6
Everything posted by mcbrat
and they will work on other applications (jeeps, soobs, etc...) http://www.dual-concepts.com/components/
it's where the bottom of the tranny mounts bolt into
they'reeee baaaccckkkkk....
meaning it's missing? (ea81 tranny crossmember?) Shawn used Jerry's kit which uses the stock ea81 tranny crossmember redrilled to fit the ea82 tranny mounts.
I'll try to get 'em re-posted out there......
we need to find new software that will work with the current version of VB. until then, the old version of it is here... http://www.usmb.net
no, I'm still using the same aftermarket fuel pump I was using with the weber... I need to put a weber back on mine for testing purposes to see what the difference would be between the weber and the Holley. too many variables changed at once. I just filled up my gas tank, so I'll be able to check mileage with the holley now....
I would assume you're not going to run a stock carb on a built motor, so you shouldn't need the computer then. My built up Brat doesn't have one at all.
Brian, ShawnW put a RX trans into his 83 TWagon. He had to get the specific anti-sway bar too as not all ea81s were the same. having the front axles made somewhere then? CVO or MWE?
or here are the ratios.... http://www.ultimatesubaru.org/80s/mick/gear-ratios.htm
you can plug in your tire sizes here for a multiplier.... http://www.miata.net/garage/tirecalcold.html
HELP!!! The Brat Tried to commit suicide!
mcbrat replied to SuBrat84's topic in Old Gen.: 80's GL/DL/XT/Loyales...
your arrow is pointing to the rocker arm, and the adjuster nut is at the other end (top of the pic) if it's actually squirting water from that bolt, then it soulds like you lost the head gasket and it's allowing coolant into the bolt passage... a cracked head could do the same thing. -
Ok tried searching couldnt find it
mcbrat replied to subarunewbie2005's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that was copied off a Internet page long ago, and is on Brians USRM pages, and under the Subarus of the 80's page, but does have some errors in it.... -
what about distributer. I had one go bad like that. just died. after cooling, it would start and run til it got warmed up.
can be done. Mudrat79 makes and adapter plate/kit. there's a forester with a D/R in it right now. ForesterRanger maybe????
Dual Cooling Fans in the Brat??
here you can see how the 2 fans fit. mine are closer to the engine because of the type of lift I have, but stock there is plenty of room.... http://www.ultimatesubaru.org/80s/mick/gallery/holley4.jpg -
EA71 Engine Variations?
mcbrat replied to Seahag1978's topic in Historic Subaru Forum: 50's thru 70's
ah yes. I remember seeing that specifically mentioned on a ea71 on eBay.... -
I know of these variations for sure.... 1. pre-80/early ea71 - solid lifters, starter on top 2. 80+ "fatcase" ea71 - solid lifters,starter on top. block case was larger. uses the same waterpump or oil pump as ea81 (I think). 3. 84?+ ea71, with bell housing that mated to ea81 trans. starter on side. 4. ea71 with hydraulic lifters. these were JDM replacement engines. I would assume they are 84+ vintage -
Superior Import Repair Inc 4443 NE 82d Portland, OR 97220 - 4917 (503) 288-8634 not sure if that's current though, as I know he just moved to a new location....
newbe with 1992 Pickup (+power steering Q)
mcbrat replied to Night Devil's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you can run a ea81 pump with a ea82 rack by having the hose fittings changed. none of the newer racks will be a bolt in swap, but could work if your willing to cut/weld/fab some custom pieces.... the newer racks are wider and tie rod ends different, so you'd need to find/make a combination to work..... do you have a better pic of the 4WD decal on the hood/bonnet? -
Ezra, yeah, it's a Brat. It would have just been a MV Pickup on your side of the world. you will need to try and find a PS pump Bracket (and mount bolts), lines, and rack (and possibly the x-member, but I don't think so) from any '80-'84 Soob Wagon, Hatch, Sedan, Coupe, or any Brat/Pickup from '82+ you also will need to get the t-stat cover and possibly the rad hose, as it will be longer to reach past the pump to the t-stat cover. Ideally a 84, maybe 83. the pre-83 ones have the line locations a little different, being older, are harder to get. your engine should already have the PS puimp mount holes tapped Welcome to the board! -
yep. no need to take out the driveshaft with the manual tranny. I've flat towed lots, and learned to always take the widest path around a curve. you may want to make sure your adjustable front suspension is turned down all the way. any positive camber will definitely make your wheels track like that.... I have also tried using some bungee cords to limit the steering wheel movement, with some success, but it hard to find places to hook to
