mcbrat
Administrator
    6
Everything posted by mcbrat
  1. use stock clutch, but have the step on the flywheel reduced
  2. Welcome Brian! Did your parents ever sell their SUS? Did you get the '96 locally?
  3. anybody know of a good replacement washer pump for an ea81? been through 2 of them now... since July... both just died... failed seals. might just grab something from a newer vehicle, and make it work... maybe with a larger tank
  4. likewise. there's a place in Des Moines, that will just take the old shaft stuff, cut off the ends and reuse if they can, and put a new tube on it. my last one piece was $135 for the 5 speed in my brat... they just need the cap to cap measurement... http://www.certifiedpower.com/cpi_desm_svrep.aspx
  5. I did this with my red Brat after busting 2 sender units....
  6. well, if the 4 door is truly an '85, then it will have an ea82 engine, not an ea81, unless it's been swapped out before..... the last year for a 4 door ea81, was '84 if it is in fact a '85 4 door, then most of the parts you need should swap over..... if you know for a fact the body is different, then it's a '84
  7. I'm thinking you saw a misprint, or it was a custom set-up do you remember where you saw it?
  8. I think is the stock US list... the turbo guys can correct me (in order of "size" according to what I've read) ea81T = vf4 ea82T = vf7 ej22T = vf10/vf11 ej20k = td04 ej20G = vf8 ej257 = vf39 (also have seen vf3 and vf6 mentioned on some boards for the ea series...) and I found this... FORESTER - - TD04 MHI Turbo 49377 04300 FORESTER (98- ) 58T 14412AA140 TD04L-13T-6 MHI Turbo 49377 04100 FORESTER (99- ) 58T 14412AA240 TF035HM-14T-4 MHI Turbo 49135 04600 Impreza ('98) - 14412AA140 TD04H MHI Turbo 49377 04100 IMPREZA GT 58T - TD04L MHI Turbo 49377 04200 IMPREZA GT555 58T 14411AA091 TD05H-16G MHI Turbo 49178 06300 IMPREZA GT555 (97- ) 58T 14412AA092 TD05H-16G MHI Turbo 49178 06310 Impreza WRX - - TD04 MHI Turbo 49377 06200 Impreza WRX - NB ('00) - - TD04H MHI Turbo 49377 04300 IMPREZE/ LEGACY (90- ) EJ20 14411AA080 RHB52XW IHI Turbo VB180039 VF12 LEGACY (SEQUENTIAL T/C) EJ20 14411AA114/ 5 RHF4B IHI Turbo VC650015 VF13 LEGACY (91- ) EJ20 14411AA030 RHB52XW IHI Turbo VG130075 VF8 LEGACY (SEQUENTIAL T/C) EJ20 14409AA002..6 RHF4B IHI Turbo VD650012 VF14 LEGACY (SEQUENTIAL T/C) EJ20 G/E 14409AA060 RHF4B IHI Turbo VA660045 VF32 LEGACY (SEQUENTIAL T/C) EJ20 G/E 14411AA350/ 1 RHF4B IHI Turbo VB420047 VF31 RX TURBO (85-90) EA82 14411AA011 RHB52EW IHI Turbo NN130038 VF3 RX TURBO (87- ) EA82 14411AA012 RHB52EW IHI Turbo VB130056 VF6 STI (LIMITED EDITION) EJ20G/E 14411AA321 RHF5HB IHI Turbo VA660060 VF34 STI VER.III EJ20 14412AA172 RHF5HB IHI Turbo VA660043 VF2B STI VER.IV EJ20 14412AA200 RHF5B IHI Turbo VA660050 VF24 STI VER.VI (99- ) EJ20 144123AA250 RHF5HB IHI Turbo VA660058 VF28 WRX STI ('00) EJ20 14411AA370 RHF55 IHI Turbo VA440017 VF30 WRX VER. III EJ20 14411AA142/ 3 RHF5HB IHI Turbo VA660033 VF22 WRX VER.VI EJ20 14411AA270/ 300 RHF5HB IHI Turbo VA660059 VF29 - EJ20G/E 14411AA440 RHF55 IHI Turbo VA440022 VF35 - EJ20G/E 14411AA492 RHF5HB IHI Turbo Email us - EJ20G/E 14411AA541 RHF55 IHI Turbo Email us - Unknown Email us RHF5HB IHI Turbo VE660065 VF36 - Unknown Email us RHF55 IHI Turbo VE440027 VF37
  9. just use the 5 spd D/R flywheel, but have it surfaced to XT6 specs, then use the XT6 clutch and pressure plate....
  10. Multi-colored Turbo Brats are the best
  11. Ben, that blower motor might be in my parts pile as well....
  12. Ben, in my pile of parts for you is a stock stereo with a harness I believe, plus there is also a aftermarket harness adapter NIP....
  13. at least it looks like a rolling 6 digits! now you just need to identify particular case casting differences
  14. For the Vanagon, yes, you would need to mount a radiator in front, and run hard piping from it to the rear... ShawnW did his first one this way, but then found a later water cooled one to start with... much easier.... for Bugs and sand rails, you'd also have to mount a radiator somehow....
