11
Everything posted by mcbrat
what kind of a seat does an Imp set in? or are they from a sunbeam Imp?
.... that may have been only for certain years.... the 84 parts manual does not show a different cam for the Brat....
you need to mod the ea81 tranny mounts, and they will mount to the 5 speed, and fit into the ea81 crossmember.
EA81 Electrical Problem with starting?
mcbrat replied to dustyrider's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I had the exact same thing happen. I had an internal short in the battery. it would "charge" but it was just putting a static charge on it. I'd try a different battery if possible.... (to be sure) -
I followed this right here... http://www.ultimatesubaru.org/forum/showthread.php?t=49952 the area to grind is the edges right where the opening at the bottom for the flywheel is... you only need to grind if the engine was originally mated to a manual tranny. I just dropped a ea81 into a 87 wagon with 5 speed, and didn't have to do any grinding, as the motor came from a car with AT.
do you see a problem with this??
mcbrat replied to 7point62fmj's topic in Old Gen.: 80's GL/DL/XT/Loyales...
should be no problem.... -
I did this with my 5 speed conversion....
ea81 D/R pops out of 1st gear and 4th on occasion. takes a longer throw to get it into 4th. (normal?) as compared to 2nd. when I let up on gas, it kind of whines a bit as it coasts.... (wheel bearings, axle, or tranny?) I hate tranny swaps....
that one is a little compressed though..... I had one that was almost flat like a pancake....
easy weber air box swap!
mcbrat replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
it's in the repair manual suggestions near the bottom on the main forums page, or already moved to the USRM.... -
yes, I was 2 qts low on oil at that point since I snapped off my oil sender....so I didn't start it up again until back at the top when I got, of all things, a FORD part to get me home....
here's some more pics.... http://www.ci4wi.org/Portal/modules.php?set_albumName=20060412_Oceola&op=modload&name=gallery&file=index&include=view_album.php&page=1
clutch started slipping before any of this happened, and it was in 4 low the whole time.... this was just trying to get back to the top. there was no trail. we were making it as we went.... normally I take the Brat on a trailer, but didn't this time.... so I was lucky to be able to drive it home.... I'm going to be fixing up a mechanical oil pressure gauge now too....
a little off-roading today.... http://www.ultimatesubaru.org/photos/showgallery.php?cat=838 slippery, steep side hills, trees, poor gearing don't mix well final straw for my clutch busted the oil sender unit off (need better skid plate yet) numerous dents on both sides both mirrors busted... CV boot shredded.... Winch got a good workout.
I'm guessing he now has one (Brat)...
yeah I have one. There seemed to be a string of them that popped up on eBay a couple years back, but haven't seen any since. supposedly made in Italy. Cloisone is the method/type of emblem construction.
Chevy/GMC 6 lugs. Would these fit?
mcbrat replied to NewDriverOlderRide's topic in Old Gen.: 80's GL/DL/XT/Loyales...
6 lug wheels are 6 x5.5"(139.7mm) -
ask if they are 8" from outside edge to outside edge. if so they are 15x7's like these... -
IL,WI,IN, and IA Subies
mcbrat replied to SyntheticBlinkerFluid's topic in Meet n' Greet. Your USMB Welcome Center
I'm in Des Moines.... -
The Return of Mountain Grizzly...
mcbrat replied to mcbrat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
another good day. it's alive. ran it today for a little while. fixed up some headlight wiring got color matched left fender, hood and cowl on. it's all red again. stock roof rack bars installed getting reaquainted with the wiring mods this thing has.... trying to chase down PW problem. drivers window will not work. either switch... other 3 windows work fine... motor was tested, and it's good.... I'll have to trace it and see where it's losing power.... -
glad to see you made it home.... don't know how long I'd trust those tires at 70 though!!!!
I snagged the pics for the wheels page. 13's?
