11
Everything posted by mcbrat
'84 and now that I think about it, it may have been a Rusty Jones decal....
it used to be fairly common around here. my parents had it done. it just slows it down... I got a perfect back glass out of a turbo wagon with a big 'ole ziebart decal. the rear door had many rust spots on it......
Gallery : 73 Subaru Splitgate
mcbrat replied to bryanthompson's topic in Historic Subaru Forum: 50's thru 70's
those new centercaps look nice!!! -
can't really. they were on a screaming built engine XT6 with welded diffs. http://www.titanstore.com/search/odiam/27
http://www.summittire.us/Pages%20II/mudsnow.html Pacemark Snowtrakker
may want to check here as well... http://www.dmbolt.com/
I used one of these... http://www.yourdictionary.com/images/ahd/jpg/A4contsk.jpg
hatch louvers and a maroon 83-84 rear hatch that's completely rust free.... oh, and a rear seatback without rips/tears....
aftermarket shifters for 5 speed?
mcbrat replied to hatchsub's topic in Old Gen.: 80's GL/DL/XT/Loyales...
same here. I think that's the handle on my dad's wagon now.... -
track width is different, so the axles are not interchangeable length-wise, though you can use the EA82 cups on the ea81 axles for a slightly better angle. you can't widen it either by cutting it, as each side torsion bar slides in from the outside, into the splined section in the middle where the rear height adjuster is...
try and wiggle the switch and see if it comes on. I had the same symptoms, and it was a bad switch.....
The links in this forum are user submitted. Use at your own risk. The products on these links are not endorsed by the USMB.
the biggest holdup, I believe, is that the 4.11 diffs don't have stubs, so then you'll need to use the legacy or Imp rear axles or some sort of hybrid.... the stubs from the 3.90 VLSD won't work. I think is was SuberDave who tried that one out..... that may only be for the WRX LSD though.....
if you take the carb top off, I'd check to see if there's anything stuck in the emulsion tubes.... I'd reset the idle mixture screw as well. turn it in until the spring is compressed all the way, but don't force it any further. then back it out 3 full turns.... I'd reset your timing to stock, and besure your throttle linkage is set properly... I'd guess you don't have an idle cut-off solenoid since you bought a new kit...
it all depends on terrain and set-up. the place I go the most often, has lots of areas that are too wide for full size vehicles. I usually end up on some quad trails too.... but there's also some things that I can't do, because of the the suspension limitations or the need for a front locker..... with independent suspension, you actually lose ground clearance when your wheels move up... because of the terrain I frequent the most, my best set-up, with the independent suspension, is welded rear, RX springs in front, and suspension adjusted all the way up front and back. nice and stiff because I need to maintain the clearance. I'll never have a ford wheeler, but my next off-road warrior will not be a soob....
actually, the guy that made mine lives in Bradenton FL now.... not sure how far that is, but I can PM you his name.
I used Subarino's pic as a guide (sort of) when this one was built.... http://www.ultimatesubaru.org/photos/showphoto.php?photo=1217&cat=539
the stop leak has clogged up your heater core....
it all depends on the terrain you're going to be on.... I'm running 30's, but have lots of other mods to help compensate.... something for you would be to get a 3.90 D/R from a 85-89 Wagon... and if you plan to go bigger, then you will definitely need to look into the t-case swap. Nissan 720 or Sammy divorced t-case could work. lot's better gears available for the sammy t-case....
http://www.indysworld.com/subaru/general/USRM/subrepair.htm
- 1 reply
- 6
yep. there's one with a 350 in it near me. mid engine.....
