6
Everything posted by mcbrat
what do you think your ratio of road driving to off-roading will be? what size tires will you be running?
if lifting for bigger tires for off-roading (not rallying) (27"+ tires) then go for a 5 speed D/R from a carb or SPFI 85-89 wagon. the RX D/R or FullTime Box will be better if you are Rallying (no lift)....
Hey All new to the CLub!
mcbrat replied to Sogonerg's topic in Meet n' Greet. Your USMB Welcome Center
okay, maybe more than "just south" Des Moines.... -
welcome! (from just south of you) -
nice. I'm down to just 2 Brats right now, but still looking for a hatch....
40 Miles per gallon with ol Gl wagon
mcbrat replied to roadsubiedog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://motors.search-desc.ebay.com/E-2970_W0QQsofocusZbsQQsbrftogZ1QQfromZR10QQsaspiZ2QQsamcmZ6000QQsatitleZE-2970QQsacatZ6000QQcatrefZC6QQftsZ2QQmppfqyZE-2970QQsargnZ-1QQsaslcZ2QQsadisZ200QQfposZQ5AIPQ2FPostalQQftrtZ1QQftrvZ1QQfsopZ1QQfsooZ1QQcoactionZcompareQQcopagenumZ1QQcoentrypageZsearch -
Doesn't look like I'll be able to coordinate anything deemed MW4 this year due to just being too damn busy with stuff..... If someone else want to try to put something together, please do..... Also, if you still want to do some wheeling and camping, check out this thread... http://www.ultimatesubaru.org/forum/showthread.php?t=53683 plenty of trails for stock soobs (lifted is better). This place caters generally to quads and sandrails.....
grind the red areas down as much as you can... and then I also use a small round file, and slightly oval out the hole in the trut tower towards the engine to give it a little more room to move inward too.
anyone ever put this type bumper on...
mcbrat replied to LiftedHatchSubie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
here's an example of too beefy -
The Return of Mountain Grizzly...
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
okay, fixed the drivers side window (wire unplugged) got rid of the bad tranny (now has one from a '86 Brat....) new battery cable lights on the roof ... and stuff still in progress.... new front wheel bearings new front axles some new brake pads lights on brush guard hope to have it all put back together tomorrow, so I can take it on a road trip Friday..... -
Lets play.. name that sound
mcbrat replied to 7point62fmj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
if it only happens above 40, then I'd say its a tire feature since you just redid the bearings, you might want to have the alignment checked out too..... -
ea81 or ea82 cupholders that work great!! pics inside
mcbrat replied to 75subie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a set of these for the off-roader -
to help with your camber, do this.... take your strut lift blocks and grind off all the areas in red on the top plate... and be sure you have beaten the snot out of the inner strut tower to allow the strut to move in at the top, and not rub. you may also want to slightly oval the strut mount hole towards the engine, to allow the top to move even further towards the engine. These things will help your camber....
Is anyone running a holley 4bbl??
mcbrat replied to Bobby_boucher's topic in Old Gen.: 80's GL/DL/XT/Loyales...
okay, if you check the link "7.62" gave you, I have put the pictures back out there so they show up. it's a holley 600 cfm, with vacuum secondaries. I used a standard 2bbl->4bb adapter, and had to slot the 2bbl mount slots a bit narrower to fit the weber bolt pattern, and I used a regular ea81 hitachi to weber adapter with it... and some spacers I believe. the idle is controlled by the secondary throttle plate, so I had to adjust it a bit to even get it to idle around 1000 rpms. otherwise, it was at about 1500 it was great at WCSS7, in the gravel pit. it loves high revs. I have since switched back to a weber, as the holley was zero fun to drive around town because it wasn't really happy until about 2500 rpms, and it made town driving really unpleasant... I did take it on a 2 day trail ride, and for the times when I could rev it high, it was great, but for the most part, if you are doing twisty slow going trails, you have to keep it revved all the time. it also had lots more issues with the severe angles. quit on me lots. since I switched back to the weber, no angle problems any more.... it was a fun experiment though... I still have it (w/o air filter assembly) and the adapter.... -
replacement struts do not come with the strut mounts or springs. you will need to take the strut mounts and springs off your existing front struts, and put them on the replacement struts. if you buy the replacement struts/mounts from NAPA, they have a spring compressor that you can use... (at least they used to work it that way, for a refundable deposit)... be sure and regrease the thrust bearing in the strut mounts though...
Part from interior, '81 Brat
mcbrat replied to Caboobaroo's topic in Historic Subaru Forum: 50's thru 70's
was it the red one in Iowa? -
gen1 coupe measurements needed
mcbrat replied to mcbrat's topic in Historic Subaru Forum: 50's thru 70's
I had a feeling they might have come from you.... though I have found multiple boxes of decals out there... it was like a treasure hunt the gen1 brat 3 color is a printed color decal, (plus, I'd recognize it ) the way the decal "curves" leads me to believe it is for a Gen1. They have "SUBARU" in the rear section of the decal.... so I at least know they are for a soob actually, any gen1 fender length, or Gen1 2-door door length will work for those measurements..... -
I've been busy cleaning out (getting rid of) lots of my accumulated parts from the last several years and I came across a NOS set of decals. don't remember where I got 'em, but they appear to be for a gen1 2 door. it's a 3 color (red/black/white) cut vinyl horizon stripe. (at door handle level, the entirelength of the car) I need the following measurements (at door handle height) off a GEn1 2 door for reference... fender length from front edge to door. length of door distance from rear of door to knob on gas cap total length of rear quarter (rear of door to backend) My decal equipment can't replicate these because it doesn't like long straight lines
looks like a cover for a seat rail, where it mounts....
