Everything posted by okamikai
If you saw the picture the score mark is pretty bad, I was doing some research and it happens that the ej251 block can be used to replace the 25d's block, and still use the 25d camheads, my question to you is, how true is this, and do you have either 251 or 25d cores, and for how much will you sell them? I mainly need the cylinder halves of the 25d, but I'm interested in making the 251 with the 25d camheads. Let me know what you think...
I may be needing the camshafts, one of them is scored pretty badly, or if you can advice me into a head swap or something else I would really appreciate it. The core seems to be ok, as I said no metal particles in oil, but I ran into a stubborn cam retainer screw and the damn thing just won't come off, its already damaged so I guess I'll just grind it out. Once I can open it up I'll be able to tell if the cylinder wall is damaged, hopefully it can be honed out. Please any help will do, my baby girl will be born soon and I need this car running. Thanks in advance...
Hi everyone, my Forester decided to let loose a piston pin retainer; found it in oil pan. So, I have to open the engine for inspection cuz it was knocking pretty bad. Didn't see any metal shavings or particles in oil so that's a good sign, but still I want to make sure nothing broke. Anyways, I'm posting pictures of the job, so if anyone needs an specific image of anything let me know.
if idle is fine but if feels lacking power you should check the following: - Air Filter - Fuel Filter - Fuel Pressure - Check Brake Pads for uneven wear, this may be a sign of calipers sticking - Loose or Cracked vacuum hoses - If the Cat is burned up its definitely clogged and it will affect performance noticiable
Pulling the engine out is not a difficult task as long as you have the right equipment. I just bought an engine hoist for $150 at Pep Boys with 1 Ton capacity, way more lifting power than what is needed for the job and for a very good price. Detailing the engine and doing repairs has never been easier. You should get one if you plan on doing this sort of jobs yourself and save some serious dollars on labor.
- 17 replies
- EJ22
- Timing belt
(and 2 more)
Tagged with:
My 98 Forester had the dead spot issue, I replaced the TPS, and with the car on, I calibrated the position of the throttle until it was purring like kitty, hasn't failed since. I will take the advice of cleaning the MAF and IAC for better performance, but where is the IAC located at?
- 30 replies
- ej22
- Impreza Outback
(and 1 more)
Tagged with:
Glad to help, I hope that all Legacy MT 09+ owners can benefit from this info
- 45 replies
- transmission
- differentials
(and 1 more)
Tagged with:
Hi, did you recently fell on a hole? if yes, the tie rods may have gone bad as well as the control arm bushings; and just as nipper said, if the ball joints and tie rods have never been change it may be a good idea to do so; Salt on the roads can speed up corrosion on these parts and it can also cause the rubber to crack it they are original-old.
And this might be important too http://www.cars101.com/recalls.html
- 45 replies
- transmission
- differentials
(and 1 more)
Tagged with:
I don't know much about the issue, but this seems like a pretty genuine article http://wheels.blogs.nytimes.com/2010/07/23/subaru-recalls-outback-and-legacy-for-transmission-problem/?_r=0
- 45 replies
- transmission
- differentials
(and 1 more)
Tagged with:
