rocketman
Everything posted by rocketman
  1. Its so bad where I am near Canada in the salt belt,I had to throw away bushings and tensioners,to keep from seizeing, and lots of grease.
  2. Oh and take Sparks out first just in case it is hydro lock, you don't want to bend a piston connecting rod,been there done that!
  3. Mine jumped a couple of teeth,so I put a belt gaurd on it,never happend again,mostly for standerd trans cars.
  4. I may be wrong on this,but I put dielectric grease on my boot connections,maybe some else will chime in here.
  5. Did you do what GD said, put oil in cylinders and crank a bunch,this will oil the valves and rings?
  6. Take head into dark room,shine flash light into exhaust port, do you see light coming threw? Maybe sticky valves,oil them.
  7. Sounds like spun rod bearing from very low oil, does oil light come on a lot?
