2
subnz last won the day on February 11 2018
subnz had the most liked content!
About subnz
- Birthday 11/15/1956
Contact Methods
MSN
sth50100@gmail.com
Gender
Male
Location
Glenorchy New Zealand
Interests
Outdoors Ski kayak mt bike camp hike
Occupation
Jack of all trades master of none 45years DIY car / farm vehicle fixer, farming, construction, driving taxis buses now in tourism / hospitality
Referral
Google
Biography
Hi From New Zealand 26 years of Subaru ownership.1983 GL Ea81 wagon DR . 1986 GL ea82 wagon DR. 1988 GL wagon. 2001 Outback ej251 Manual (D/R). 87 Brat Ea81 4MT DR (have) 06 Outback 3.0R wagon SI Drive facelift paddle shift (current)
Vehicles
06 Outback 3.0R SI Drive facelift. 87 Brat 4MT D/R
subnz's Achievements
Eat, Live, Breath Subaru (5/11)
49
Failing universal joints on rear drive shaft usually cause vibration, particularly noticible at 45 -50 mph as you mentioned, so check both front and rear joints for side play and also check carrier bearing on drive shaft as well.
- 20 replies
- differential
- driveshaft
(and 1 more)
Tagged with:
Failing bearings in diffs whine continuously -- the whine increasing in pitch and volume as speed increases. Worn diffs still whine not being driven so disconnecting the driveshaft / FWD fuse may not isolate the whine - it may lessen it. You have answered that question by being on or off the throttle and and not making a difference to the whine. If its the rear diff, the whine will be obviously coming from the rear. And front diff whine from front. Agree also - failing universal joints etc in drive shafts vibrate - most noticable at a constant 55 / 60 mph - maybe less noticable on a trailing throttle decelerating (under engine braking) - balancing changes due to side play / wear in joints
- 20 replies
- differential
- driveshaft
(and 1 more)
Tagged with:
If its not a fuel issue then, after investigating the obvious - fuel filters /gauzes fuel pump / pressure etc. Then agree it could be a hi tension leads (ignition) issue. These can break down under load and performance becomes progressively worse when these get warmer / engine approaching running temperature. (when failing) Have had two different vehicles that have done this ie failing leads / coil (not Subarus) Another thing to consider is carburetor icing. Is the diaphragm operated flap on the air cleaner intake working correctly? ie to pick up warm air when required to prevent icing. Was the vacuum line reconnected /air temp sensor? If it has a manual summer / winter flap lever on air cleaner intake, try setting it to winter position. This is what my 87 Brumby (Brat) has. That diverts air intake off engine - warmer air to prevent icing. Icing Symptoms: jerking, surging, loss of power, getting worse as more throttle applied, coming to a stop - another type of fuel starvation. This could explain the momentary improvement after stopping with the heat in engine bay melting icing
IF guideline are followed regarding cooling system maintenance for EA82s - as stated in owners /service manuals. EVERY 2 YEARS - change coolant . remove radiator hoses , and heater hoses at firewall to flush out heater core as well (with garden hose) Flush radiator and engine separately as well with garden hose. replace thermostat / radiator cap if necessary. If these guidelines / recommendations are followed then there should be few if any issues. Both my 2 ea82s had cooling system issues and it was due to neglect / lack of maintenance from previous owners. As these are prone to overheating and consequently blowing headgaskets (particularly EA82T with extra heat generated with turbo) if regular maintenance is overlooked / neglected.
thrust side must alter left to right case?
subnz replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would assume that because the of the position and the firing of the spark plugs from the top - the thrust side would be on the bottom for all bores / pistons. But not sure considering the clockwise rotation thing and the difference between left and right sides , if any ???? I would still position the ring gaps as per the diagrams as we have previously discussed in the manuals. None of the gaps are are positioned directly near the bottom or top sides. 30 degrees below / above the centre line (either side ) is far enough away from the thrust areas, top or bottom, in my considered opinion. / -
Who knows EA82 ring gap spacing?
Looked at my Gregorys manual for EA82 and the diagram there, for piston ring gap position was similar to the second diagram (above) that you posted. ie the 2 compresion ring gap positions - both 30 degrees below centre line - left for top and right for second. and the 2 side rail gaps for oil ring at 30 degrees above centre line - left for top and right for bottom side rail. The top (1st) diagram that you posted are the ring gap positions for the EA81 according to Gregorys manual also -
87 GL EA82 wagon - new to me running problem
subnz replied to DaveT's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Agree also if not a fuel issue or not a blocked cat. It could be a coil / distributor / leads etc issue. If it runs ok when cold then gets progressively worse when up to running temperature and when under load (hills) Look at coil (these can break down and fail under load and when warm also with intermitant random inconsistant misfires ) and also look at obvious stuff like rotor / distributor cap / and all 5 high tension leads - to spark plugs and coil to distributor and low tension wiring / distributor module etc High tension leads can break down under load causing misfiring getting worse under load and when warm / hot (like failing coils also), particularly if old or are of cheap replacement quality. -
Radiators work by transfering heat from water / air / refridgerant that was hot in the first place that needed cooling. Their surface area with airflow is for dissapating heat away -They don't work well in reverse. Most roof mounted solar heating systems use long lengths of black hose coiled back as forth to create surface area to induce heating.
Agree anything with a phase 1 EJ 2.2 (non interference) engine with a manual transmission. If I had bought a Legacy of that age ie 90 - 95 it would have been 2.2 GX manual D/R Wagon (available here in NZ) These here have a good reputation for longevity. But Legacy low ride height made me keep my 86 GL wagon till 2009 when structural rust around windscreen put it off the road (regular 6 monthly compliance road testing for older cars strict on rust here in NZ) Then bought 1st Outback.
Still have breaker points distributor and original hitachi carb on 87 EA81 Brumby (Brat). Can't be bothered changing either because they both work fine.
Completely original and clean vehicles should always and can bring the highest prices. As soon as they are modified from original (including repowering with larger later engines) the price should come down accordingly. You only have to look at the original unmodified American classic car values market as an example.
EA82 distributor and timing
subnz replied to Loyale_93's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Agree check T belt timing - there should be one cam sprocket with mark at the top and the other cam sprocket with its mark at bottom (180 degrees of difference with crank on its timing mark. If it still doesn't run it is also possible that the distributor could be 180 degrees out of phase with engine or also agree leads connected up in the incorrect firing order.- 19 replies
- 1
- distributor
- timing
(and 1 more)
Tagged with:
Agree keep engine between 3000 - 4000rpm for cruise best for power / economy / longevity. Most modern Japanese OHC 4 cylinders engines need a minimum of 3000rpm before they start to work properly ie start developing reasonable torque / hp. Have had two EA82s. EA81 OHV (old school tech dating back to steam engine) need less rpm to do the same thing ie best between 2500 - 3500rpm. Have had 2 still have one of them - bomb proof simplicity / reliability so long as don't over rev them.
Guys, like 95% sure it is restricted exhaust.
subnz replied to kmpdx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
What is the exhaust pressure like at tail pipe? Put your hand over tail pipe briefly while engine idling , to get an idea of exhaust pressure - should feel strong even pulses for each cylinder firing. Have done this in the past to diagnose / feel / listen for valve problems as well ie burnt out failing exhaust valves.
