later_Peter
Everything posted by later_Peter
(99 OBW) just came out of transmission shop. May need a new front differential... However, $1500 (minimum) on a 208k vehicle, although it is the 30th Anniversary model (heated leather seats, 2 sun roofs, heated mirrors & stuff)... NEVER had any major repairs so: a headgasket MAY happen (hasn't yet) has a problem when I get gas & it takes a moment to start up again... & then drives & starts fine until the next fill up & then... so... what to do? what to do?
living out in the country we find mice to be nearly everywhere. Mouse traps would be full everyday & decided it was also attracting more/new mice... found cotton balls soaked with peppermint oil & kept in a small jar with holes in the lid, would prevent the mice from coming back in... this is based on the "mice don't see as well as smell for direction... so, interfere with that sense & the draw for them is gone.
I went through 3 alternators before buying the Subaru re-manufactured one... no problems since.
- 7 replies
- 1
- Hot alternator
- low volts on alternator
- (and 2 more)
1999 OBW... 2.5 AT. 194k Runs smoothly & fine except: right after putting in gas (doen't need to be a full tank) it won't catch. Starts but as soon as I let off the gas pedal it stalls. This happens a few times (3-5) then it runs fine & continually start on first crank... Kind of like no fuel or no spark? Any clues/hints/wisdom? later, Peter
or you could buy it back from the insurance company... (a few hundred dollars) put on a new fender & a couple of doors (a few hundred dollars (depending on the wrecking yard/or parting out))... live with the dent in the back fender... good driver for "practically" free... (besides the other guy's insurance company should hand you a fine looking large check...)
Tires
later_Peter replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
depending on the model tire, I've never had tires last as long as Pirellis... I've had good luck with Michelins (but only as studless snow tires) -
yeah, I forgot the entire routine but something about turning the key from off to on (not start) a certain number of times, locking/unlocking the door... find that routine... it's easy then. an easy google search found this: Programming or Overriding the Alarm when you have lost the remote Open driver's door. Turn ignition key to 'On' Press and *hold programming button* in (see diagram, button under dashboard) After 15 seconds the the door locks will cycle 3 times. Do not release Programming button Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off. Follow the directions... I don't think I'm coming over to your house to set this up, either.
no comparable ones in the area? assuming it is a thousand dollar car front axels radiator flush (careful here this is a major headgasket culprit) fender door so you spend another thousand (now you're at two thousand) for a thousand dollar vehicle... (& if the radiator flush leaves air in the line.... figure another $5 hundred IF you do most of the work (you won't be planing the heads, I'd guess) good luck... & remember: "friends don't sell cars to friends & remain friends"
