okamikai
About okamikai
  • Birthday 07/23/1981
  • Gender
    Male
  • Location
    San Juan, Puerto Rico
  • Occupation
    The Home Depot
  • Referral
    Google, various topics, engine swaps, compatibility issues, turbo mods
  • Biography
    Every day driver with love for subies, and other cars. I want to make my Forester a sweet riding street lady, and perhaps meet subie enthusiasts as well.
  • Vehicles
    1998 EJ25D (2.55L Forester)
okamikai's Achievements
Advanced Member
Advanced Member (3/11)
3
  1. the block cylinder wall has a pretty bad scoring mark due to the wrist pin coming off and it has already been bored to .020 (100mm) I was told that something could be done with it, but I'm not sure about it, I would like to weight my options...
  2. i was using 5w30, but I used 10w30 on the last 8 oil changes, that may have been it, also I used an oil treatment and let it run for too long in the engine, that may have been the problem, but i was told at the dealer to stick to 5w30
  3. Here's a pic of the score markings on the mating surface of the camhead, I was told in the dealer the this damage was caused by mixing oil types, turns out I was using the wrong oil from the beginning, and there was some dirt particles in the engine that worked their magic as well.
  4. If you saw the picture the score mark is pretty bad, I was doing some research and it happens that the ej251 block can be used to replace the 25d's block, and still use the 25d camheads, my question to you is, how true is this, and do you have either 251 or 25d cores, and for how much will you sell them? I mainly need the cylinder halves of the 25d, but I'm interested in making the 251 with the 25d camheads. Let me know what you think...
  5. the crankshaft bearings looked pretty bad although its been over 6 years since I did the engine work, I used ACL Race Series Bearings and I must say they have endured hell under my driving conditions, but besides the bearings everything else looks pretty good.
  6. And it scored! ... I was really lucky that the wrist pin did not reach the access hole, but I'm pretty sure it tried.
  7. Good news I went to the local Subaru dealer and spoke to a technician there, he instructed me to machine the mating surface of the cams and cylinder head to remove the groove marks. I hope this works, he also advice in changing the crankshaft bearings to be sure.
  8. I may be needing the camshafts, one of them is scored pretty badly, or if you can advice me into a head swap or something else I would really appreciate it. The core seems to be ok, as I said no metal particles in oil, but I ran into a stubborn cam retainer screw and the damn thing just won't come off, its already damaged so I guess I'll just grind it out. Once I can open it up I'll be able to tell if the cylinder wall is damaged, hopefully it can be honed out. Please any help will do, my baby girl will be born soon and I need this car running. Thanks in advance...
  9. Hi everyone, my Forester decided to let loose a piston pin retainer; found it in oil pan. So, I have to open the engine for inspection cuz it was knocking pretty bad. Didn't see any metal shavings or particles in oil so that's a good sign, but still I want to make sure nothing broke. Anyways, I'm posting pictures of the job, so if anyone needs an specific image of anything let me know.
  10. The Throttle Position Sensor could be bad, it sends a signal to the ECU that the throttle is open/closed so it can send the proper amount of fuel to the injectors. Its inexpensive to replace; around $50. You should try that before anything else...
