![](https://www.ultimatesubaru.org/forum/uploads/set_resources_9/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
lichen
Everything posted by lichen
Thank you, gentlemen.
Paging Larry from Colorado Springs I lost your number, somewhere between the island and Grand Junction, which is where I'm at now. I may need an engine for a 2006 Outback. 808 937 4085 Please call me.
Update: I idled it in the driveway, until it began to get too hot. The fans never came on. Turned it off, then back on, fans came on, immediately cooled down. CEL flashing, obd-2 says front oxygen sensor malf, speed sensor malf, and neutral position sensor malf. It also says neutral position sensor high input and speed sensor malf 2.
Hi, guys. This car still has issues. It wants to overheat again. I just got finished replacing the head gaskets, and by the way, I have to climb about 2,500 feet elevation every time I drive home, in about six miles, so the grades are steep. It does fine down on the highway, but coming up just now, it began to get past normal operating temperature. The fans aren't coming on. I replaced the knock sensor, what else can it be?
I remembered that years ago, for some reason I had removed the pitch stop link, and knowing nothing about what it was, thought it must be normal that it was sort of z-shaped. I had to loosen the motor mounts to get it back in. This has been a problem all along! So after I took it out, I simply jacked up the engine a smidge, and it fell into perfect alignment, the starter now sounds normal again, the engine purrs sweetly again, and the vibration is gone. All well! Thank you so much!
1999 Legacy Outback, 2.5 liter engine, successfully replaced head gaskets. New water pump, thermostat, and knock sensor. Did the job without pulling engine. Used a floor jack to raise engine. The passenger side motor mount won't seat. Low-key high-pitch whining noise on test drive. What did I do wrong? Is it the cv joint not seating correctly?
Hey guys, I talked to Larry about this, but he doesn't know, or care, because he always replaces the 2.5 with a 2.2 when it has been overheated. I replaced the head gaskets, and it seems 700 inch-pounds is too much for the cam cap bolts. Feels like they will strip if I torque them that hard. When I removed them, they were nowhere near that tight. So what I want to do here, is torque them until I feel comfortable, and use red threadlocker to keep them there. Thoughts?
Codes are: P1510 P1516 P0106 P0440 P0136 I cleaned the IACV with MAF cleaner. It could be the timing, but after checking the numbers, it had new pulleys, idlers, tensioner, bolts, belt and head gaskets only 37k miles ago. This corresponded with a fuelling from a station we never use. But I don't know how that could be relevant. Contaminated fuel?
Hi, guys! We just picked up this 1998 Forester, previous owner parked it because it was overheating. It sat in the weeds here in Hawai'i for three years, and started right up. It also started to overheat on the way up the hill. I suspect the heads are warped because the coolant, after being forced into the reservoir, will not suck back into the radiator as it normally should. No steam out the tailpipe. No oil in the coolant. No coolant in the oil. The heater works. I suppose I should pull the plugs to look for evidence of coolant there. How else can I check for evidence the head gaskets are leaking? And lastly, maybe it just needs a new radiator?
