Bagelton
  • Gender
    Male
  • Location
    AZ
  • Interests
    gl
  • Vehicles
    1984 Subaru GL Wagon
Bagelton's Achievements
Newbie
Newbie (1/11)
0
  1. I have a stock 1984 4wd gl wagon i want to put rear disc brakes onto instead of the stock drums. should i swap other suspension components along as well or will certain later subaru rear disc hubs bolt on?
  2. I have a pretty much stock 84 gl wagon 4wd that i have had electrical problems with in the past, and am planning on redoing most of the essential electrical system soon. i have not heard of this old "external" to new "internal" regulator swap that you are mentioning and am wondering if i should consider doing it as well? not exactly sure what you are talking about here specifically whether the alternator itself or a separate component but i am looking to modernize if i can and also have as many amps available to my disposal for peripherals like lights as well. is there a thread for such?
  3. I just bought a 4-Door 1984 GL Wagon with 164,xxx thousand miles. it runs and drives well, save for the lack of rear differential mount bushings making a racket in the rear end, the engine surging because the distributor is very sloppy, and the oil dripping from the power steering pump. The power steering pump seems to be leaking between it and the reservoir, so I believe I should be able to take it apart and re-seal it, correct? The distributor just needs to be replaced. The bushings I cannot locate for the life of me so I am looking for suggestions on where to get them or if I should make them. The owner I bought it from had just replaced the shocks and struts all the way around, the starter, got new tires, new seats, rebuilt the tranny, and replaced all seals and gaskets for the engine. This is the first Subaru I've owned, and auto parts stores don't seem to have the parts I need to replace, so where do you guys suggest I look? And what else, if anything, should I look into on this car that could be a problem in the future? Thanks for any feedback.
