Junkie
Location
San Luis Obispo, CA
Referral
subaruoutback.org
Biography
Rebuilding a totaled 99 4EAT Outback, in the process of lifting it and building a tube bumper
Vehicles
99 Outback Wagon, 4EAT, getting lift/tube
Junkie's Achievements
Advanced Member (3/11)
4
I have a 99 Legacy Outback. It could use some better struts, so I picked up some 04 FXT struts not too long ago. I'll probably be installing them next week. I also have some 1/2" strut top spacers. Between the two, it should be a moderate lift. My plan is to set the front to as much negative camber as I can, as long as it is even (or close) on both sides. I don't imagine it'll be enough to cause any significant wear. Is it possible to run two sets of camber bolts up front? If so, are there any modifications needed? If I do that, it probably won't be all the way negative. In the rear, there's no way to set camber from the factory. I grabbed OEM camber bolts from the junkyard. Do I need to oval out any holes to use them, or should they work fine with no changes? I'll probably set the rear up with a little less camber than the front. What's the best toe spec to aim for? How about camber? I can deal with a little extra tire wear if it handles better.
I just pulled off my skid plate and bumper because I plan on building a new bumper, and found a fair size dent in the oil pan. Apparently I didn't support my skid plate well enough and it hit the oil pan pretty hard. This most likely happened a month and a half ago at the dunes, I know I landed pretty damn hard once. Probably 1000 miles on the car since then and I haven't noticed any problems related to this. Do I need to replace it, or should I be ok with just beefing up the skid plate so that it doesn't get any worse? If I need to replace it, what oil pans will bolt up? EJ25D in a 99 Outback wagon. Thanks for any help.
After a rutted hillclimb that wasn't so kind to the car today I noticed that on articulation or hard left turns there's a single click. On turns it'll only click once, and only on fairly hard turns, more likely if there's a bump. Doesn't do it at parking lot speeds, even at full lock. My first guess is a broken front swaybar. Is that at all likely? Suspension is all stock.
I thought the OE style plugs were the best option, even though they're expensive. I think it's the PFR5B-11 plugs that I was told to use. Besides, since they aren't the easiest to replace I'd rather run something that lasts longer than copper - my old Integra was a different story. NGK plug wires are the best choice as well. When my car had bad head gaskets it still drove fine. Made the same power as far as I could tell. Not that it was ever fast, but it was no more sluggish than usual. I never ended up with black stuff in the overflow as far as I can remember, even though I was driving it around for a while with blown head gaskets. When they blow, they tend to push exhaust into the coolant and therefore push the coolant out. You can get away with driving on it for a while as long as you make sure it doesn't run out of coolant. You have the EJ25D, right? Meaning a DOHC engine, it's easy to spot.
When it comes to engaging I was mostly wondering what wiring needs what in order to engage the clutch. I'm sure I can figure out a way of turning it on and off. I agree on a scuba or welding tank, I think I'll be able to find one pretty cheap (or might use one I have) I'd rather use the factory compressor rather than one from another car if possible. That makes mounting and belt very easy. I don't expect I'll use this very often, so a small oil reservoir would likely last a long time. Or, I could have the inlet (with the oiler) lower than the outlet (with the oil separator) so that it automatically recycles the oil. I know other people have done similar things, I was curious as to whether anyone has done it using the compressors that Subaru uses. One of the main questions I have is what pressure the AC compressor will put out.
Has anyone set up the AC compressor to act as an air compressor? I never use my AC and have had the condenser removed for at least 6 months. I'd like to be able to air my tires up and maybe even use air tools every now and then. I know that I'd need a filter and then something to oil the air before the compressor, and then a manifold with fittings and a pressure regulator after the compressor (and maybe an coil separator). I'd consider running it to a tank, I know that a lot of AC compressors run on the order of 300psi so either I'd regulate it before the tank or use a high pressure tank (intended for SCUBA or welding or whatever, and capable of much higher pressure). How would I control the clutch on the compressor? I wouldn't want it running all the time of course. I suppose a manual switch would be fine, but don't know which wires on the compressor do what. If it matters I have a 99 Legacy Outback, which uses a compressor designed for R134a. Thanks for any help.
Did you ever do this? How well did it work? I'd like to do it on my 99 Outback, AC has been ripped out for a while but I still have the compressor.
As it rolls off the showroom floor a 1st gen Outback has around 1/4" clearance to the strut tube, on 205/70R15 tires. If you run some 1/8" spacers you should have adequate room for 215s as long as they don't run into the perch. I figure if I get the 3" backspaced wheels I'll have plenty of room to the tube, hopefully enough to the perch (depends on tire size).
235/75R15 is going to require a lot of trimming even with lots of lift. I'd rather stay with tires a little smaller and significantly lower ride height - I don't think I'll get rid of my factory body lift, but I'm not going to add any more. That limits me to 2" over stock at the highest. Trimming is fine, though. There are pretty good choices in 215/75R15 and 225/75R15.
