HASx11
Everything posted by HASx11
Where? How?
HASx11 replied to CaityP's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Something similar happened to my father-in-law's Baja when he had it. He was on a bike trip in Maine and someone stole his gas door cover. -
97 obs issue
HASx11 replied to HASx11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yes I’ll make sure to not do that. I know how little space there is between the pan and the solenoids. -
97 obs issue
I have done the 3x drain and fill with the trans x when I bought the car which helped a lot but never went fully away. I figured it was gonna need a transmission hence why i have a spare. Besides this this car has been the cheapest car I have owned more so then my legacies and my forester -
Hey everyone I have a 97 obs with 270,000 miles and it has an issue when I let off the pedal. It doesn't happen all the time but when it does the car does not respond when I press the gas for a second or two and then it will thud into gear. When it's doing this it feels almost like it braking and the rpms drop slowly. Just so you know I have owned this car near 4 years and have put over 80,000 miles on it. The brakes, calipers, drums, and shoes have been replaced over time. It has been doing this since the day I drove it home. The transmission fluid was a thick black sludge almost when I first for it and besides happening on and off had never been a issue but I have noticed it getting more and more frequent. I have a spare transmission was just wondering if anyone else had a thought of what it could be. Thanks
I have a 2005 Subaru forester that is mifiring so much that if I put it in gear it cuts off within a few seconds. The misfire is on cylinder 4. I have replaced the plug wires in had I had an obvious break in the cylinder 4 wire and this got rid of the misfire originally. It's my 3rd car so it's only driven once or twice a week and it sat for over 3 months due to the brake lines going out. It ran rough after sitting but cleared up and it's been driven with no problem since until now. The wires were NGK
Thanks bushwick for the video I'll take a look at my evap canister and go through my vaccum hoses for leaks.It does leak coolant out of the passenger head gasket right onto the exhaust. I check coolant level and all fluid level once a week or more depending on how often I drive the car. The forester is my back up car so it only is driven once or twice a week at the moment. It only drains the reservoir in about 5000 miles of driving I do check the actual radiator and hasn't been low yet.
So since cleaning it all up I haven't seen any more signs of coolant in the spark plug holes. The only issues now are if I turn my vents on outside air I get an overwhelming coolant smell that doesn't happen if I have it on recirculation. Also I have some check engine codes p0171, p0457, and p1443 these came up shortly after I replaced the plug wires. And every once in awhile I have to hold the gas pedal down to start the car after full up.
I hope I am not some 11 year old lol! I bought the car back in September the previous owner passed away and I bought the car from his daughter who said the car sat from April 2017 til I bought it in September before that she drove until she bought a new car. I have stacks of papers on the work done to the car I would have to look through but I know the radiator was replaced shortly before it sat as well as the entire steering system. The head gaskets leak but not too bad it burns and leaks about 2.5 quarts in 5000 miles. It runs great except when it rained and it would misfire. With new wires that doesn't seem to be an issue anymore. I also replaced the coolant back in October when I had to replace the oil cooler lines that were rusted. The control arms and axles were replaced a few months ago.
Hey everyone I have a 2005 subaru forester with 188000 miles on it and it's an auto. I was tracing a misfire on cylinder 4 which I noticed was break in the plug wire. So I decided to replace the wires with NGKs. But when I pulled each wire they were covered in coolant and oil. I was planning on replacing the valve cover gaskets and spark plug seals anyway but I was wondering if anyone has seen coolant in the spark plug wells before. The car runs great and only loses a little coolant. Thanks, HAS
I hate to disagree with you on a 2005 couldn't leak coolant via headgasket but my 2005 forester leaks coolant from the passenger side gasket not oil I have all the service records from the original owner and second owner and the head gaskets have never been replaced. Now I know my forester could be a rare case but I am just saying that it's not 100% not possible for them to leak coolant from the headgasket.
So it ended up being the thermostat it was not a oem one. For an aftermarket one it lasted more then 3 years and 60k plus as I am not sure when it was last replaced. Who ever replaced it last though used a lot of gasket maker it took a good amount of scrubing and scrapping to clean it all up. The car is running good now I'll keep an eye on it for awhile to be safe. Thanks everyone for the advice and help.
I'll take a look at the grounds and check the fans again. There is no bubbling in the coolant that I have seen. I have a code scanner that allows me to run diagnostics so I drove around until it started to rise and was able to see the temp rise. The car does have a couple electrical glitches such as my dome light only works on door not on and my windshield fluid sprayer works intermittently. I was able to get it to start to overheat by just turning off the heat on my car and I could get it to drop by putting it back on on high.
I am not sure on if it is oem or not but I have owned the car for three years without issue and I know the guy who worked on it before I owned. I should have mentioned I have been cheking the coolant level via radiator I learned that lesson when I was 18 and I filled the overflow bottle instead of the radiator and blew the engine on my dad's Nissan altima. No visible leaks or loss of coolant to my eye. I believe the fans are working at least they where when I checked at the start of the issue. The car can idle all day without issue seems to be more when I am driving between 20-40 miles an hour but still happens less often at other speeds. I plan on replacing the thermostat with an oem because I don't know when it was last done in the car and to see if it's my issue
Hello I have 97 impreza obs with 252000 miles where the temp gauge is fluctuating between At temp and 3/4. The hottest it got was 226 and it does no matter the speed but worse when driving around town. It is a gradual rise in temp it doesn't rise until driving for awhile it won't at all if I have the heat on full blast. I was thinking possibly it is the thermostat but I know these engines can develop headgasket issues towards this mileage. just wondering if my thinking is correct. Thanks, HAS
