SubaruDave
Everything posted by SubaruDave
  1. brus brother - Thanks for the suggestion. Whenever I put new pads on I always put anti-squeal on the back of the pads as well as the shims. Usually there are no problems, not sure why there is this time. May pull the pads and try again.
  2. Hti-Johnson - Yes, I cleaned the pads and rotors before installation and then wiped the rotors down again after install. This is the first time I have ever had this problem. Thanks for the reply and this board is pretty neat. I have already found several useful hints and ideas. Thanks again! I work at Subaru of Indiana so I will ask some of the folks at the plant tommorrow for some ideas from them.
  3. I installed new front OEM rotors and brake pads today on a 2003 Legacy L. I used the anti-squeal lube on the shims, but after installation I still have a very noticable squeal from the right front brake. Squeal starts when brakes are applied, stops shortly after release. The caliper appeared to be in good shape and the I regreased the release pins before reassembly. Any ideas or suggestions on what I may have done wrong would be appreciated!
