- 1988 Subaru XT, crazy no spark condition
SPFI running like crap
My SPFI wagon has had a issue for a month now Symptons: running like crap down on power wont idle without some throttle super rich, can smell unburnt fuel Things done checked tps ohm and idle switch checked CTS ohm replaced cap, rotor and plugs air/fuel filters good fuel pressure good IAC works correctly when tested.
Rear cv axle questions and compatibility, and sources for remaned ones
you can drive a long long time with a bad rear wheel bearing. I had one strip the threads holding the nut in, and ran it for 20k+ miles before getting a new control arm. Also you just need a giant hammer to get the axle out. Ive hit the axles so hard the car slides to get them out.
Seat belt module issues
Some how my seat belt module got wet. Can't find any for Loyales, found one for a Legacy with the same connector for the switches, but the motor connector is different. Should be easy to adapter that has its just power, ground and the 4 motor wires. Hoping everything swaps over, but I cant seem to find a FSM for legacys with auto belts. I found one but it stops before the page with the diagram. Any chance someone has it? I need pages 80 and 81 from this book. I have the Loyale and XT books with the diagrams.
Achilles Desert Hawk XMT LT 175R13 MT
Any one try these? They are the right size and MTs. I have the Forceum MT's and can tell they are narrower.
Tires for 13" rims
they are much thicker than normal so be aware the ride will be worst.
EA 82 No crank blows fuse
Could be the coil fuse.
2022 Various Parts Availability
This might sound dumb, but try cheap rump roast fluid. I used 80w90 out of a 5 gallon pail a buddy had. It was gl4+gl5 rated, smelled like hell. It made my trans so quiet I found out I needed a pilot bearing lol.
1987 GL Driveshaft Support Carrier Bearing Replacement
First post says 4 inch lift and EJ swap.
HELP! 89 subaru EA82 SPFI will not start.
If you need an ECU let me know, I think I have a manual spfi spare.
Got a sunroof?
You could also just get good tint on the glass, it will reject almost all of the thermal energy.
Anyone with a totalled or scrap brat ??
Yes also of you swap most the major components from one car to the other, including the vin plate, you get issued a NEW vin. You must show them both vin plated, attached and unaltered, and they issue you a new vin and a rebuilt title. Then your title looks crazy as they list all 3 vins on one. Been there done that on trucks. Swapping good cabs on to good drive train frames. Note if they catch you with an illegally altered vin, not only is it a felony, the car gets crushed. This is the federal government, they don't codswallop around. Do you not remember them collecting all the illegally imported GTRs and crushing them?
Tires for 13" rims
I run walmart douglas tires. They are like $45 bucks a pop, and I get over 20K a each even with a crappy rear alignment. You can also get the 165/80R13 Forceum MTs for <$100 each on EBAY when they are instock. They are durable as hell, and are truck tires rated for 40% more load than the normal car tires 1400 vs 1000 pounds.
Coolant Temp Switch
The 1 wire coolant sensor is for the gauge, and the two wire is for the ECU.
Ea82 to Ej22 Swap Questions
Start with 2 running cars if it's for first swap. Photo/video everything and write down everything. What I have always done for any swap is get the ECU/wiring out of the donor car, label/document all the connectors, and with any wire cut, label both sides! Then when the ECU and wiring out of the donor car. Plug it back into the engine and get it running. If it doesn't work you can go though anything you cut and have both sides. You can hook it all back up until it fixes the issue. Then with everything hooked up in the recipient car get all your measurements and wiring labeled while it's still running and you can test things. Don't do anything to the wiring in the car yet. Do the mechanical transplant next. Get it all in, plumbed and read to run. Then get it running with the unmodified hardness from the donor. It should work the same as when it was in the other car. Fix any wiring/fuel issues first so it runs fine. THEN pull the wiring out of the recipient car and merge the hardness. By doing it in stages and keeping it running at each stage you can reduce the possible issues to troubleshoot.
Ionstorm66
