440
Start at the fuel pump control unit mounted above the hood release cable bracket - it's either a 6 pin black or 5 pin blue box that controls fuel pump power based on tach pulse (coil neg.) input. If you don't have a factory service manual for 84, find one on ebay. Aftermarket manual diagrams are worthless. GD
No. Get a weatherpack connector kit and make your own.
There isn't one. I assume you either recently reset the codes on the computer or disconnected the battery. The ECU need to relearn it's idle. Clear the ECU or disconnect the battery for 15 minutes. Turn the key on, wait about 30 seconds, and then start the engine. Allow it to idle for 45 minutes. DO NOT touch the accelerator during this time. Then you may drive it normally. GD
Problem is NOT fixed. The 2.5 sensor has a different connector because the 2.2 and 2.5 use different piezoelectric crystal frequencies and it will not correctly identify knock events. It has the right resistance to make the ECU diagnostic subroutines happy but it will not function the same and may lead to detonation and a premature rod bearing failure. Subaru engines are very sensitive to detonation. GD
Yes we can and do offer re-ring services for short blocks, etc. It's about 4 hours labor for removal and reinstallation / ring fitting, plus the knurling which is $25 per piston and includes putting them through the parts washer till all the carbon is dissolved. Rings are $50. So it would be $546 parts and labor. As for adding power - you can do a cam grind which will likely not make "more" power but will move the peak power around, or you can shoot for a compression increase which in the case of that engine which already has flat-top pistons, would mean milling the heads and using eccentric timing idlers and slotting the intake manifold bolt holes. Plus running exclusively high octane. GD
- 105 replies
99 should already have a 10mm oil pump I think..... definitely check. 642 gaskets are a slightly better fit to the head cooling ports. Though it doesn't matter in the least. The valve guide dropping issue is on the 2006+ heads. The stem seals are viton and you need not touch them. I would lap the valves though. Or have a 3 angle done. STI oil pan and dipstick (different length) will increase capacity, has better baffles, and this way you don't have to clean the old one when you do rings. NPR rings, NO honing. Drill the carbon out of the drain back holes, knurl the skirts and hand file them to a net-zero fit. GD
- 105 replies
- 1
642 and 770 are basically interchangeable and we just use whichever best matches the head casting being used. GD
- 12 replies
- head gaskets
- 2003 outback
(and 2 more)
Tagged with:
Call a yard out here and have it shipped. But that's a $175 part from the dealer with no bearing, no hub, and no ball joint. So $100 used with a good bearing isn't a bad deal. And if you are buying parts from the NE then you can expect them to be rusty. Bead blast it. Paint it. Should be fine after that. GD
There's tons of threads about it, but the issue with the gaskets is very simple for your model. They leak oil. They need to be replaced with 642's. End of subject. The biggest issue isn't the gaskets or the problem with the gaskets - it's the procedure that seemingly can't be done correctly by the MAJORITY of shops out there. Including the dealers (they use the wrong gasket entirely). From head bolts being replaced (not required and frequently detrimental), to head bolts being installed in the wrong holes, to stripped head bolt holes, to the wrong gaskets and surface prep. There are many places to go wrong on this job and THAT is the problem. If you don't know what you are doing you can REALLY screw it up. GD
Hello from Massachusetts
GeneralDisorder replied to Mattbrat85's topic in Meet n' Greet. Your USMB Welcome Center
Excellent. Glad you got here. You'll find everything you need around here. Definitely post some pics and specifics on your Brat. It's not stock and there's few around like it. GD -
No - the 633 gaskets were used till 10. The few EJ25's made after 10 use the same 770 gasket as the turbo models. But this was only Legacy platforms in 11, and 12 models IIRC. None of the Forester or Impreza models got the 770 gasket because they switched to the FB25 starting in 11. Those have worse problems with insufficient ring tension leading to massive oil consumption which, ironically enough, requires an even more invasive job than replacing the head gaskets. The dealership solution is to replace the entire short block. Honestly the best used Subaru from that vintage that you can buy would be a manual (6 speed) transmission 2011 or 2012 Legacy platform. Comes with the proven EJ and factory 770's, and no early CVT problems. I can't think of any down sides to an 11/12 Legacy/Outback 6MT car. Except possibly the random 8-14 rod bearing failures that we have seen. Usually this is turbo models though...... The turbo Legacy GT have some interesting one-off parts and the maintenance work on those is expensive and time consuming with the front mount turbo. You don't want to know what goes into doing the timing belt and water pump on one of those. It's a beast of a job. I would own one, but then I'm not a typical Subaru owner either...... GD
