6
Everything posted by mcbrat
Was there more than one 4-lug Suby bolt pattern?
mcbrat replied to freedster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes. -
How do you make 2nd fan come on continually?
mcbrat replied to Camelwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the second (thinner) fan is the fan that came on AC equipped cars. it only comes on thewn the AC or Defroster is turned on (stock). I have both my fans wired to a dash switched relay. -
http://www.ci4wi.org/Portal/modules.php?set_albumName=mcbrat&id=PDC_0032&op=modload&name=gallery&file=index&include=view_photo.php I have about 5 new dents, including the fender
anyone use a harness/belt setup on stock Brat seats?
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
nobody huh? -
Water Pump and BIG Thank You
mcbrat replied to Bucky92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Paul, what kind of bracket does the AC compressor use to mount up... I've seen a few different kinds. the one I most see, is a complete one piece unit that is cast iron, and has 2 pulleys for the AC. a fixed pulley below the compressor and towards the center of the vehicle a tad. and the adjustable one for tightening the belt, to the left of the alt... if you have that set-up, and the bottom pulley is missing, I have a spare none of the set-ups I've had ever had the double pulley on a ea81 waterpump... got any pics? -
brat owners check this out...
mcbrat replied to tailgatewagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
okay, here is a preview of the new shirt design. I need to re-work it to include the B9 ans STI yet though.... when we do shirts this time, we wont have as many color optiosn, etc.... last time was a pain to coordinate because of all the different options.... -
that page is the old one. we will not be offering all theose shirts, etc... wait for the thread later this fall on shirts jeez, like kids in a candy shop ... -
yes, I copied the design, (I got one just like it off eBay) and had TheSuckerKing (board name) owner of "Flappy's Print Shop" print them up. we are kicking around the idea of having another shirt offering up, but were'nt thinking about doing the Brat one this time around. I have a new "Ultimate" design..... if there is enough interest for more Brat shirts, we could probably do some as well.... I will post something when all is decided.... -
about 14 mpg on my 5" lifted Brat. of course that's with a Holley 600 cfm carb on a non-stock motor best I ever got with a weber was around 20.
Paul, if that's the water pump I sent her, it should work. sounds like you are missing the bottom tensioner pulley??? I've never seen a water pump with the double pulley... -
my 87 Brat has 59k on it..... actually 3 of my 4 have under 100k.....
driving your 1600 more now due to gas prices?
mcbrat replied to mcbrat's topic in Historic Subaru Forum: 50's thru 70's
with hard town driving, I've getting 20 mpg, so I'm pretty happy with that... boy these 1600s sure can rev shifting out of first at 6500 is fun though the other night, I was taking some pretty hard corners, and I ended up blowing out the bead on my right front tire. had to replace the tire..... -
there's a couple on this page with the wrap around style.... http://www.ultimatesubaru.org/brats/bratcolors/bratclrs.html but they look like mostly 1 color decals though....
this is a door decal for Gen1's..... it came with the Gen2 Ski Team decals....
that's about the same price as a xt6 alt from the parts stores...
How do 4WD EA82s do in snow autocross?
mcbrat replied to Syonyk's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, here in Russ's area, before a storm hits, they just go ahead and spray down a brine solution just in case. so the streets are usually white from salt all winter, even if there's no ice/snow... lovely.... -
Leone is back. Check out pics!
mcbrat replied to EA82Turbo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you're talking about the rear diff swap, a 3.90 VLSD from a 91-92 Turbo Legacy will bolt right in. it's stub axles are held in with a c-clip, instead of the bolts that the EA diffs use. -
Hey folks, looks like I'm gonna be in WC, PA for work on Oct. 3-5. for work. looks like they've even got night stuff planned for us, so not sure if I'll have any time to meet anybody, but just for kicks, who's close......?
Stripped Valve Cover BOlt!!! AHHH
mcbrat replied to Numbchux's topic in Old Gen.: 80's GL/DL/XT/Loyales...
put a big ratchet strap around the engine -
I currently have the drivers side one still hooked into the PCV valve, and the pass side on has it's own filter.
I just happen to have this for you http://www.ultimatesubaru.org/80s/mick/paintchips.html
looks good Kurt....
that's where my second battery is sitting my engine bay is no different, with the weber, or the holley (except the holley takes up more room, and eats more gas)
