6
Everything posted by mcbrat
EA81 Front strut question???
mcbrat replied to stansgl's topic in Old Gen.: 80's GL/DL/XT/Loyales...
yes, those are the adjusters. you can raise the front end up about an inch that way. though you will encounter more stress on the axle joints with it up all the way.... -
need to check your transmounts. I had some bad mounts, and I couldn't get into revers if I was parked with my right side up a hill....
hard to say what ratio it is,as it had to be a custom conversion, but since it's a 1.8 turbo according to the listing, it's probably got a 3.70 ratio. The Brumbys came in REgular and "Sport" models. didn'tt think they had theDL/GL badging....
I don't think the ea81 sedan (80-84) came in 4WD in the US. If it did, it would have had an auto tranny mated to it.....
General Disorder has a buddy who was trying to make some MOMO adapters out of old steering wheels. I'm gonna have my friend do the same thing, using my true momo adapter (6 bolt) as a model the post you were referring to I think was for the Grant adapter which is a 5 bolt I think) it is available I think but very pricey....
ran into a snag while wiring my third eye.
mcbrat replied to subawoohoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had one once with a bad motor. turned out the motor case was cracked, and the gears weren't meshing. I have also had the solder connections on the motor go bad (bust, corrode away) When that happens, it's a bit harder to fix. the door hinges don't move on the one in my 80 wagon. I had been doing some testing, and got it to move. found the bad spots, and redid the wiring, but it still won't move. there's no door on it now, so it's just an extra light up front.... -
I would say that'd be top end for a rust free 2WD ea81 soob in the midwest....
well, that wiring has been used on the 82 style, and a 80 style. I would assume the 81 to be the same.... could be a difference in the switch... does yours have the numbers like in the diagram? some have letters.... -
DPDT = Double Pole Double Throw. you might have to find a Radio Shack or equivalent electronic parts store.... the switch is away, so you are looking at the bottom or back of the switch. -
did you use a DPDT switch? here is the diagram again.... http://www.ultimatesubaru.org/80s/diagrams/centerlamp-wire.jpg -
ignition switch '87 brat /tumbler removal
mcbrat replied to DaveAP's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've used a dremel to make a slot in a headless bolt before, and then used a regular screw driver to get it out.... never looked at the internals of the lock before though..... -
Light in the center of the grill
mcbrat replied to Birddog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if you go to the gray bar above, and click on 'Homepage' then find "80s Subarus" along the left hand side, and click it, at the bottom of that page is a helpful diagrams link. one of the diagrams is how to wire the centerlamp with a DPDT switch.... http://www.ultimatesubaru.org/80s/diagrams/centerlamp-wire.jpg -
yeah it was Tim I believe... QuattroNut was his board name I think...
i need 14 inch rims bad real bad
mcbrat replied to vtboy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I responded to your PM with my phone number a couple of days ago..... -
sure, if you have the exact same vuild structure, but the steel blocks are hollow, and the AL ones are solid blocks.
Patrick K. Davis Prices should be on the website... http://www.ozified.com
yeah. has a littleflex in it, but not much.... I used the windo-weld from Advance Auto Parts and filled in all the areas around the stockrubber (after cleaning of course.) But you need to start with a good set that way.
weber fuel strainer in inlet.....
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
sounds good.... Ihaven't gotten to your imaginary CD's yet either -
I urethaned my tranny mounts and motor mounts. everything is holding up nicely. it vibrates a lot more than my 86 Brat.... but not unbearable for most normal driving. not sure I'd want to go on a 5+ hour drive in it....
so how important is this strainer? I just started a rebuild last night, and the plastic/mesh strainer is a bit "bent". looks to just be a catch for any big particles that fall out, though after going through the 2 soobie filters, not sure how much would be left...... I found the weber replacement number for it after lots of digging, but it still appears functional based on how it installs.... any thoughts.....
depends on if you want more than one person with you... I enjoyed my 82 lifted wagon, but my Brat is more fun... Hopefully my 87 lifted wagon will do okay with the set-up it's getting... for what you've described in other posts, your set-up above looks perfect..... 82 Brat 82 Brat 5" lift rear discs welded rear diff rancho shocks custom exhaust/magnaflow muffler ea81 with weber 32/36 27" BFG Mud Terrains custom bumpers winch dual battery 150 amp alt
78 brat vs 82 brat NEED QUICK RESPONCE
mcbrat replied to spinsirs's topic in Old Gen.: 80's GL/DL/XT/Loyales...
the second gen has a readily available lift from http://www.ozified.com , but you can get a lift for the gen1 from mudrat79 in Eugene. parts are probably a bit easier to find for the gen2, but since the 78 has already been converted to 1800 and D/R. it will come down to other less important things: tilt steering wheel roominess in cab bed capacity body style you prefer I like the style of the Gen1 too, but prefer the bigger size of the Gen2...
