Gender
Male
Location
Northern Wisconsin, WI
Referral
google
Biography
1997 Legacy EJ22 260,000 miles.
Intermediate skills -
Vehicles
Subaru Legacy 1997
igammie's Achievements
Advanced Member (3/11)
2
Gloyale "Biggest thing is to support the inner race of the bearing as you press the hub through. If not, the outer bearing race will be loaded by the force of the press." [i only wanted to quote that line...] Thank you, that is obvious; and I hadn't thought of it. Imdew, Given how little the parts cost and the relative ease of the job.... I'm not good at ignoring stuff, it's like an itch I have to scratch!
My gut reaction is to agree with you. If I got 260K miles from the old fashioned type..... The newer standard roller bearing is easier to install, but.... I'm undecided. Who do you purchase old fashioned tapered 'finger' roller bearings from? Which brands do you trust which have to best life in Subarus? Thanks! (I attached pics of the two types in case someone is confused - I have always called them finger bearings but I don't know if that was my family or universal?)
I see from attached Subaru service bulletin that Subaru changed specs from the 'Finger' roller bearings installed at manufacture to regular roller wheel bearings. I have the new part but I am concerned that the mating surface hub is radiused and that will destroy the oil seal it is against? That it will lead to premature failure? Anyone have any real word experience? Thanks!
Given that it is an seventeen year old car that has done 260,000 miles I think there is a good chance that the seals will have dried out and since I am taking the hub to pieces the extra cost of replacing seals is small compared to the increased life of the new bearing? Same reason I'll do both sides unless it looks like it was done before I go car (once I have it apart).
Has anyone tried these? Can anyone vouch for them? This is the link for my car: http://www.amazon.com/gp/product/B00DM9SZPI/ref=ox_sc_imb_mini_detail?ie=UTF8&psc=1&smid=A6JK0PO3GJYXY If not I'll buy the Timken part from Rockauto. FYI the Amazon part is $34 including seals and snap ring. The Rock auto is a lot more as you purchase each part separately. Thanks in advance. As you know the job sucks I don't want to save 50% and do it again next year. Pressed bearings suck!
I just put a new, to me (used rack}. I put in cheap power steering fluid as I intend to flush the system and replace. I have to assume rack and my handiwork will produce contaminants. How long should I wait before I change? I was thinking a month (I drive about 1,400 miles per month. Thanks in advance! If this is elsewhere and I missed it, sorry.
I set it by voltage... My scan tool is quite basic; I'll have a look and see if I can access that data?
