10
Everything posted by RustyBrat
i actually have another project in mind for it... and i will make it compatible my subie has a weber already, but my PUG does not
ahh... i kinda figured something like that but you never can be sure
im sorry but... you "meowed" a seal yesterday? what in the world does that mean?
finished up the switch panel today! i think it looks pretty sweet! the main power switch and the starter button are good, but the 8 toggle switches are going to need replaced, i bought cheap ones and it turns out they are complete crap. so i wont have this panel wired in for a while, but as soon as i can get some good switches it will be in use the key is still hooked up so it will still run. also i moved the mounting points on the strut hats as much as possible, and it fixed the camber as much as its going to get. to me, thats an acceptable amount. also, i wont be keeping a strut setup anyway. this summer when i have a job i will get some coilovers for it, so when i build the mounting points i will fix the camber. im thinking ea82 coilovers might be strong enough? if not i might go dual ea82 coilovers or dual vw coilovers. but anyway its good enough for now. oh also i built a plate to cover the ash tray hole, and a plate to cover the glove box hole, which i will be cutting a hole in so i can mount the radio there.
really? I'll take it if you want to give it away...
everybody wants webers, just post it for sale
im going to modify my hats tomorrow and see what i can do
the strut hats on mine are causing the issue, i just cant afford to buy any parts at all, 2 axles kills it for me
Going to pick up my barn find 1978 BRAT
RustyBrat replied to Rinker1989's topic in Historic Subaru Forum: 50's thru 70's
4 inch lift is easy -
so i finally got all the stuff i ordered. valve cover gaskets, main power switch, and push button for the starter. today i started building a steel plate that will go over part of my dash to mount all the switches to. (see pics) i think its turning out pretty sweet, it will be painted the same green as the body. im going to have quite a few switches in there, coil, fuel pump, lights, etc. tomorrow i will get the valve cover gaskets in and the dash wrapped up, then take her for a spin!
thats a veritable diamond in the rough! -
oooohhhh... well... never mind then... thank you for the info, but i was hoping it wouldnt be that much work! i just want to correct my camber, cant seem to do it no matter what i try
i dont think thats been done before, but blaze a trail!
Ahem, Idaho is the GEM state, NOT the potato state thank you very much -
Im going to be widening my control arms in the same way, but i wanted to know first if you have had any problems with it?
if the different diff has a different number of teeth on the splines, you have to make some hybrid axles, which really isnt that big of a deal. its impossible to change gear ratio in the stock one, because nobody makes aftermarket ones
Just First Generation Subaru Photos!
RustyBrat replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
yes, as far as i know the Reagan BRAT is perfect -
i shall! thank you!
- 169 replies
- 1
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
dang... alright well its awesome nevertheless!
- 169 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
*gasp* are you going to be selling those?!
- 169 replies
- Loyale 2.7 Turbo
- Rear Park Brake
- (and 8 more)
just swap in the rear diff from the donor vehicle, and quit using all caps haha
What about idaho? -
Another 78 brat! Yay need any parts yet? Haha
