tcporsche
  • Location
    Brattleboro Vt.
  • Referral
    online
  • Biography
    retired optical tech.auto mechanics hobby
  • Vehicles
    1984 gl wagon
Recent Profile Visitors
507 profile views
tcporsche's Achievements
Member
Member (2/11)
2
  1. Hi guys,does anyone have a source for front struts for '84 fwd gl wagon? If not has anyone been able to fit '85 struts on the '84? thanks, tom cramer
  2. Hi guys, I'm looking for the two pieces on my 1984 gl wagon unibody that attach the left and right frame rails to the front ends of the left and right rockers.The're about 8" long and 6" wide and they're curved.with recesses pressed into them.obviously difficult to fabricate.So,where can . these pcs.if anyone has a parts car,Has anyone dealt with this?Thanks in advance T.C.
  3. thanks guys.Vt. used to be like texas i.e. just keep on going till you pass.however a brand new system that makes that just about impossible has just been started.every station has a direct link to dmv.thanks again.T.C.
  4. Hi guys,well my '84 GL just failed inspection due to unibody rust.I believe it can be fixed.does anybody know where I can buy already formed pieces that can be welded replacement parts? Has anyone done this before? I can weld but forming the parts takes the most time.Thanks, T.C.
  5. Thanks for the reply.when cold the butterflies are almost completely closed.So are you saying when cold I should adjust the choke so more air,less fuel is coming in?I will try.Thanks
  6. Hi everyone,I put the 32/36 weber DGEV carb.in 2 years ago.Used the correct manifold.ect,ect,ect.My problem is at first start it feels like it's running on 2 cyls. Can't drive till it warms up (about 5 mins.)If you put in gear before this it just stalls.I've checked for vacuum leaks,correct timing,idle,mixture,plugs,coil,wires,ect.NO LUCK! anybody done this swap and had similar problems?Once it runs good it's good for the rest of the day.fuel pressure and quantity are good. car is 1984 gl sw EA81 1.8l. Thanks in advance for any ideas.Tom Cramer.
  7. Hi,I've put the k730 weber kit on my '84 ea81 wagon with a hitachi manifold and the problem is the left front corner of the air box is about 1/16" away from a plug wire coming out of the dizzy.This seems dangerous.Do you agree?I called redline and they say just put a piece of insulation from a romex wire in between.the other problem is the idle speed screw.even when all the way in it is still 1/4" away from the linkage but the linkage isn't hitting anywhere and snaps shut fine.I appreciate you're help.Tom Cramer
  8. Hi, question.In your write up (excellent by the way) I noticed where the 5/8 " hose from the pass.side mounts under the airbox, the elbow is right under the filter element.Isn't this blocking the airflow?Or does it work just fine? Thanks for reply.Tom Cramer
  9. Can anyone tell me where I can buy original or close to it cut-pile carpet with the felt bonded to bottom?Thanks,T.C.
