touch the cylinders, and DO NOT just polish the crank. Regardless of what the machine shop says. Have the rods resized to the crank. Get ACL tri-metal race bearings. GD
Likley internal coil ignitor failure. Cheap electronics in the coil pack. Overheat and stop working. You want to know for sure? Stick a scope on the ECM 1/2 coil driver signal, and the 1/2 secondary ignition. Drive till you get a failure and capture it. If you lose the driver signal you have wiring or ECM issues. If you don't you need a coil. GD
Bubbling in coolant reservoir
GeneralDisorder replied to MTNjohnny's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's completely normal. Subaru issued TSB's to ignore the cracks unless they extend into the exhaust port and leak coolant. Back in the day I did head gaskets on dozens of EA82's and I don't remember seeing any that didn't have cracks between the valves to one extent or another. Never caused a problem. GD -
No. You have to deck the block half (the smooth one), then run a line hone through it. You only get to do this once before you get into problems with oil pump fitment. But we do it all the time. I believe there are also oversized OD bearings being made now also. At least for the #5 thrust engines. The #3 thrust engines can have the thrust moved also and use a phase II crank. GD
Aftermarket coils are crap. Likely your problem. In fact a 1/2 misfire on a wasted spark ignition system is going to be a coil 99.99% of the time - since that's prettymuch the only thing shared by 1 and 2. Get an OEM coil. 100k is a good run for a coil. Also (OEM) coil failures are typically a result of plug gap being too large or the wires being shot. Anything the increases the secondary ignition voltage requirement will cause more heat in the coil and kill it sooner. GD
New guy looking at getting a 79 brat
GeneralDisorder replied to Rayrook's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You pretty much can't get any of those things. Oil pumps are NLA as are most engine parts in general. You will spend the vast majority of your ownership searching for parts. Used, new old stock (rare), and otherwise. These vehicles are absolutely not viable daily drivers. GD -
There is essentially no aftermarket for a 1990 Legacy. You can have exhaust custom made, but don't expect it to provide any performance benefit - it really will not. DO NOT change the intake in ANY way. Don't change the airbox, don't even put in a fancy air filter (especially not some oiled garbage like K&N). You will throw off the calibration of the MAF sensor and you will ABSOLUTELY lose power and fuel economy. You can't change the intake on a MAF vehicle without being able to tune it, and you can't tune a 1990 Legacy without spending way more than the car is worth. You can buy a lift kit. That's about it. Everything else has to be custom. Don't try to stick a turbo on it - besides the fact that this will cost a small fortune for someone in your financial position, the results will be spectacularly bad... if it runs at all. And if you succeed you will just blow the engine up - the compression is too high, etc. Basically just drive it and enjoy it for what it is. Basic transportation. Which is all that 99.9% of these will ever be. GD
- 12 replies
The first round of replacements was "interim". They replaced the airbags with the same defective Takata units (just newer) that were being removed. The Takata bags were considered more dangerous the longer they were in service and the higher the humidity of the environment they were exposed to. This second round is to replace them with permanent replacements rather than the defective original units. GD
Epic BRZ drift car build in Oz
GeneralDisorder replied to el_freddo's topic in BRZ and its Sister the Scion FRS/Toyota GT86
Not that epic really. Just had a Formula Drift BRZ/FRS in here on Saturday with a 2JZ in it. 470 RWHP. GD -
The shadow at 5 o-clock means nothing really. The "skirt" doesn't come up that far..... whoever you talked with is talking out their a$$ and has no experience with Subaru engines. The cylinders look fine. Put rings in it and call it good. If there is piston skirt scuffing then send me the pistons for knurling. Every EJ turbo we build has forged pistons and they fit quite loose and "slap" when cold. Doesn't have any real effect and they still don't burn oil. GD
