stratman977
Location
Belle Vernon, PA
Vehicles
1988 Subaru GL Wagon
stratman977's Achievements
Advanced Member (3/11)
15
Had to get towed today
stratman977 replied to stratman977's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I ran it today in the driveway for a good 30 minutes and nothing happened. I also drove it locally about 10 miles and no blown fuse. I felt the coil and fuel pump and neither were even warm so its not heat related. The only thing different was the relay I changed. I need to stock up on fuses and go for a longer drive before I can trust it again. -
Trailer tires on a Soobie/Small car?
stratman977 replied to Subaruist's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think the 12" tires was unrelated to the orig thread it was just a passing comment. -
If you need 12" car tires you can get them reliably from here: http://www.7ent.com/categories/wheels-tires/tires.html?sort=featured&page=1 -
The alternator checks out fine. I suspected maybe it had some a/c ripple but a/c voltage was hardly measurable. I also haven't any odd behavior leading up to the handful of blown fuses since then. I also had the fuse panel out yesterday when I was looking for the relays and it looked ok to me. There wasn't any noticable corrosion. I did take the cover off the computer to see if there was anything obviously toasted in there. The circuit board looks great but I noticed the cover which would be on the bottom in the installed position had a spot of white powder on it. Kinda looked like an alkaline battery leaked in there. I was expecting to find a burst capacitor but theres nothing that looks like it would have went bad. This powder looks as if its been there for a long time though. I'm going to try to get another computer and see if it makes any difference but im not cinvinced that it will do anything. -
The wire that comes off of the magnet side of the relay runs into the ecu. Is all the ecu actually doing is grounding out the circuit to turn the fuel pump and coil on or is it doing something else in addition with that signal? I want to isolate the coil and the fuel pump from everything else and put them each on their own 15a fuse to see which one of the two is causing the problem. Just wondering if it will run with the computer bypassed? -
I found it, it's above the computer behind this metal brace for the steering column. I tore it apart and it doesn't look bad to me, nothing obviously burnt or broken. Not sure what to do next. -
So 3 weeks later and I'm still fixing this. I put in a new fuel pump and a new coil and I took it for a test run and sprung a leak in the fuel line. It had some rust where it goes through the support brackets. I make a new fuel line and again take it for a test run and low and behold I sprung a leak in a brake line. So I repaired that line and go for another test run. Of course, I blew a fuse. I made it home but I made unplanned 3 pit stops in 5 miles to change the fuse. When the fuse blows I can hear a click under the dash. The only other thing other than wiring in that circuit is the fuel pump relay. Thinking about it now the fuel pump isn't actually powered by that circuit, its through a relay. I found two relays under the hood by the vacuum check valve but none of those seemed to be it and there were 4 silver ones under the dash but none of those were it either. I was looking for the black and white wire coming from the fuse box and also testing for continuity at the connectors. Where in the heck is the fuel pump relay? If this isn't it I'm out of ideas. -
Occasional surges, and a code 51
stratman977 replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Code 51 is the neutral safety switch. I was getting code 51 intermitantly after an auto to manual swap because it was always in neutral. I wired in a switching relay to switch the computer from drive to neutral when the starter is engaged and this fixed that code. I would start with the temp sensor for the computer. This one always seems to cause erratic computer behavior. -
Very Rare FWD 1985 XT Turbo on Ebay
stratman977 replied to Beat Grinder's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just trying to help, I think you need to put a few more pictures on the ebay add. One of the interior, the engine bay, and one of the passenger side. The value in that car is the excellent condition that the body is in. I think you need to show off the condition a little better. If this sells its going to go to someone who had one of these in the 80s and wants it to bring back memories or someone who collects obscurities. -
I would expect donut tires to be equally as dicey to run as trailer tires. Plus the tread on those donuts are pretty much worn out in less than 1000 miles. Any fuel mileage savings would be spent up in rubber unless you had an endless supply of donut tires and nothing better to do. I have seen the demo derby guys run tall skinny bar lug tires on a donut rim and get amazing traction though. I could see that being fun in the woods but probably not so much in deep mud. -
You have to punch your car back into the system to navigate on there after you click on the link. It's comes in handy even if you don't buy from subaru. Heres the rear. http://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=1985&modelName=dlglgl10rsrxdl-wagon&ukey_assembly=6028557&ukey_category=54106&assembly=a10-281-b1
I'm having similar trouble. Thought it was the wiring for my idle air control valve. The iac circuit on mine was replaced with a new wire for some reason and one of the splices broke before so I was chasing that but it might be that temp sensor as the behavior you describe is consistent. I blew a fuel line this weekend and have to fix that first or I would go swap a spare into it to try. Any chance were you running an el cheapo replacement sensor from rock auto?
Chnaged out my fuel pump and ignition coil to hopefully fix the fuse I keep blowing on my 88 wagon. Those are really the only two major components on that circuit so hopefully one of them fixed the issue. I cracked the fuel line that goes across the back in the process and spent a few hours fishing it out of the support brackets so that it would be intact to bend a new piece. I was pretty rusted in the spot where it cracked.
