yankneck
Location
Lynchburg, VA
Referral
google
Biography
Just trying to get help figuring out code issues
Vehicles
1992 Subaru Legacy L
yankneck's Achievements
Advanced Member (3/11)
Alright, so apparently with this, Speed Sensor 2 refers to where to speedometer cable goes into the transmission. I knew the Speedometer wasn't working. I also knew it was because I didn't have it seated into the dash part, because I'd had the entire inner cable out. I cleaned it fully & then applied some Never Seize on it. Once I finally got it seated in the dash correctly, the code went away. Now though, the speedometer seems sluggish. Meaning it seems to go up slowly and especially slow when slowing down. Is there a way to lubricate where the gear us in the transmission itself, or is the NeverSeize an issue. I didn't have any graphite & just figured NeverSeize is slick as all get out, that it would work.
Ok, so following the directions here http://www.surrealmirage.com/subaru/trans.html, I came up with code 33 speed sensor 2. What on earth does that refer to? I did a search here, http://parts.riverheadbaysubaru.com/productSearch.aspx?searchTerm=Speed%20sensor%202&ukey_make=5806&ukey_model=89998&ukey_trimLevel=110403&ukey_driveLine=0&modelYear=1992&ukey_category=52093 and seemingly came up with AT. Control Valve. Which I tried to price at my local dealer & was told over $1,000. What am I in the middle of?
When I punch it, like to pass or stomped off the line, I get what sounds like metal on metal squeal that was not there before. I'm looking into how to translate power light flashing. When I start the car power light is solid for maybe 2 seconds then flashes 16 times. If it's something like the Duty C or clutch pack, would I be able to swap it off my original transmission?
Update Ok, I cheated. I took it to the transmission shop for them to locate the leak. Apparently, in my worry about the positioning of the holes in the bolt to the rear steel line, I didn't get it toght. They went ahead and tightened it for me, no charge. Honestly, with as sore as I am, I'm glad they took the 20 minutes or so because watching how hard it was for them on the lift, it would have been a PITA on the ground for me. I'm still keeping check, I think I still have a leak, just significantly slower. I may have to get an actual Subaru pan gasket. Shop said the rubber gasket doesn't usually work well on these especially with no sealant like the directions said. Thanks for all the help & support. Paul
Morning update. After approximately 25-30 fluid was off the dipstick entirely, leaking like a sive. Will get it up later to look. New developments. When I start the car, the green Power light on the dash flashes, never seen it do that before & I can't get any sound out if my radio even when playing a CD. Keep y'all updated.
Ok, I answered my own question. Putting 8 quarts in BEFORE starting was WRONG. It started pouring out around the dipstick tube where it mounts to tranny. I did a short easy test drive, shifted well & all. Then went to gas station about 5 miles away. After buying inside items & gas, I checked & I'm pretty sure it was showing low. I backed up & had a puddle on the ground. Drove home had no issues. Will check again in the AM. Whoever suggested ratchet straps, thanks a million. One through front doors & one around front fenders. That got it up enough to get a Jack under it. Then the addition of a skinnier friend REALLY helped get it mounted.
I totally get what you're saying about walking away, BUT I NEED it to get to work leaving at 5:30 AM EST. SO you add what you think it needs, then start and idle, then check. I was mainly asking if I start & let idle BEFORE I'm finished adding initial fill. I believe from empty capacity is 8.8 quarts. So I was wondering put 8 in then start or start after say like 6?
On the bolts to the steel return & supply lines, anything specific I need to pay attention to on those holes in the bolts? Yes, I finally got it down and out after 3 working days on it. Yay me now to get it up ugh ???? Old Replacement These were before I swapped the steel lines. The dipstick tube also got bent some, I'm hoping it's bent back far enough or should I swap those too?
