11
Everything posted by mcbrat
SRX rally hatch pictures
mcbrat replied to legacymax's topic in Historic Subaru Forum: 50's thru 70's
I have brochures I can scan I've actually been trying to get hatch measurements so I can make some..... and there are some pics in here of some brochures... -
Modifying the XT6 alt to work on an 88 Engine
mcbrat replied to mid-knight's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/80s/mick/mick-usrm/xt6-alt-swap/XT6alt.html -
engine cross member blocks, and strut tops are 4" radius rod blocks are 3" I think. maybe 3.5" steering extension is a longer you will still need to trim (or gently fold back ) the rear of the front wheel wells....
What d'ya mean ya didn't get one?
mcbrat replied to ezapar's topic in Meet n' Greet. Your USMB Welcome Center
Very nice! -
is this what you saw? http://www.nicksgarage.com/cars/rampage/rampage84_01.jpg
2 XT6s in my work parking lot!!!!
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the white one I saw is a full time 4wd with slushbox.... -
I've maybe only seen 1 or 2 of these in Des Moines, over the past 6 years, and there's 2 in my parking lot now!!! a white one and a maroon one.....
cool! let me know if there's any Brat specific parts you can't find out there....
and you'd have to use the turbo legacy axles, as they had cups on the inner ends. all others I believe had the stub as part of the axle, and it went in with C-Clips
How do I remove the lower control arm pivot bolt?
mcbrat replied to markjs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
shouldn't have to remove the steering link for the axle... to remove the inner control arm bolt, I've always just take the nut off, and used a punch to punch the bolt back out towards the front. (ea81/ea82) -
Having Stock rims widened?
mcbrat replied to subarunewbie2005's topic in Old Gen.: 80's GL/DL/XT/Loyales...
not in the case of wagon wheels. the ea82 wagon wheels have .5" more backspacing, pushing the tires in closer..... -
waste of time and money, when you can get a wide aftermarket 6 lug wheel and drill it, or do the 6-lug mod on your hubs.... you can run 225 width tires on the 14" steel pugs without any problems too... and with increased width (and traction) you have a greater rolling resistance. -
bump
there are a bunch of pics on this site.... click the home page link in the gray bar above, then on the side of the home page under navigation links, there is a Subarus of the 80's link. click it. on that page, there is a Pics from ProjectRudy link. lot's of pics in there, including EA81 RX... or just click here... http://www.ultimatesubaru.org/80s/projectrudy/rudy.html
Proportioning valve changes on rear disc swap?
mcbrat replied to freedster's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done a few of these as well, and the braking is much better in my opinion. the soob has a dual diagonal system. Jerry (bratsrus) did a lot of research on the rear disk swap, and the actuating pressure for the discs is the same as used by the drums, so no need for a proportioning valve... -
Help! Trying to retrofit a/c in 85 Brat!
mcbrat replied to elcaminokurt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I did that conversion once, and it worked for a while..... did you create a vacuum in the system first? (I didn't which led to it's early demise I believe) I put on a different compressor, so the system was empty. I used a kit from a parts store, but only one of the fittings was covered by the adapters in it, but luckily, it was the only one needed... I just hooked onto the low side, and with the vehicle running/AC turned on to do the compressing, I opened up the vavle on the r134 charge/oil, and it sucked it in.... if yours isn't pulling in, you may have a bad hose someplace, and not creating enough vac pull.... -
okay, here we go.... here's the campground map. http://www2.mvr.usace.army.mil/Saylorville/CherryGlenCampground.cfm we have sites 69-74, all sites have electricity. bring firewood if ya got it.... I have to show up with a photo ID on Friday evening. if you get there, and I'm not there yet, give me a call 515.321.3709 I'm packing up some stuff tonight. my camping vehicle is going to be the SkiWagon.... here's the other map... http://www2.mvr.usace.army.mil/Saylorville/LakeMap.cfm I'll post some other maps I did later....
Check this out,.. Aussie RX Rally Spec
mcbrat replied to ausubaru92's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ausubaru.com/ausubaru/html/modules.php?name=Forums&file=viewtopic&t=4035&highlight=rx+rally+spec -
cool. good sized pic too. I got my copy in the mail today....
