About nakedandfam0us
- Birthday 05/26/1986
Gender
Male
Location
muskoka, ontario
Occupation
Electrician
Referral
motor swap subaru forum
Biography
few subarus over the years, bent valves and blown bearings. good times
Vehicles
00 outback limited
nakedandfam0us's Achievements
Member (2/11)
Putting a 2002 ej251 out of an impreza m/t into a 2000 outback a/t. Why, oh why, is the timing different between an auto and manual? I have a fsm for a 2000 legacy. FSM: Ignition timing [bTDC/rpm]: MT vehicle: 10°±8°/650 AT vehicle: 15°±8°/700 Also, I was planning to swap the injectors between the two. Looking at the FSM it shows just an o-ring seal for the a/t, an o-ring and insulator for the m/t. Anybody know what that's all about? Thanks! The build is coming along slowly but quite nice.
Good to hear. I did notice a difference in the cam sprockets so the car specific set are cleaned up and ready for install after my gates timing belt kit arrives. I will order some new injector seals (appears to be 3 seals per injector, 2 into the manifold and one fatty o ring into the rail) and swap for the newer set of 4. I'll get some pics up as well for anybody else going down this path. Thanks
Okay so leave em alone, just new o rings. Sounds good. Follow up question: I am mid-motor-swap putting an 02 block in a 00 car. I was advised on this forum to leave ecu, original intake manifold, cam and crank sprockets. The injectors on the 02 manifold which I am not using are 1. newer and 2. different colour/part number. (I can go copy numbers down if needed) I'd rather use the newer ones, I mean, why not right? More squirts away from death, and possible an improved design. Is there any reason why I can't? Ej251AXAWL 2002 motor from TS, car is 2000 outback ltd Ej251AW3AB.
Here is a price breakdown of what these bits cost, figured I'd take a minute to scribble it down for anyone else going down this road. I am in Ontario, Canada as I'm sure prices differ regionally. From local Subaru dealer- The two seals I questioned about above total $18. Thermostat 78deg $26.20 Oil pan $66.08 V-belt $21.58 (mitsubishi) a/c belt $27.90 (gates) rear main seal $16.66 water pump gasket $3.40 oil seperator plate $21.79 bolts for sep plate $0.39/ea from ebay Gates timing belt kit TCKWP304 with waterpump $172 USD + exchange + import + shipping + tax = $221.64 CND from local auto parts shop (+tax) Valve cover gasket kit $50.36 (with spark plug seals and 10 bolt grommets) Fel-pro intake manifold gasket set $12.54 Knock sensor $132.55 Front main seal $18.71 PCV valve $4.93 don't forget plugs, wires, oil, filter, coolant, engine cleaner, sand paper, anaerobic sealant, rtv sealant.... prices vary by quality. I'm still under "budget" (had a dollar figure in mind to get this car rolling) but certainly costing me a little bit more than expected. reassembly beginning today
